Question about Cooktops
The ignition on my hob is sparking every second or so constantly on it's own? The knobs don't seem to be stuck down or anything obvious. All four ignition points on the cooking points are visibly sparking.
I think the problem lies at your knob mechanism. Try to service the mechansm. Currently the possible problem is lies at the contact point(electrical) might accidently contact without pressing down the knob. This normally occur when it is hyper press or there are grease in between the contact. Possible solution is replace the damage knob... or repair it.
Posted on Aug 26, 2010
We have an electrolux gas hob and it seems as if the electric spark ignition is stuck and it is clicking all the time on all four burners. Wonder if you have any suggestions ??
The problem is one(or more) of the 4 switches that turn on the spark when that burner is turned on is shorted and stays closed (on) all the time.To determine which one it is the face where the knobs are has to be removed,with THE POWER OFF a meter set to low ohms rating is used to check each switch by removing the wires to it and see which one has continunity (ZERO OHMS) when its off and that switch that slips on the burner valve shaft is the bad switch(s) and needs to be replaced to keep it from sparking all the time.
I hope this helps you to repair your cooktop,
Gene
Aug 07, 2011 | Electrolux Cooktops
Electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 31, 2010 | Cooktops
Gas hob is permanently igniting
hi gud day,try to clean the area of knobs by using vacium,remove all the knobs firts then clean it,unplug the unit before u clean.
tnx gerbee
May 19, 2009 | De Dietrich DTG775X Gas Hob 22 in. Cooktop
Ignitor will not stop sparking on AEG Electrolux Cooker Hob
gud day,try to clean the bottom of knob control by removing of knob then clean if by using a vacciumm,if u want to use manually ur cooktop unplug the unit to stop the cliking,then use macthes every time to on the gas cooktop.
Jan 09, 2009 | Cooktops
Four burner gas hob
You have to turn the knob a little farther, past the light stage. Sometimes they're not marked quite like they should be.
Jan 04, 2009 | Cooktops
Stuck auto ignition
try easing each knob upwards a bit.
Jul 15, 2008 | Smeg 23 in. SE64 Gas Cooktop
Dacor SGM304... no ignition
There is no fuses, as long as you have a power supply into unit then the only item that can cause this fault is a faulty spark generator.the hob will need to be dismatled to repair, remove the knobs, remove the burners and then remove the obvious screws, top will lift off Regards Advisor
Sep 01, 2007 | Dacor Preference SGM304 Gas Cooktop
Stuck auto ignition
Either one of the ignition switches are stuck down internally or the ignition pack is faulty, no other possible cause. Regards Advisor
Aug 29, 2007 | Smeg 23 in. SE64 Gas Cooktop
Gas Hob constant ignition clicking
Had the same problem. All five burners were continuously igniting, after my wife had given the stove a clean. Turned off the power, removed the five knobs and corresponding rubber rings, and used a hair dryer on the five holes where the knobs were for about ten minutes in total. Hey presto, when I turned the power back on, the constant igniting had stopped. Thank you all. I love the internet :-)
Aug 18, 2007 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Cooktops Logo
217 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
