My freecom 20gb portable hard drive does not power up anymore when i connect it to my computer. i have tried several pc's but to no avail
  • 55 Answers
This PC should take DDR SDRAM
It is quoted as being a socket 478 motherboard and should be compatible with a faster pentium 4 processor unfortunately the new dual core and quad core processors use a socket 778.
Hope that helps
Posted on May 02, 2008
  • Edward Stewart
    Edward Stewart May 02, 2008
    Sorry I posted this to another problem not sure why it showed up here, can a moderator please remove this post
I have a Maxtor 20GB Hard Disk which when connected to a computer the BIOS is able to read it but the problem is the HD only shows ZERO GB(its empty).Can this problem be fixed in order to make it show 20GB...
Computer sees the drive. That is important. I'm assuming this uses a standard IDE cable and the drive isn't physically damaged. Make sure it is the only drive connected and it is the Master. Try flipping the cable if you have checked that the connection has a snug fit. Put the connector that you had the hard drive originally on and place it on the motherboard and the connection that the motherboard had insert it in the hard drive.Or better yet try a new cable. IDE cables have a tendency to fail. You could also try some recovery software. Maxtor is now part of Seagate so you can try here:
If you absolutely have to get data off this drive and you are desperate, then you could try the freezer trick. Put a dry towel and hard drive in the freezer for an hour or 2. Take the hard drive out and wrap it with the cold dry towel. That is to try and minimize any condensation build up. Plug in the hard drive and see if it works. This could potentially kill the hard drive but I have recovered data using this method before. If this works for you do not depend on this drive anymore. Good luck.
Feb 11, 2014 | Compaq Evo D500 PC Desktop
Used drive once, now computer doesn't see it
try restarting computer with drive plugged into usb but no power on drive
once computer is all on, then power on the hard drive
May 24, 2012 | Freecom Xs External Usb Hard Drive 1tb
My external HD will not read on my computer anymore. It spins and lights up as if loading, but does not connect.
Most likely the interface from the external case has failed. Take out the actual hard disk from the case and put it in a desktop - if the disk is still good it will appear in My Computer. If it's not there then the disk is dead, time for a new one.
Jun 14, 2011 | Toshiba My Portable Peripherals 20GB USB...
Data Missing from 250GB Freecom HardDrive.
May be that is hidden..Go to the control pannel look for folder options and then in the view tab check the box show all files and then click ok.
connect it again see if are able to see your files again. if not then there are data recovery tools available on the internet.
But i think the first method will solve your problem
Jul 28, 2010 | Freecom (24358) 160 GB Network Hard Drive
Unable to connect to my computer
I would try it on another PC to see if it is the drive or your PC that is the problem.
Jan 04, 2010 | Freecom (24358) 160 GB Network Hard Drive
My 250gb hard drive is not working
Assuming this external hard drie is powered via USB, you probably just need the drivers:
Jul 01, 2009 | Freecom (24358) 160 GB Network Hard Drive
Freecom external 80GB drive not detected by Windows
go to the freecom web site and download the drive for that unit after that the computer will see and connect to the unit
Oct 24, 2017 | Electronics - Others
Freecom harddrive beeping
Had the same problem. Just checked with their tech support: regular beeping can mean that there is not enough power going through the unit. I tried another USB port on the back of the computer (ie one connected directly to MB) and it worked fine.
Mar 30, 2009 | Computers & Internet
Freecom external hard drive classic 2.5
Have a look here>
I can't see any Mac drivers for the drive...
I found this page>
You might be able to get some help here...
Jan 03, 2009 | Freecom (24358) 160 GB Network Hard Drive
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
