Question about Lexmark X342n All-In-One Laser Printer
What does pc life warning on X342n LCD mean? - Lexmark X342n All-In-One Laser Printer
    Genius:
  • 1,087 Answers
PC life warning on X342n indicates that the photoconductor (pc) unit has nearly reached it's rated life. You can still continue printing but will be at risk for developing print quality issues. It is advisable that pc unit be replaced. Now, when you replace the pc unit you will also need to manually reset the pc page counter as well. Thanks.
Posted on Aug 19, 2010
What does PC life warning mean - message on Dell 2350dn?
it could be that the cartridge is nearing the end of its serviceable life, I assume PC stands for Printer Cartridge. You could try getting it serviced
Feb 12, 2015 | Dell Office Equipment & Supplies
PC life warning
This means that the photoconductor has reached the end of life; on other printers, this is called the drum. It transfers the toner onto the page during printing so that it will fuse to the paper. The replacement is $70 from Lexmark: http://www.lexmark.com/US/en/view/Ink/Toner%20&%20Supplies/X340,-X342-Photoconductor-Kit/catId=cat170003-category&prodId=3599-product . The replacement should last about 30000 pages.
To replace the unit after you get a replacement, open the front cover and pull out the print cartridge assembly by the handle. Put the assembly on a flat surface. Remove the toner cartridge by pressing the button on the assembly and pulling on the handle. Open the new photoconductor kit and snap the toner cartridge into place on it. Then slide the new assembly into the printer. The steps are shown here: http://support.lexmark.com/index?page=answerlink&userlocale=en_US&segment=SUPPORT&locale=en&url=http%3A%2F%2Fsupport.lexmark.com%2Findex%3Fpage%3Dcontent%26id%3DSO4365%26actp%3Dsearch%26viewlocale%3Den_US&productCode=&answerid=16777217&searchid=1397780403561 .
After installing this, you need to reset the photoconductor counter.
With the printer on, open the front cover and press and hold Stop for 5+ seconds. When you see Resetting PC Counter release the Stop button. Close the front cover when prompted to do so.
If this doesn't clear the error, try powering off the printer for 10 seconds. Otherwise, try unplugging the printer for a minute to reset the internal memory. If the unit still doesn't reset the counter, it may need service. Contact Lexmark.
I hope this helps.
Apr 17, 2014 | Lexmark X342n All-In-One Laser Printer
PC life warning on Lexmark e360dn
You need to change the photo conducter... its the 2nd tray that pulls out under the toner cartridge I think its a green handle same as toner
Jul 27, 2012 | Lexmark E360DN LASER PRINTER N Laser...
Pc life warning on Lexmark e360d printer. What does that mean
PC life warning indicates that the photoconductor has nearly reached its expected life rating. You can still continue printing but will be at risk for developing print quality issues. It is advisable that pc unit be replaced. Now, when you replace the pc unit you will also need to manually reset the pc page counter as well. Thank you for choosing Lexmark.
Sep 20, 2010 | Lexmark E360d Laser Printer
My faxes are not printing. They seem to be connecting but they won't print.
Tips and tricks For the LEXMARK X342N
1) Faxes won't print.
Try this first....
Press <MENU> then <*> <#> on the keypad
Press <UP ARROW> and see "UTILITIES RESET SYSTEM"
Press <CHECK MARK>
and see RESET SYSTEM
Press <DOWN ARROW> and see (FAX NVRAM)
Press
<CHECK MARK> should reset the fax memory.
Try this second....
Press <MENU> then <*> <#> on the keypad and see "SERIAL NUMBER"
Press <CHECK MARK>
Press <DOWN ARROW>
<DOWN ARROW> <DOWN ARROW> and see (ERASE FFS)
Press
<CHECK MARK> should reformat the fax memory.
It will reboot. Occasionally says the FAX NVRAM is bad
when performing the boot-up self-test and corrects the problem.
2) PC LIFE WARNING message
After replacing your photo conductor kit you need to reset the "PC LIFE WARNING" message. With the front toner door open press and hold the red <STOP> until you see the "RESETTING PC COUNTER" message
Mar 15, 2010 | Lexmark X342n All-In-One Laser Printer
WHAT IS 84 Replace Photoconductor
The 84 Replace photoconductor message means that the photoconductor has reached the expected life spam. It will be time now to replace it.
Jan 30, 2010 | Lexmark X342n All-In-One Laser Printer
Getting message "PC Life Warning"
That warning most likely refers to the photoconductor. That type of error normally means it would need to be replaced.
Thanks.
Jul 02, 2009 | Lexmark X342n All-In-One Laser Printer
Lexmark x342n
A 902 Service Engine Software error indicates a failure in the engine board software, power off clear print que on pc print driver then power up if problem persisits see this link
http://www.marketpoint.com/article.cfm?id=119
Oct 29, 2007 | Lexmark X342n All-In-One Laser Printer
Lexmark X342n All-In-One Laser Printer Logo
1,377 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
