Question about SpeakerCraft MZC-66 Amplifier
Clicking from remote speakers - SpeakerCraft MZC-66 Amplifier
  • Scott Frye
    Scott Frye Aug 19, 2010
    Hi...
    Could you elaborate on that a bit??
    Thanks
Gary's solution worked perfectly for me. Bought the capacitors online, a repair shop installed them for me and the unit is as good as new.
Saved a WHOLE lot of money - Thanks Gary!!!
Posted on Feb 26, 2013
  • 4 Answers
The output amplifiers are TDA8920BTH (datasheet at alldatasheet.com) and there is a 47uf 63v capacitor between pins 14 + 23 and 17 + 20 (the VDDp and VSSp pins) due to its close proximity to the heatsink it dries out over time and causes the the continual clicking from one or both channels, replace it with a new one (I used a low Z 105 degC type 47EXR63) and the continual clicking goes away.
Gary S
Posted on Nov 16, 2012
  • Steve Poehlein Dec 29, 2012
    Gary, I have the same issue. Where did you find the capacitor online? Will this one work:http://www.mcmelectronics.com/product/31...
    New Friend:
  • 30 Answers
  • The Seeker May 12, 2011
    Please see our website for current pricing. Price increase coming soon due to rising costs.
No sound coming out of the speakers
set the speaker as default, whichever you are testing, it will start working, just right click and select.
Dec 15, 2013 | Denon AVR-1513
Where is adjuystment page for audio
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
hope this helps you
Mar 22, 2012 | Logitech Audio Players & Recorders
I cant install my speakers???
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Oct 22, 2010 | Ozaki DT-500 3-Piece Speaker System...
Mitsubishi cs-26201 with "speaker off" - how to turn back on?
After a pulled plug got me Speaker off I was frustrated for weeks and found no solution online until I looked at a site offering original remotes and realizes I was using a VCR's remote for the TV. The Manual was long ago destroyed and is not available online that I can find, but I dug around for the oriignal remote and clicking the Audio button repeatedly brought up the Speaker: Off option and then it was just a press of Adjust to turn it back to On - problem solved.
I don't know if there is a way to do it without the remote, but the only controls on the TV are those on the front and in addition to steps people online suggested I think I must have tried every combination possible of pressing those in sequence or together as well as everything I could think of on the other Mitsubishi remote and the Universal remote I had been using.
Sep 04, 2010 | Mitsubishi CS-26201 TV
Neither my Harmon remote or my Logitech universal
Use the help function on your Logitech remote.
Need more information on specific problem to go much further.
Check for tight speaker connections on back of receiver.
Some units have fault sensing; causing 'drop out' preventing A/V receiver from turning out. Typically this is characterised by a clicking sound after receiving an IR signal.
Using high volume levels can affect speaker connections, especially at the back of the A/V unit connectors and banana speaker wire connections.
Dec 26, 2009 | Harman Kardon AVR 500 Receiver
Right place not working still
1.click Start -> Run … enter:services.msc
2. Click OK, a services window will appear, scroll to windows Audio, double click
3. Windows Audio Properties will appear. Change startup type to “Automatic
4. First click Apply, then click on start to start the service
Hope this solves your issue
Aug 27, 2009 | Ozaki DT-500 3-Piece Speaker System...
Olevia TV Remote doesnt work Sleep Timer
The TV is in 'showroom mode'. To fix: Click: Menu --> Picture --> Mode --> Power up then select: Home. Then click menu until you exit the settings. You will now be able to use the sleep timer.
Mar 10, 2009 | Bose Cinemate Digital Home Theater System...
One more
Does it make any strange noise with no RCA cables plugged into it?
If not, you need to check the shield grounds on your head unit.
Click HERE for the test procedure.
Aug 20, 2008 | MA Audio HK4000D Car Audio Amplifier
SpeakerCraft MZC-66 Amplifier Logo
158 people viewed this question
Top SpeakerCraft Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
James Oliver
Level 1 Expert
Electro Med Services...
Are you a SpeakerCraft Audio Player and Recorder Expert? Answer questions, earn points and help others
