Question about Fagor Washing Machines
Got a f5 fault on fagor wm602 - Fagor Washing Machines
Fagor dishwasher not completing cycle showing f6
The heater or thermostat is faulty and not allowing the dishwasher to complete cycle as water is not getting hot enough. Try to run a cold or short cycle and see if is completed.
see explanation of fault codes in this manual.
http://www.fagor.co.uk/documents/LFU-65iT.pdf
Sep 21, 2014 | Fagor Dishwashers
Fagor dishwasher showing f6
Please check fault codes on page 70 in this manual.
F6 would mean the water is not getting heated. I am not sure which model you have but if there is only a cold water inlet connection then either heater or thermostat is faulty. If you have both hot and cold water inlet then you may have to check if hot water is getting in at right temperature. Easiest way to confirm is to run dishwasher in cold cycle (short rinse) and see if it goes through. The heater would get used in warm/ hot wash cycles and drying.
Sep 19, 2014 | Fagor Dishwashers
PANASONIC DMR BS850 SHOWING ERROR CODE F5 202 CAN IT BE FIXED
hi,
Fault Code At Remote = F5
Indoor Unit PCB
LED1 = Lit
LED2 = Lit
LED3 = Lit
LED4 = Lit
Outdoor Unit PCB
LED1 = Lit
LED2 =
LED3 =
LED4 =
Measuring Of Fault Code = Signal from RC to ID faulty.
Air Conditioning Fault Codes
Feb 28, 2014 | Heating & Cooling
Need manual for fagor splendid
Here is the manual for the Fagor Splendid Pressure cooker!
http://www.hippressurecooking.com/fagor-splendid-pressure-cooker-manual/
Jan 13, 2013 | Fagor Elite/splendid Helper Handle
User manual for a White Westinghouse WM602 washer
http://www.appliance365.co.uk/userfiles/file/MDA/Laundry/WM603%20&%20WM602%20manual.pdf
Nov 13, 2010 | Washing Machines
Fagor cook top connection
Guy from Fagor said brown & blue go to black & red. White and ground together go to green & yellow. Hope he's right.
Apr 04, 2009 | Fagor 31 in. VFA-78S Electric Cooktop
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Fagor dish washer VFU-05S
What do I do to overcome the fault 'F3' accompanied by beeping ?
Jul 15, 2008 | Fagor LFA-019 SS Stainless Steel...
Fagor Dishwasher FI-48w Replacement Parts
Angelo,
We are the manufacturer; Fagor Commercial, Inc. We have a network of parts distributors for our products. contact us to provide you with the most convenient one for you.
305 779 0170 or 1-866 GO FAGOR
Thanks
Jul 04, 2008 | Fagor Dishwashers
Washing Machines Logo
48 people viewed this question
Top Fagor Washing Machines Experts
Vernon Taylor
ray gallant
Are you a Fagor Washing Machine Expert? Answer questions, earn points and help others
