I am a refrigeration mechanic, i would apreciate it if some one could help me with a delema with a Quarsar space heater , pilot light dropin out i have checked the thermo coupling its ok i would be even greatful for a suimatic drawing if poss if i over looked something apreciate your time
  • 455 Answers
Hello GAVIN Change the the thermocouple anyway if you already did'nt.Check the pilot flame itself it should be stronger than a lighter.It can be turned up/down @ the gas valve.Lastly & very rare I have heard of a sticking gas meter @low pressures in standby mode starving the pilot out.Also when the main burners shut down it should be smooth with out any (snap) blowing it out.
Posted on Aug 19, 2010
Is there a way to adjust the pilot light on my wall space heater. I don't know the model number.
normally pilot lights are on a fixed jet size and cannot be adjusted
call a gas fitter for a diagnosis and fix as the problem may be else where causing the large pilot flame
Oct 12, 2016 | Heating & Cooling
Tip
Vent free heater tune up
An ODS space heater is a nice way to keep warm on the nastiest winter nights. It does not require power either so when the lights go out the ODS space heater keeps on truckin. This vent -free system is used on most fireplaces and space heaters today. A heater/fireplace using the vent-free system sits idle in summer months and dust gets a chance to accumulate in the pilot safety. After lighting the pilot and starting the heater all will be fine for a few minutes then the pilot goes out and heat fades away. The thermocouple for these is a superior grade one that is much costlier to buy than an ordinary t-couple. Lots of folks buy a new thermocouple only to realize that didn't fix the prob. Well I have the solution. I took some photos:
Each year just before the cold season you should at least vacuum the grates for flame unity and blow the cobwebs out the pilot to avoid having problems. Hope this helps someone.
A nice video from Micheal Holigan which explains how it works.
on Dec 19, 2011 | Heating & Cooling
Pilot lights but won't stay on in my older style vulcan space heater. thermo couple was replaced last year.any ideas that i could try thanks
Most common cause of pilot light problems is air movement. If your space heater exhausts gas through the roof, ensure the cap is on and level. If not, outside air movement will blow out the pilot. If you do not have an exhaust gas duct, check that the unit is positioned so that it does not blow air back onto itself from walls, furniture, etc, and ensure no other devices that move air are aimed towards the unit. The unit also needs to be placed away from central ducting, including return vents.
Hope this helps!
Aug 09, 2010 | Vulcan AUW230A Heater
Have a vent free lp wall mounted heater.40 lp tank with regulater. pilot light will light but only the tip of pilot light is flame.there is a space between pilot light and tube where lp comes out. does not...
Too much gas pressure. Are you sure that this is a LP heater and not a Natural gas heater? Is the regulator you have rated under 1/2 pound pressure? Try to throttle down the shutoff on the tank to see if pilot gets better. If so, you have a pressure issue. Gas you adjust the pilot gas valve?
Jan 22, 2010 | Procom 10K BTU, Vent Free, 2 Plaque...
The pilot light will not stay onit is desa propan fire place
HI clean the pilot light might be too small check or replace the thermocouple
Jan 17, 2010 | Desa International Unvented Gas Space...
Pilot light won't light on ventless fireplace
Ventless Gas logs, Vanguard, VS30PR. Propane gas
Pilot light stays lit various times, sometimes for several days then other times for a few minutes. Lights best when temp outside is below freezing. Pilot flame appears to receive too much air. How do you adjust the pilot flame? Is this done using two screws marked A & E? Do you have suggestions?
Thanks,
Ed
Jan 07, 2010 | Desa International Unvented Gas Space...
Pilot won't light
You may have to bleed some more air out of the system.
Your ODS pilot may be clogged with dust or lint and needs to be blown out with air(less than 30 psi).
Your regulator or gas valve may be faulty.
Dec 09, 2009 | Desa International Comfort Glow Infrared...
Have Model CGP30TB Copmfort Glow propane heater. Pilot light won't stay lit. Flames also coming from what seem to be air vents just below flame on pilot light.
sounds like an obstruction in pilot assembly.try using canned compressed air to blow directly into pilot. this technique is successful about 70%. if not,pilot assembly must be removed and cleaned thorougly
Sep 10, 2009 | Desa International Comfort Glow Infrared...
Heating & Cooling Logo
147 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
