Question about Peg Perego Santa Fe Express Ride On Train
A peg perego 6v 4.2A battery came with the second hand peg perego choo choo express train ride on set I bought but after charging it the train does not work (charger light went green so charger is ok).. After taking off the green cover of the top of the 6v battery I can see that one of the two wires has snapped off from the middle terminal/plate (and it looks slightly rusting too) and I do not know how to fix it - maybe it's a simple solder job for someone? but I have neither the equipment nor knowledge. what can I do, can I get a replacement of these leads/cables? I can see plenty of 6v batteries for sale but none come with these leads and I think that these may be all I need to replace as opposed to a whole battery anyway? thanks for your help. granny p
  • wendy p May 22, 2012
    Thank you so much Adam for taking the trouble to reply, I bought them in the end from a store called Classie Chassis in Upminster who I found use the websitehttp://www.pegperego.co.uk/
    best wishes wendy
    Genius:
  • Peg Perego Master
  • 1,508 Answers
I can send you new terminal cables if you still need them
Posted on May 22, 2012
4 Suggested Answers
  • 156 Answers
SOURCE: My son poured water in his peg perego santa fe ride on train
It might have shorted out the motor under the seat.
I would contact the repair help at
http://www.shopjandl.com/
Posted on Jun 23, 2009
SOURCE: thomas train peg perego instructions
have to hold on the button that has arrow untill it moves
Posted on Oct 08, 2010
Ironfist109
  • 3018 Answers
SOURCE: is there a way to
  • Yes you can. You have to disassemble the tractor to expose the motor. When the motor is exposed you will take a couple jumper wires and bypass the pedal switch by going from the positive on the battery to the positive on the motor and the negative on the battery to the negative on the motor. Have someone lift the rear end up just enough to get the wheels off the ground and let them free spin. If when the battery is fully connected to the motor the wheel starts spinning the motor is good. If not then the motor is bad. Make sure to use the actual tractor battery only. Also make sure the battery is fully charged so you get a good diagnose on the motor. If you are unsure if the battery is charged then use a multi meter to check the voltage of the battery and make sure it reads 6volts before going to test the motor.
  • Here are a couple links to help you get to the motor.
http://peg-peregoparts.com/diagram.php?num=IGED1061 http://peg-peregoparts.com/manuals/IGED1061.pdf
Regards, Tony
Posted on May 01, 2011
Our choo choo express train won't start...is it the battery...how can i fix the battery that has charged at least 24 hours
check the battery and the charger with a multimeter and make sure that its putting out at least 6 volts
Nov 07, 2010 | Peg Perego Santa Fe Express Ride On Train
Battery issue with santa fe express train from peg perego?
yep use a multimeter and make sure its showing at least 6 volts
May 05, 2010 | Peg Perego Choo Choo Express Train Set
Peg Perego Santa Fe Express Ride On Train Logo
185 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
