Question about HP Photosmart C6180 All-In-One InkJet Printer
Dice Error. 0xc18a0001 - HP Photosmart C6180 All-In-One InkJet Printer
  • 857 Answers
Please perform the below steps on the front panel of the printer to resolve the issue.
Press and Hold the "Print Photos" &"Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo"
Press and release in sequence"Red Eye Removal","Print Photos","Red Eye Removal".
Display should say “Support” and display the FW rev (something like R0616R)
Press and release the right arrow button until the display says “System Configuration Menu.
Then Press and release the "OK" button.
Display should say "Hardware failure status: Clear. Press OK to clear".
Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer.
Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. it will say printer preparation occuring - do not interrupt.now try to print a self test page and see what happens.
Make sure that you do these steps:
1) Load letter, A4, or legal unused plain, white paper into the input tray.
2) Make sure that the printer is on and loaded with unused plain, white paper.
3) Press Setup . The Setup menu appears.
4) Press the down arrow button to select Tools , and then press OK .
5) Press the down arrow button to select Self-test Report , and press OK . The self-test report prints.
This should fix your problem.
Posted on Aug 19, 2010
Ink system has failed. Error:0xc18a0001 my printer is HP Photosmart 8250All-in-One System Failure) I refer to printer documentation Error:0xc18a0001 Turn power off, then on again. I dId this command but...
Try taking out the cartridges, and turning off then unplugging the printer. Leave it unplugged for about five minutes, the plug it in. Wait a few more minutes, and turn it on. Wait for it to completely start up, then put the cartridges back in (make sure you are putting them in correctly, I think this is your product here). If it still shows the error, contact HP customer service. They will probably say something similar, though.
Jul 06, 2011 | Office Equipment & Supplies
ERROR 0xc18a0001 Ink system has failed Quite new
Try the link below. This error is related to air in the lines between the print head and the cartridges. It is quite common and HP are very aware of this.
http://fix-your-printer.blogspot.com/2009/03/ink-system-failure-on-hp-photosmart.html
I hope this helps. Regards GM
Apr 16, 2011 | HP Photosmart D7360 All-In-One InkJet...
Tengo una hp photosmart c6280 y tiene un problema con un error 0xc18a0001 compre los cartuchos nuevos y sigue reflejando el mismo error, compre un sistema continuo y sigue dando el mismo error,quiero saber...
if you speak english and can read english go here and scroll down to Re: hp photosmart 8250 by Anonymous (7/26/08 2:04 PM) reply There is also help from HP support online chat
http://www.fixyourownprinter.com/forums/printer/51559
si usted no habla Ingl?s o leer aqu? es la conversaci?n que le dir? c?mo resolver el problema paso a paso de este error. si esto no ayuda usted puede ir a CV y obtener ayuda en l?nea o hablar con un t?cnico por tel?fono.
Aceptar que ten?a el c?digo de error CV 0xc18a0001 problema y aqu? est? la conversaci?n que tuve con el ..... James Cowan tecnolog?a: el c?digo de error CV 0xc18a0001 llamarse Ernesto: Voy a ayudarle en este sentido James Cowan: gran llamarse Ernesto: Yo entiendo que una c?digo de error con 0xc18a0001 con "Error de sistema de tinta" se muestra en el panel frontal del dispositivo Todo en Uno de la impresora. En lo correcto? Soy James Cowan: correcta Ernesto: Gracias por la confirmaci?n de llamarse Ernesto: ¿Me puede dar el n?mero del modelo del dispositivo Todo en Uno que est? utilizando: James Cowan c6250 llamarse Ernesto: Gracias por la informaci?n. Gracias Ernesto: James, por favor h?gamelo conocer la temperatura ambiente en el que la impresora se sustituye James Cowan: 67 grados F llamarse Ernesto: Muy bien llamarse Ernesto: Por favor, realice los pasos siguientes en el panel frontal de la impresora para resolver el problema de James Cowan: puede llamarse Ernesto: Pulse la tecla "flecha izquierda" . Presione la tecla "Setup" clave y suelte ambas teclas, la pantalla debe decir "Introduzca Especial Combinaci?n de teclas" Pulse y suelte el bot?n "Aceptar". llamarse Ernesto Por favor, ignore los pasos anteriores, James James Cowan: ok si nada parec?a hacer nada Ernesto: Por favor, realice los pasos siguientes en el panel frontal de la impresora Earnest el: Pulse y mantenga oprimido el "Imprimir fotograf?as" y "ojos rojos" botones. Suelte ambos botones. La pantalla debe decir "Introduzca