Question about True 72 cu. ft. / 2039 liter Commercial Freezer GDM-72F
My GDM-72F Freezer lamps holder burned out and I wants to change them in order to use the T8 bulbs. Do I need to change the ballast too? It uses the magnetic ballast now.
  • True Master
  • 1,253 Answers
Yes, the ballast must match the bulbs. no other way to make it work correctly
Posted on Aug 21, 2010
Why gdm 72f cap tubes
That freezer is meant to have a stable load an example is storage. A supermarket application would require a tx valve.
Apr 28, 2014 | True 72 cu. ft. / 2039 liter Commercial...
Where are the Freon nodules for a True GDM-72 cooler?
SEALED SYSTEM REPLACING COMPRESSOR ON COMMERCIAL FREEZER
Aug 08, 2013 | True 72 cu. ft. / 2039 liter Commercial...
True gdm 72 goes below 20 degrees
Usually a blocked condenser fooling the thermostat into running overtime. Possibly thermostat fault but less likely
Apr 14, 2012 | True 72 cu. ft. / 2039 liter Commercial...
True GDM-72f freezer Fans don't start
Thermo fuse has failed on the core plate, tells the freezer its cold enough to start blowing air, you can bypass it but not recommended. hope that helps, Russ
Jun 11, 2011 | True 72 cu. ft. / 2039 liter Commercial...
My true cooler freezer in side fans dont turn on i run it for 15 min. the make is gdm-72f
first place to look is in the evap where the defrost/ fan delay is located. It is usually attached to the "U" tube on the evap and senses the temp. It prevents circulating warm are after a defrost. It could be bad and keeping the fans from running. Start there and let me know if I can be of further help
Jan 27, 2011 | True 72 cu. ft. / 2039 liter Commercial...
My fans in freezer stop working. fans on condenser and compressor not running. compressor is cool. i changed relay but not working i am not getting ground on the inside
I would check for a bad neutral in the system. Look at the recepticle first. It may be just that simple.
Let me know and we can go further.
Sep 07, 2010 | True 72 cu. ft. / 2039 liter Commercial...
To cold its freezing drinks
You need a cold control. (easy to change)
Its where you turn it colder or warmer.
Go here
www.marcone.com
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 04, 2010 | True 72 cu. ft. / 2039 liter Commercial...
Light removal
get a screw driver and loose the light holder and replace it a new one bought .
May 03, 2010 | True 23 cu. ft. / 651 liter Commercial...
I like the wire diagram from 3 door freezer swich to lights inside
http://www.truemfg.com/index_en.aspx?language_id=1&event_id=401
Go to "Support" and then do the "Ask the True service Dept." They will need your model and serial numbers and they will send it to you.
Jan 11, 2010 | True 72 cu. ft. / 2039 liter Commercial...
True 72 cu. ft. / 2039 liter Commercial Freezer GDM-72F Logo
289 people viewed this question
Top True Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Freezer Expert? Answer questions, earn points and help others
