Question about Sharp R-1480 Microwave Oven
All funtchions work except it dos'nt heat up anything Light comes on, turntable works, timer works. But no heat
  • Kelly
    Kelly Aug 19, 2010
    No loud buzzing before? Usually when this happens there are 3 items that can cause the problem.
    1. The HV Capacitor
    2. The Power Diode
    3. The Magnetron
    I can help but need a complete model number for exact parts references and sources of parts for you to purchase. I will NOT tell you to change a part you have not proven to be defective.
    Just respond with the Model number please.
    Thanks for choosing FixYa,
    Kelly
  • bobjamieson Aug 19, 2010
    The model no is IEC 60705
    No buzzing just normal until you remove food and it's stone cold
  • Sharp Master
  • 3,740 Answers
I tried the ICE60705 number and it did not cross http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=IEC60705
Is that a serial number by chance?
To do any of the below the chassis cover must be removed.
To perform a diode resistance check you must first ground the high voltage capacitor several times to avoid a nasty shock.
To check the Diode you have to disconnect one side if the diode before reading resistance. Read the Diode on R X 1000 and then reverse the meter leads is should only ONE way. IF it reads both directions or not at all then it has failed.
To check the HV Capacitor (After grounding) you reverse the leads repeatedlyand watch for a momentary jump on an analog meter EACH time the leads are reversed. No jump of the meter needle = bad Capacitor.
Diodes can be found here:
http://www.appliancepartspros.com/Appliance-Parts/?keyword=Diode%2c+Sharp
I know that this is an 850W free standing Microwave. I just can recall the model number from memory.
If you find either one of the 2 parts bad I recommend contacting a LOCAL appliance parts center with parts in hand for the simple fact the model number is not crossing.
Just make sure they failed per directions above before replacement.
Thanks again for choosing FixYa.
Kelly
P.s. If the above parts check out good then that leaves the door switch or the magnetron as possible failures. If the Magnetron has failed you may want to evaluate repair vs total unit replacement cost of the microwave.
Posted on Aug 19, 2010
The microwave isn't heating/cooking on any setting but the turntable, light is working. What should I check before calling a repairman?
There is nothing more you can do, you have verified everything is working except it is not heating the food. The next step is have the repairman come in to isolate the cause.
Jun 02, 2011 | Maytag MMV4205 Microwave Oven
Not heating or defrosting although light works, timer etc works
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fjfh
May 11, 2010 | Neff H5470 Microwave Oven
MICROWAVE NOT HEATING
Most likely you have a magnetron problem. Easy to replace (DYI) but make sure the high voltage capacitor is fully discharged first against the case.
Dec 11, 2009 | Kenmore 62622 Microwave Oven
Everything seems to work fine until you hit the start button than nothing happens except the timer starts counting down
If everything appears to be working normally, as you say the timer counts down, the light comes on, turntable rotates etc. then the problem will be linked to the magnetron not operating & not heating the food. This could be just a thermal fuse device which may have gone faulty but if it is a magnetron fault then the cost of getting this replaced can be expensive & it might be more economical to buy a new microwave. I would advise taking it to a local repair centre, one which gives free estimates to get a quote on a price.
Jul 27, 2009 | GE Microwave Ovens
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
Won't heat
Do the inside light and turntable come on when you try to cook?
Is it making any unusual noise or is it louder or quieter than normal?
Do you have the model number?
Aug 01, 2008 | Maytag MMV5207A Microwave Oven
GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Dec 10, 2007 | GE JVM1650 1000 Watts Microwave Oven
Sharp R-1480 Microwave Oven Logo
315 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