Especial Combinaci?n de teclas" Pulse y suelte en la secuencia de "ojos rojos", "Imprimir fotograf?as", "ojos rojos" Ernesto: la pantalla debe decir "apoyo" y mostrar el rev FW (algo as? como R0616R) James Cowan : Ernesto COxxFN0723BR: Bueno Ernesto: 2. Pulse y suelte el bot?n de flecha derecha hasta que la pantalla dice "Men? de configuraci?n del sistema James Cowan: puede llamarse Ernesto: 3. Pulse y suelte el bot?n "Aceptar". James Cowan bien y que dice llamarse Ernesto estado de fallo de hardware: pantalla debe decir "error de estado de hardware: Despejado. Pulse Aceptar para borrar". Llamarse Ernesto: Pulse y suelte el bot?n "Aceptar". Mensaje se convierte en "estado de error de hardware aclarados continuar. Pulse Cancelar para":. Llamarse Ernesto Pulse y suelte el bot?n "CANCEL" tantas veces como sea necesario, de modo que, ya sea el "Welcome to Photosmart Express", aparece la pantalla, o bien, la tinta " El fracaso del sistema "aparecer?. NO TRATE DE NO ESCRIBA EN ESTA ETAPA. POR FAVOR James Cowan: puede llamarse Ernesto: Con el bot?n de encendido, apagar la unidad y desconecte el cable de alimentaci?n de la parte posterior de la salida de la impresora y la pared:. Llamarse Ernesto D?jame saber una vez que se realizan con el los pasos anteriores James Cowan: ok su desenchufado llamarse Ernesto: Espere 30 segundos para que el poder ser dado de alta ya continuaci?n, conecte el cable de alimentaci?n al enchufe de la pared primero y luego en la parte posterior de la impresora llamarse Ernesto: Encienda la unidad. La impresora puede mostrar mensaje "USO DE ENERG?A BOT?N DE PARADA DE LA IMPRESORA" seguido de "Pulse Aceptar para continuar". Pulse Aceptar. James Cowan: puede llamarse Ernesto: Quisiera saber el mensaje que muestra en la parte frontal del panel de la impresora James Cowan impresora: preparaci?n ocurriendo - no interrumpir Ernesto Bueno James Cowan: puede hacer su Earnest: Vamos a imprimir una p?gina de autoprueba de la impresora ya James Cowan: tratar bien llamarse Ernesto: 1) Carta de la carga, A4, o de plano no utilizados legales, papel blanco en la bandeja de entrada 3. 2) Aseg?rese de que la impresora est? encendida y cargada sin usar con papel blanco), papel. Pulse Configuraci?n. El men? de configuraci?n. 4) Pulse el bot?n flecha hacia abajo para seleccionar Herramientas y, a continuaci?n, pulse Aceptar. 5) Pulse la flecha hacia abajo para seleccionar Auto-prueba de informe, y pulse Aceptar. El auto-informe de prueba imprime. James Cowan se puede imprimir llamarse Ernesto: Muy bien, por favor, compruebe si todos los colores pritned perfectamente en la p?gina de prueba James Cowan: perfecto llamarse Ernesto: Gran .. Saludos James Cowan:! Muchas gracias Ernesto: James, ahora usted puede seguir utilizando la impresora de llamarse Ernesto: Le agradezco su esfuerzo y paciencia para tratar de resolver el problema.
Oct 01, 2010 | Office Equipment & Supplies
I get the following error message from C5180 printer: 0xc18a0001. What should I do?
Hi there
0xc18a0001.
Try the following steps to remove HP Printer Error Code 0xc18a0001.
I have put 3 ways for you to try.
1. Without turning off the printer, unplug the USB cable.
2. Remove the cartridges.
3. Wait until the message "Insert cartridge" appears.
4. Unplug the power cord.
5. Wait 60 seconds.
6. Reconnect the power cable. If the printer does not turn on automatically, press "On button".
7. Reinsert the cartridges and close the lid.
8. If the printer has a page of calibration accept.
9. Reconnect the USB cable and remake an impression.
10. If the problem persists, the machine must be repaired.
Or try 2
Turn the printer and wait until you receive the error message.
* Simultaneously press the keys "9" and "#" printer.
* While holding the button down, unplug the power cord from the unit.
* Wait a few seconds.
* Still holding the button down, reconnect the cable and turn on the printer.
* Release the buttons.
Or try 3
* Turn the printer and wait until you receive the error message.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Mar 01, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C6280 printer won't print and displays Ink System Failure message and Error #0xc18a0001.
Hi there
0xc18a0001.
5. Wait 60 seconds.
Or try 2
Or try 3
Feb 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
Mi mp3 nextar solo dice file system error y se apaga no se escuch
cuando le cambie las batterias solo dice file system errror
Feb 04, 2010 | Nextar X3 GPS Receiver
HP Photosmart C6180 All-In-One InkJet Printer Logo
35 people viewed this question
Seeker5211
Seeker5211
