Question about D-Link (des-3526) Networking Switch
How can i reset switch to factory default without console cable
  • 19 Answers
SOURCE: How to reset the cisco switch to factory default?
When you say you were able to connect to the switch through hyperterm, were you able to login with the enable password? If not, you cannot reset the factory defaults without the enable password. If you do not have this then search on Cisco's site for password recovery for your model switch. If you did login with the enable password, the command to run for CATos is "clear config all". For Cisco IOS, you have the right command with "write erase". When you issue that command, do you get a "Erase of nvram: complete " or an error? Are you issuing the "reload" command after a successful erase? Be sure you answer No when it asks "System configuration has been modified. Save? [yes/no]:" as sometimes this seems misleading and some people think they mean to save the reloaded default. They are really warning you that you are about to loose the old configuration and attempting to prevent you from accidently erasing it. So answer "no". After a successful reload of the IOS you should also clear any VLAN information. To do this, issue "delete flash:vlan.dat" and then do another "reload".
Posted on Aug 29, 2007
ted1430
  • 339 Answers
SOURCE: can't console cisco catalyst 3500
It's possible that the management port is on another VLAN or is not enabled. Your most reliable bet is to try a serial connection to console in.
Alternatively, there is a procedure that will work even if you don't know the password:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2900xl_3500xl/release12.0_5_wc5/swg/swtrbl.html#wp1028958
Posted on Jul 16, 2009
  • 1566 Answers
SOURCE: command line only logs in as operator - how to reset to factory defaults
Hi. There's an online manual available here at fixya.
http://www.fixya.com/support/p314181-allied_telesyn_8024gb_networking_switch/manual-20201/page-3
You might be able to get the answer you are looking for there.
Posted on Jul 22, 2009
Geekman
  • 32281 Answers
SOURCE: ho to reset dlink3226 switch
Have you got a manual for the D-Link switch?
You may find the info in the manual, if you have lost the manual you can download a manual from this WEB site - Use this link :-
http://safemanuals.com/annexe_Reference%20Guide_D-LINK_DES-3226-_E.htm
Posted on Sep 17, 2009
  • 74 Answers
SOURCE: Reset a switch
Please login in Switch usign Default ip
then in last menu they give one option reset switch as factory default setting please click on this.
Posted on May 11, 2010
How to factory default Procurve 224M J3299A using console and/or Reset/Clear
There's a reset button on back. When pressed in a specific pattern the switch is returned to the factory default configuration. Chapter 8 discussed this in the following manual:
ftp://ftp.hp.com/pub/networking/software/59672145.pdf
May 07, 2014 | HP ProCurve 224M (J3299A) Networking...
IBM 2005 16B SAN SWITCH
If I were you I'd try to reset it to factory default and then reconfigure it.
The default ip address is 10.77.77.77
Nov 28, 2013 | IBM (2005B16) Ethernet Switch
How to RESET Motorola AP 6532 Access Point to Factory Default?
This is the reset username Username : reset Password:
MAC address XX XX XX XX 10 20 = IP address of 169.254.16.32 *10 in Hex = 16 in Dec *20 in Hex = 32 in Dec
Apr 29, 2012 | Motorola AP 6532 Access Point
Cannot log into the SMC8024l2 switch via ethernet or console and after resetting to factory defaults still cannot ping the device at the default IP Address or the IP address it was set up on.
Looks to me like they never implemented the serial port. The used unit I just obtained has no signal on the serial console pins and no SMC documentation beyond plugging it in appears to exist. Likewise with TELNET access.
However you can reset the switch to factory defaults with the following procedure from a pop-up window off the login page. It worked for me.
If you have forgotten the administration password you can return the Switch to its factory default state by doing the following:
1) Remove the power cord from the back of the Switch.
2) Remove all cables from the front-panel ports.
3) Connect port 1 to port 2, on the front panel, using a standard network cable.
4) Reconnect the power cord to the rear of the Switch.
5) Wait at least 40 seconds before disconnecting port 1 from port 2.
After completing this procedure, the password will be 'smcadmin' and the network address will be returned to the default; 192.168.2.10/24.
Apr 02, 2011 | SMC EZ Switch SMC-8024L2 24-Port Gigabit
I am unable to access my omnistack 4024c using telnet or through Hyperteminal, how i can reset the switch to its factory settings
  1. You need to connect via a console serial cable with suitable terminal software running.
  2. Power on the switch.
  3. Hit any key when prompted by boot process about 10 seconds after power-up to get to boot/diagnostic menu.
  4. Enter c
  5. Press enter (which accepts the defaults) until line displays: "Boot Flags :0xb"
  6. Enter 0x1000
  7. Press enter until back at the "[Boot]:" prompt
  8. Enter S to save settings (thats a capital S)
  9. Enter @ to boot
The switch should now be back to factory defaults.
Mar 14, 2011 | Alcatel OmniStack 4024C Networking Switch
Need cli entry for factory default reset.. adding old switch from another site to new stack and want it clean on factory defaults
Follow these steps:
  1. Connect to the console port of the switch (9600,8,N,1)
  2. Reboot the switch.
  3. When the first line of the diagnostics tests is displayed, press CTRL-C. The system then displays a menu.
  4. Select option "i" to factory default the switch.
  5. Select option "a" to run the agent code.
Upon boot up, the switch will be in a factory default configuration.
Feb 24, 2011 | Nortel Networks Nortel Ethernet Routing...
I want to reset using RS323 port , i forgot its ip adress
Hi
You can reset the device through RS232 port then please follow the below steps.
You need a laptop with Console port and a console cable for EOC-8610 EXT, You really dont need the IP address if you want to do it via console (RS232) interface.
1. Connect the console cable one end to EOC-8610 EXT RS232 port and other end to Laptop serial port.
2. Open Hyper terminal and select com-port option and then provide the username and password for the device management.
3. Go inside the system menu and select Reset Factory default.
Remember if u set to load the factory default settings, the device will loose its config and will boot up with factory default configuration.
Nov 03, 2010 | EnGenius / EOC-8610 EXT / 54Mbps /...
I tried to eset ps3 and it won't help with ps3
try doing a factory reset but be warned resetting it deletes all data and restores it back to factory default
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format.. You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset
Mar 27, 2009 | Sony Playstation 3 (PS3) Console
Ps2 screen display problem
Try reset to the Default Configuration, Remove the Memory Card and try this:
Press the Power and turn off,
Press the Power and Turn on, without a MC the default has been charge.
- No have a "reset sequence" but I can send to you a sequence to reset rgb without video".
Sequence: when the ps2 sound "ready" press:Down, X, Down, Down, Down, X, Right, X.
After Default Load, in "Browser" put your memory card and delete a System Configuation for the MC, the icon is a PS2, and save a new configuration, Done, if the problem not solve, send me a mail or msn gamba.support@hotmail.com (Mail and MSN)
Dec 17, 2007 | Sony PlayStation 2 (PS2) Console
D-Link (des-3526) Networking Switch Logo
497 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
