Question about Garden
Bought a presto briefcase from the flea market, which came opened already but the combination lock is locked and i don't know the number. will like to open and reset, any help ?
Obertelli
  • 3006 Answers
SOURCE: Samsonite Briefcase, fogot the Combination Lock can not open it
There is no quick fix, it wouldn't be very secure if there was.
There are 999 possible combinations remaining and if you start at 001 you'd be extremely unlucky to need to go through all of them. Try 999 straight away though, sometimes the tumblers can appear to be set to 000 when they're actually at 999.
Posted on Aug 11, 2009
SOURCE: change combination on a presto lock
Enter the correct code and open the case. Now push the button you use to open the case to the open position and hold it there, now push in the clamp and push the opener more and it will lock in place. Enter the new code and push the clamp part again to set it. Do to other side now.
Posted on Feb 14, 2010
SOURCE: presto combination lock on a suitcase will not open
my mother in law has a norton suit case and needs keys the number on the lock is 332 norton do not excist anymore where can i get replacment keys from?
Posted on Mar 01, 2010
flbergeron68
  • 541 Answers
SOURCE: how to reset an open master lock
your answer is on this site
http://www.masterlock.com/faq/lostcombo.shtml
Posted on Jul 05, 2010
  • 905 Answers
SOURCE: I have an old but
Hello Bud,
Classic case, that has been addressed several times on the internet.
My favorites:
This is a video showing how to do it:
http://www.metacafe.com/watch/756344/easier_briefcase_crack/
Here is another alternative, that also works well.
http://wiki.answers.com/Q/How_do_you_open_a_briefcase_when_the_combination_is_lost
Posted on Sep 18, 2010
I lost the combination and I need to know how to open it without the combination. Help!!!
man I hate this when it happens . to destroy a perfectly good case . saw or grind the lock off .
Dec 09, 2015 | Vaultz Locking VZ01353 SLR Camera Case
Where can I get briefcase combination lock?
Look for my tip on unlocking luggage with combination locks.
Mar 26, 2015 | Delsey PARIS Hard Side Briefcase Business...
Fix my briefcase combination lock
Use Combination To Release Button--Factory is 00
Feb 27, 2015 | Luggage & Travel
I bought a sentry safe DH-074E, I know little about safes, except for they are valuable, at the flea market, for $30.00,with no pass code. How can I get It open, HELP
Good luck with that. You are hoping to get a code that any potential thief wants to know for a different reason. You may choose the approach that is common for Dudley locks, that involves sampling the code until it opens. This can be done about 100 times until you get an approximate code. However, I presume this safe has a more precise method of accepting combinations. Again, good luck. Don't lock anything valuable inside it until you find the code.
Feb 02, 2015 | Home Security
Is there an owner's manual available on line for a Stebco Attache Case Model P-16? I need to know how to set the combinations on the dial lock system.
I couldn't find the manual for your particular briefcase, but please read the instructions on the attached link. It should help you since most briefcase combination locks work the same. Hope it helps.
How to Change the Lock Combination on Briefcase
Oct 27, 2014 | Lands Phones
Presto combination lock
By frequently resetting your lock combination, you decrease the chance that someone will break into your luggage.
If someone watches you open your luggage at baggage claim while going through security or at a hotel, they may break into your luggage when they encounter you on another leg of your journey.
Change your lock after every major flight or trip to help keep your items safe.
Avoid easy to guess passwords, as well, such as sequential numbers, all the same number or birthdays.
Open your lock by inputting the current combination.
New Prestolocks have a factory set combination of "0-0-0."
Turn the shackle 180 degrees.
Press the shackle down and turn it 90 degrees to the left or right.
Input the new combination.
Move the shackle 90 degrees so that it is 180 degrees from its locked position.
Take your hand off the shackle and pull it out.
Turn it back to the locked position.
Push the shackle into the lock and turn at least one of the lock's dials.
Write down your new combination.
Keep this paper in a safe place for future reference.
Jun 20, 2013 | Extensis Suitcase X1
Forgot my Presto Lock combination!
You cannot reset the lock unless you know the combination. You would need someone to pick the lock, like a locksmith and then once it's open you can reset the lock with a new combination.
Jan 25, 2013 | Locks & Locksmithing
How do you set your own combination for the locks on the briefcase,there were no instructions with the case
  • 1 Turn the lock to the correct combination and open the briefcase.
  • 2 Look at the lock. There should be one or two pins that you can slide with your fingers. If there is one, simply push it in. If there are two, push them together. It may be the same button you use to open the case.
  • 3 Change the lock to an easy-to-remember value, such as 000 or 123, to test the lock. Release the pin.
  • 4 Close the briefcase and turn the lock to another value. It should not open. Now turn it to the test combination. It should open right up.
  • 5 Repeat Steps 2 and 3, but this time choose a number that will be easy for you to remember, but hard for someone else to guess. Write down your new combination and keep it somewhere safe.
  • Dec 29, 2010 | Office Equipment & Supplies
    Change combination on a presto lock on a briefcase
    Sep 15, 2009 | SK Hand Tool (87018F) 9pc. Fractional...
    Pin number
    The only way to get it going is to send it to Garmin. The PIN is a security lock and Garmin will only unlock and return it to the registered owner ... who is not you. This is to prevent miscreants from stealing them and then selling them at, erm flea markets. You DID ask for proof of ownership, manuals etc from the flea market person didn't you?
    Sep 12, 2007 | Garmin zumo 550 GPS Receiver
    Garden Logo
    393 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
