Question about McCulloch Garden
Mac 335 14" Chainsaw - not lubing chain. Oil Pump behind flywheel. What tool (name) can I use to free flywheel? Its a two pin type (probably rachet). So query is tool name and where to get it?
Mike258
  • 1498 Answers
SOURCE: Ryobi 14 inch electric chainsaw won't cut with new chain
Hi Rossmac,
Both the smoke and it's lack of cutting ability are symptoms of the same problem. The Chain is dulled. Instead of cutting, it's just rubbing on the wood and heating up. It's also not a big deal to fix..
Your options are:
  • Replace the Chain
  • Have the Chain sharpened
  • Sharpen it yourself
To sharpen it yourself, you will need a narrow round file that will fit inside the Chain teeth. Each tooth has a two cutting edges, get the file a position that matches the tooths angle of attack. Don't over do, three to five swipes of the file should do it on each surface.
You will see they alternate directions. You may find it easier to do all the teeth in one direction (skipping every other tooth) then do the other direction. Up to you.
When you are done, check the level of your chain oil. Since it did get hot, you might manually oil the chain before trying out your handi-work.
Go cut some wood.
Mike
Posted on Dec 21, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Chainsaw Bar Lube Oil Leaking
A new mounting bar would solve this issue. On that mounting bar there is a little piece that allows oil to drop onto the bar when you call for it or if this is a electric bar oil chain saw. Then it tracks when it needs to open.
Posted on Feb 14, 2009
dontbother10
  • 2220 Answers
SOURCE: Husqvarna chainsaw 440e - enough chain lube?
That seems low to me. Page 15 in your manual is the only oil discussion I found. Usually there is an oil pump adjustment reference somewhere. I didn't see one beyond return it for service on page 15. Are the chain and bar hot after cutting a while? I recommend you not get a longer bar without an oiler adjustment. I think the hand of the EPA has been here.
An IPL (exploded parts list) for a 440 can be found here:
http://weborder.husqvarna.com/order_static/doc/USA/2009/I09000/I0901018.pdf
There is no oiler adjuster listed. HTH
Lou
Might be a good idea to copy the IPL,
Posted on Oct 07, 2009
Testimonial: "thanking you"
dontbother10
  • 2220 Answers
SOURCE: magneto to flywheel gap for Husqvarna 455 Chain Saw
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 22, 2010
dontbother10
  • 2220 Answers
SOURCE: tighten chainsaw chain
There is a very in depth explanation in this Remington OM.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 25, 2010
Oil pump 266 xp
The pump or gasket could be bad. Make sure you use only bar and chain lube as this can also effect flow.
Apr 17, 2014 | Husqvarna 266-266xp Chainsaw Piston Ring...
018c oiler
ck.the oiler drive gear behind the chain sproket
May 06, 2013 | Standard Oregon Chainsaw Chain For Stihl...
I need to know which oil type goes into the oil chamber for the chain on a mac 3200 gas chainsaw, not the mixture...thanks
There really is no exact type of oil that goes into the chain and bar oiler. Each manufacturer usually makes their own, but any chain and bar oil will work. It is a thicker type of oil unlike a motor oil. Just ensure that the bottle says "bar and chain" oil
May 02, 2011 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
I need to change the oil pump in a stihl 026 chain saw but I am not sure how to access the pump. I believe it is beneath the armature but I am not sure how to take it off. Any advice or a...
Removing the Oil Pump
  • 1
    Pull off the spark plug's rubber boot. Unscrew the spark plug with the socket wrench. Remove the spark plug and insert the piston stop tool into the hole. Remove the starter cover and turn the flywheel by hand until the piston contacts the stop tool.
  • 2
    Unscrew the brake band's cover screws with the star Allen wrench. Remove the brake spring from its anchor pin with the end of the screwdriver. Caution: this spring is under a lot of pressure and may pop out unexpectedly. Remove the brake band from its seat on the crankshaft.
  • 3
    Remove the E-clip that holds the washer, sprocket and clutch drum to the crankcase. Pull them off the crankshaft. Unscrew the clutch's bolt with the socket wrench. Loosen the bolt clockwise and remove from the crankshaft. Pull off the washer. Remove the clutch shoes and the clutch spring.
  • 4
    Twist the worm and drive spring clockwise and remove them from the crankshaft. Unscrew the oil pump's mounting screws. Take the oil pump off its seat and remove from the crankshaft. Remove the bottom washer.
  • 5
    Disassemble the oil pump. Knock out the spring pin on the bottom with a punch. Pull the bottom control bolt from its hole and remove the O-rings. Pull the end plug off housing and remove the pump piston, spring and washer.
Read more: How to Repair the Oiler on a Stihl Chainsaw ' eHow.com http://www.ehow.com/how_6515266_repair-oiler-stihl-chainsaw.html#ixzz1H62BeTAW
Mar 19, 2011 | Stihl Chainsaw 024 026 Oil Pump
Flywheel/ignition coil air gap for mcculloch mac 130 chain saw
Specifications for a Mac 130 can be found here:
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/c1f32b7598cccadd88256c2f0019c792?OpenDocument
Ignition coil gap:
An index or business card is a good gap tool. Remove the plug, rotate until magnetic attraction pulls coil and card tight to flywheel, tighten the coil screws. Rotate flywheel until magnetic attraction eases, remove card, rotate a couple of revolutions and ensure nothing drags or contacts flywheel. HTH
Lou
Jan 07, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Homelite d3300 chainaw has stopped lubbing itself
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Oct 23, 2009 | Standard Oregon Chainsaw Chain For...
Lou
Oct 07, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
What type oil do you need for an electric chainsaw?
you need to buy chainsaw lube oil, its red and lubricates the chain.chainsaw chain lubricant. plz rate-bozcro
Sep 10, 2009 | Heavy Machinery
Have a MAC 3818 chain saw it just stopped oiling.
Same for me. Take chain off and ensure clean oil hole and channel. Clean hole if needed with fine wire or heavy nylon line. otherwise I think problem is interior, either oiler itself or oiler oil tube came loose. Since I have no excess oil coming out I suppose oiler iself is bad.Still working on it.
Apr 17, 2009 | Poulan 1630 16" Chain Saw
Feb 14, 2009 | Garden
Garden Logo
395 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
