Question about Raymarine St 4000 Wheel Drive E12093
I have a Raymarine Autohelm ST4000 wheel drive autopilot on my Catalina 27. Last night, it was working fine until I tried to disengage the locking lever to steer manually. The lever felt "different". It didn't snap back as it usually does. The drive unit did not disengage. The head was on "Standby" mode. I tried to work the clutch lever a couple of times but no luck. In an attempt not to strip the gears, I pulled the steering wheel off and used my emergency tiller. I'm trying to figure out how to disassemble the wheel drive to see if I can fix the clutch lever. Please help!
5 Suggested Answers
  • 43 Answers
SOURCE: Display control unit frozen, display just reads standby
The reason is because the housingin is a little bit broken or throw the keypad water came inside yuor Display and after this the oxidation ha destroyed a part of the printid circuit or the switch of the keypad
Posted on Oct 13, 2009
  • 16 Answers
SOURCE: I HAVE A 1997 AUTOHELM ST4000 AUTOPILOT AND THE
GLUE THE SMALL POSTS EXACTLY IN PLACE AS THEY BROKE OFF ,DRILL A HOLE VERTICALLY THROUGH THE POSTS ,SAME SIZE AS HOLE IN THE SS WHASHER, (HOLE OF THE SCREWS)ALL THE WAY THROUGH THE BACKPLATE ,INSTALL A STAILLESS SCREW WITH HEAD ON THE REAR OF THE BACKPLATE AND NUT ON THE WASHER SIDE TRIM TO EXACT LENGHT USE LOCKTITE FOR NUT.
Posted on Apr 21, 2010
  • 38 Answers
SOURCE: Service Manual for Autohelm's st4000 Wheel Drive Autopilot
Yes check at google on the internet
Posted on Jun 21, 2010
  • 16 Answers
SOURCE: Where can I purchase the
Search in e-bay ,there is a supplier
Posted on Jan 02, 2011
St4000 pops into standby
Hi
This is almost always caused by a dirty connection at the standby contact. If you're handy with electronic repairs, take the control apart and clean the circuit board for the contacts with silicone spray (safe for plastics) and a Q-tip and reassemble. Works 99 44/100% of the time.
Hope this helps.
-Steve
Apr 09, 2014 | Raymarine Smartpilot Autopilot St6002 S1g...
Where do I find the parts number for the clutch lever and pin for ST4000 to order from a marine store?
The clutch lever for the black wheel unit st4000 has Autohelm reference N011,see at Westmarine,is sparepart is available
Sep 16, 2010 | Raymarine St 4000 Wheel Drive E12093
My st4000 mkII shuts off from auto mode whhen i engage the clutch lever and the wheel turns for a second. the screen goes blank and just displays "st4000" . voltage is fine and all wires are connected....
CHECK THE POWER SUPPLY WIRING ,If it worked before ,could be corrosion or lose wire connection,or terminal bad crimped,or terminal loose inserted.
If it is new installation ,power wires could be undersized,or battery discharged .
Normally autopilot shuts off from auto and restarts when power supply voltage drops under the reset voltage ,when the wheel turns ,the motor current increase and the power voltage drops when the power supply wires are not OK.
Apr 06, 2010 | Raymarine St 4000 Wheel Drive E12093
Jan 05, 2010 | Raymarine St 4000 Wheel Drive E12093
Hi, If you are looking for Autohelm service manuals you may find them at http://sdmarine.online.fr/Service%20Manuals/Autopilot%20Systems/
Dec 18, 2009 | Raymarine St 4000 Wheel Drive E12093
ST4000 autohelm
The clutch lever shearpin is on the outside through the body of the clutch lever
Jul 06, 2009 | Raymarine St 4000 Wheel Drive E12093
Raymarine St 4000 Wheel Drive E12093 Logo
300 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
merc racing
Level 1 Expert
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
