Question about Westinghouse Washing Machines
My Westinghouse lt819 shown an error of pu at around 28minutes the wash eventually finishes but it is stopping with this message more and more often I have checked the waste pipe is not kinked or blocked I think I will have to have a tech attend to fix it
5 Suggested Answers
  • 77 Answers
SOURCE: washing machine
-the conditioner compartment may be blocked
- the cable with spring that change course of the water may be out,
Posted on May 08, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint aquarius extra manual WMA44 can't find the waste pipe
Remove lower rear cover of washer, locate, and remove large black hose fastened to bottom of drum, remove and clean plastic filter inside hose.
Please rate my solution.
Thanks.
Posted on Aug 28, 2009
SOURCE: Hi, good evening. I have a zanussi iz12 washing
Hi there
I have an IZ12 jetsystem which sometimes works and other times it starts and then clicks and stops just before the water starts to run in. I usually turn it off and try it again a few hours later and then it starts to work again. Sometimes it is the next day before it will work again. Would anyone know the problem?
Posted on Aug 14, 2010
  • 6277 Answers
SOURCE: goes through washing cycle then
Have you managed to check that the drain pump is functioning correctly? Here is the final bit of my guidance notes on checking filters AND motors ;-0)
Disconnect power
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
Posted on Mar 20, 2011
Westinghouse LT809 S Won't spin water out message PU
Won spin water out message PU Google Search ..try this link..you did not put make or model if you dont find what you are looking for her just put in your make and model into google and see if it finds something to do with your model.
Dec 02, 2016 | Washing Machines
My washing machine goes fine until half way through wash then comes up with error code PU and beeps until I turn it off...will not drain out the water? Simpson encore 556
simpson encore pu Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/simpson_encore_pu
Unsolved problems for simpson encore pu question. Get free help ... My simpson encore 757 shows PU error code. What is this? ... Simpson encore 556. Aug 22 ...
Sep 10, 2015 | Simpson Washing Machines
My washer error message unit detect a problem
The most common solution for this message is to turn the machine OFF and then ON. If the error resets, you are done.
However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
Solution:
  1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
  2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
  3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Mar 02, 2015 | GE Profile WPRE6100G Top Load Washer
I keep getting the error message top-au followed by weird sounds on a westinghouse sensor drive
I tried to research this error but came back with no results. I would contact Westinghouse and talk to their support team.
May 08, 2012 | Westinghouse Washing Machines
I have a Westinghouse Mastermind 711 Front Loader Washing Machine which is flashing OE and the clothes inside are very wet. Can you please let me know what this flashing OE means....Many Thanks, ELena
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
May 27, 2011 | Westinghouse Washing Machines
Error message UE
out of balanced? adjust your clothes till there even around the bowl. set the machine on a higher water level. cheers
Mar 31, 2009 | LG Washing Machines
Samsung frontloader problem
UE - UNBALANCE ERROR
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 31, 2009 | Washing Machines
F-11 code error.
sound like a control problem
May 24, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Mack Baxter
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
