Question about Garden
I have model 12A-569Q755 serial no. 1E16K11678. The mower was bought new in 2006. The control levers have been removed and need reattached to the push handle. How do I reattach them correctly? There is a square piece that both levers attach through before attaching to the mower handle. I need an illustration if possible.
  • 843 Answers
Here's an exploded view.
http://www.oscar-wilson.com/MANUALS/MTD/770-10347F.PDF
Good luck
Posted on Aug 19, 2010
How to change blade on a troy-bilt mower model 12a-264u011
Turn mower on it's side with the carb facing up (otherwise fuel will pour out of the carb) There should be one bolt holding the blade on, remove it and the blade will come off. Install new blade in reverse order. Use an impact wrench if you have one otherwise use something to keep the blade from rotating when removing the bolt with a wrench.
Oct 19, 2014 | Troy Bilt 5.5hp Self Propelled Mower
How do I determine why the blades will not engage on my mower
With the mower turned off and the deck at its lowest setting, check the top of the deck for any debris like rocks or sticks. Then watch the top of the deck while you move the engage lever. If nothing is moving, you either need to adjust the cable, reattach the cable, or install a new cable. If you see the lever with the pulley on it moving, when the engage lever is locked on, check the tightness of the belt. If it's loose, that is your problem and it could be a stretched belt.
Sep 18, 2014 | Craftsman Garden
Why does speed control lever return to neutral when going forward ?
this model uses a series of groves cut into mower body to maintain the transmission gear/direction , it's held into groves by a spring just under the cover , if this is broken a replacement can be gotten from sears (part# 164X39) to replace it , it should take at least five pounds of force to move shift lever out of grove to next gear , if not then your shift spring is loose or broken
Jun 05, 2014 | Craftsman Garden
Troy Bilt self-propelled model #12A-466-M011 front wheel drive not working
would this also cause them to lock up when off???
May 10, 2012 | Troy Garden
Model #911503 ,serial #000278 The pull
Here a couple of links with instructions on replacing your rope... Text Good Luck
Jul 03, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Need manuel for Toro 12-38-xl riding mower
I have a Toro XL 380H, which has been discountinued, but I really need the bagger for this thing. I bought it in 2006, and my yard expanded and the grass is higher and thicker. Please help !!!
Jan 18, 2009 | Toro Garden
Unit in Safeguard Mode, Error Code 01
Wow! This is the same problem that I am having since I brought mines in 2006. This is imagining that this same problems and happening to many. Maybe it was a lemon of this product.
Dec 24, 2008 | JVC Video Cameras
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
