Question about Samsung WIS09ABGN (8808993304486) Pre-802.11n Wireless Adapter
My samsung wireless adapter will not connect my samsung LED tv to the internet. when I test the connection everything works except the ip address for the DNS server which it says is not valid. I have checked the DNS server ip address, which is correct and even put this in manually. It still will not connect. It does, however connect my samsung sound bar to the internet without any problems. Please advise
4 Suggested Answers
  • 34 Answers
SOURCE: cannot connect to internet
Make the Ip address similary to the router, example should work.
SUbnet mask will then fill in automaticaly, just leave it
then Default gateway will be the routers IP.
the dns server would be the ip of your internet provider. I would leave it blank at first, see if it will work then. If not, then ask your service provider for it. If they give u a number, then you will have to go into the router properties, and change the dns and stuff like that in there aswell.
good luck
Posted on Dec 25, 2008
  • 88 Answers
SOURCE: Hi guys, I have an
Right now the security on your LED is set to 64 bit wep - now you need to change security on LED to wpa/wpa2 and that will solve your problem .
Advisable :if you can make sure what kind of security is been enabled on your wireless router (wep 128 bit or wpa/wpa2 ) that will be more helpful for you to select the security on led - give a try with wpa/wpa2 .
Posted on Oct 04, 2010
  • 5807 Answers
SOURCE: samsung wireless lan adapter can't find network
Samsung server is your router ,
Use the DLNA and check .
Use a computer to log In to the router and check if the device is listed
( the TV with USB)
Posted on Sep 25, 2012
Reset the IP address on my Samsung wireless LED TV?
Please provide the model number for more assistance. There are just too many versions out on the market.
Dec 02, 2014 | Samsung Televison & Video
My wireless connection to my Sharp smart tv works - but the wired connection does not. Should the two IP addresses be the same or different for wired and wireless?
For the same hardware on your system the IP address needs to be the same, no matter how its connecting to the router. Also check your available IP addres range on the router. The IP address must be within the routers IP address range or it will not see it.
Aug 10, 2014 | Sharp Aquos Televison & Video
Cannot wireless connect Samsung DVD Blue Ray to Net Flix
set the ip address to be detected automatically in the tv network settings.
What you need to know is the encryption key used on the Wi Fi
If you do not know it it might be on the case of the Wi Fi access point device.
Otherwise you will need to log into the router by typing the router's ip address into an internet browser on the working computer.
Nov 01, 2017 | Samsung Televison & Video
I have a samsung LCD TV Model LA40C650L1R newly purchased a week ago . it went with an offer of free wifi wireless LAN adapter.I cant seem to connect it in the internet. I did all the configurations the...
Please test the WiFi with a laptop or netbook, if Internet works with it, maybe you have bad settings into the wireless adapter, you could use the PC wireless connection parameters (SSID, IP address, subnet mask, gateway, DNS) as reference with the data obtained with the TV wireless adapter, the only difference must be the IP address, the rest must be the same since they're using the same network.
Mar 15, 2011 | Samsung Televison & Video
Everything works well on my wireless linksys e2000 router my itouch, my computer except my samsung wireless lan adapter wis09abgn cant seem to connect to the internet on my Tv i plugged it in the usb slot...
IT looks like it might not be accepting the type of security on the router..try changing the security typa it might work.
(P.S. YOu might need to re-connect all the wireless computers to the new network once you change the security.)
Hope this helped.
Feb 13, 2011 | Computers & Internet
I am trying to hook up a Samsung WIS09ABGN LinkStick Wireless USB 2.0 Adapter to a Samsung BD-C5500 Blu-ray DVD player. In going through the setup process after I set up the router connection which...
To resolve issues with the Internet Gateway connecting to the MyQ server
1. Determine if you can connect to the Internet using your computer. If you cannot connect, proceed to step 2.
2. Reset the router. Unplug the router for 30 seconds and plug back in. It can take a few minutes to reconnect to the internet. If you still cannot connect to the internet, contact your Internet Service Provider before proceeding.
3. Move the Internet Gateway ethernet cable to another port on the router. Put it in one of the ports on either side of the current position on router. Make sure that the Internet Gateway is plugged into a LAN port, normally numbered 1-4. Proceed to step 4 if none of the ports work.
4. If you are using a modem and a router, disconnect from the router and plug the Internet Gateway directly into a LAN port in the modem to bypass the router. Note: This will turn off the internet to the rest of your home network temporarily. If this works:
5. If step 4 doesn't work, power cycle your home's internet modem, it may need to be restarted to provide a new IP address to your network.
6. Perform a Soft Reset on the Internet Gateway. This renews the IP address with the router. The LED lights will blink like a normal power up. To perform a soft reset:
1. With a safety pin or paper clip, press and hold reset button while the Internet Gateway is still plugged in.
Note: The reset button is located on the side of the Internet Gateway in a recessed hole.
2. Hold the button in until you see a yellow LED light blink and release.7. Perform a hard reset on the gateway. This deletes all the devices and renews the IP address with the router.
1. Unplug the AC adapter from the gateway.
2. With a safety pin or paper clip, press and hold the reset button on the side of the gateway.
3. Plug the AC adapter back in while continuing to hold down the reset button until the yellow LED light blinks.
Dec 08, 2017 | Samsung WIS09ABGN (8808993304486)...
How do i setup my internet on the samsung nc10? i am wirelessly connected but when i go into networks it says te local connection is not connected because the network cable is unplugged but i dont have a...
Local area connection is meant for wired LAN connection. you can connect the internet using a straight clable wire.
on how to make a straight cable,below is the link
But as you have said you can connect using wireless,then in wireless adapter setting,
Assigned your IP address Plus Subnet Mask address.
Set your wireless access point IP address as your Default Gateway Address.
In Primary DNS address as provided by your Internet service provider.specify secondary address too,it available.
If DHCP server is available then you don't need to configure anything.
If you are trying to browse internet through a proxy server than Go to internet Explorer,Click "Tools", Select "Internet options ", Select Connection, Tick Proxy server and specify the IP address of your proxy server and the port.
you will be able to browse Internet now.
Rate this answer.
Dec 27, 2009 | Samsung NC10-14ROBL Notebook
Samsung CLP-510 not printing
hi ,
i went through the website and i found that Samsung CLP-510 is not compatible with wrt160n.
Oct 23, 2008 | Computers & Internet
Dynex G usb network adapter
sir i think ur lan card has been not working properly...
Mar 09, 2008 | Intel Anypoint Network Adapter
Samsung WIS09ABGN (8808993304486) Pre-802.11n Wireless Adapter Logo
192 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
