Question about Microwave Ovens
My husband makes protein shakes in the margaritaville blender - is it possible to buy a closed top? The funnel where the ice comes out gets really yucky from the shake going up into it - plus, it's a pain to clean.
Microwave arcing
The magnet item is known as a magnetron, as far as your pcb is concerned check for shorts on the hv diode, be advised microwaves can kill you, never work with the cover off and always discharge the HV capacitor, if you don't know how to do this then do yourself a favour and get the lid back on and buy a new one, If you do know then good luck!!
May 17, 2012 | Microwave Ovens
I am getting ready to update my appliances. I want to know the exact size of the appliances I currently have supplying you the model and serial numbers. Double wall oven: RDE 2400 P2 Model Number, MI 34...
OK, now replacement of major appliances in your home should be left to someone that you don't even know. Why should I recommend Whirlpool replacement appliances. This is your decision.
It depend on what you want in appliances; such as, top quality, the most expensive, mid level appliances, and many other factors involved in your choices of replacement appliance.
Mrs Alecia William you need to talk it over with your husband and friends, do your research on appliances on the internet. Just remember this....Everybody will give advise on what appliances to buy but the final decision will be left you and your husband. I could recommend different types of appliances, but who am I! Please do your research. All I can recommend is BUY AMERICA. And yes, United States does make all the appliance that you have mentioned. GB you...stewbison
Sep 05, 2011 | Whirlpool Microwave Ovens
I have a blender thats been about 20+ years old... However, although I continue to use it well, lately it has been subject to leaking and other issues. I suspect that the rubber part (to hold the liquids...
Do you happen to know the make / model of your blender? If you do, you should be able to go to the manufacturer's website and order a replacement "o-ring".
Aug 17, 2011 | Microwave Ovens
Is the blades supposed to come off when I take the container off of the blender.. My blender is brand new sat for 3 or 4 years after I bought it. . The first time I used it , it was extremely hard to get...
You did not specify a brand or model number of your blender; however, most blender jars will lift off their power base without turning or with only very little turning motion to release them from the base. The blade assembly should NOT come off as you remove the blender jar from the power base.
Were you successful in removing the bottom ring which normally screws on to the bottom of the blender jar from the powerbase?
You should make sure you have properly attached the blade assembly for your brand/model.
The blender blade assembly should be held on to the bottom of the blender jar by the bottom ring which screws on clockwise; most will have a sealing gasket that fits between the blade assembly and the sealing surface of the blender jar to prevent any leakage while in use. It will take much more turning to unscrew the bottom ring to release the blade assembly than it should to release the bottom ring from the powerbase.
Assemble your blender jar and blade assembly and try a dry run by placing on the powerbase, giving a couple of bursts of power, and then seeing if you are able to remove without the blender ring unscrewing.
Make sure you are comfortable with the action required to remove the blender jar from the powerbase before you put in to use.
Jul 31, 2011 | Microwave Ovens
My blender won't power on, the lights don't turn on. I've had the blender for 1 year and have never had any problems with it. In the past month it would only work intermittently, and now it doesn't work...
sometimes something (food etc) gets "stuck" in the lock mechanism, preventing it from turning. unplug the blender and give the locking mechanism a cleaning with a bottle brush or rinsing it under very hot water. also the lock could be broken/chipped, also preventing it from turning.
i must admit that I broke my locking mechanism 5 years ago by not "seating" it correctly and forcing it. my hubby somehow removed! the locking mechanism but now it goes on - turns - as soon as I plug my blender in (because the stop/lock doesn't exist anymore). so I must be very careful to always have the lid on before I plug it in. but it's a braun blender and I love it. so i've kept it all this time.
Oct 06, 2010 | Microwave Ovens
Dear sir/mam im having a philips comfort juicer/blender of model no HR 1720,can u please suggest whre i will get a small pot whch wl get attached in this model?for your kind information model HR 2000/70...
It is not possible to attach extra units that can mesh with this juicer than the reccomended attachments that is available.Contact philips appliances dealer close to you.
Sep 29, 2010 | Microwave Ovens
My freezer is working but the rest of the fridge is hot
Hi, it is possible for your freezer to work when you fridge is not working. Fridge-freezer appliances have independent controls which can malfunction separately. If your freezer is fine and your fridge seems down, there are several things that could be wrong but what i suspect is that... You should check the damper door located between the freezer and fridge compartments to make sure it opens and closes, sometimes they get an ice build up there and this causes them to stick shut, remove ice with hair dryer or remove and device and replace this will solve your trouble.
Best of all is to call in a local fridge technician around to get it fixed, it won't cost you much...
Take care
Feb 18, 2010 | Magic Chef Microwave Ovens
Microwave Ovens Logo
35 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
