Printhead check nozzles on my Canon Lp-17 and the head is realy damaged, but can print still. Every time when I print I get this message and printer doesn't want to print. How Can I ignore this print with damaged head? THank you, zoran
  • 1,219 Answers
can you please tell me the exact message wich IPF reports.
i.e. "change left printhead"
You can also contact me on emma.servis@gmail.com, for troubleshooting manual.
Regards!
Posted on Aug 19, 2010
Error 03800 500-280 C
Many nozzle on printhead did not inject .
You must clean your head or replace it. Or comes up in service mode
and check your nozzle check .For cleaning head you can take it out of printer and clean with head solvent, if not clears maybe u must replace print head.
Also check the canon ipf710 service manual from below link, it will save you money and time
Canon ipf710 service manual
http://goo.gl/e0h9OC
thanks
Nov 17, 2014 | Canon imagePROGRAF IPF710 Printer
PRINT HEAD ERROR
You can first try reseting your printer by unplugging all the cords for 30min. and then plug it back.
Please do a deep cleaning, align the print head, and also do a nozzle check.If you still have the problem then replace the print head.
Apr 03, 2008 | Canon PIXMA MP830 All-In-One InkJet...
I need a new print head
Check if the service station proper covers the black nozzles when the printhead is parked. Sometimes the mechanics change its position and the printhead dries out.
Try to unclog the nozzles with very hot water. Sometimes it helps. The new printhead is very expensive and you may want to buy a new printer instead.
Remove the printhed, put it in a bowl with the nozzles down and fill with boiled water until the nozzles are covered. Wait 15 min and dry the electric contacts with a dry napkin. Good luck!
Jun 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Not printing yellow or blue despite full cartridges & clean head?
alcohol burnout print nozzles, you have ruined your printer head. you need to replace-it.
Feb 13, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Problem with Printhead
I have the same printer with the same exact problem. Even the same color being affected. Unfortunatly no solution. It sounds like we have to replace the very expensive printhead.
Jan 13, 2010 | Canon imagePROGRAF iPF610 - large-format -...
Canon S900 Now prints murky and dull
Printing is Blurred/Colors are Wrong
? If a specific color does not print, check whether the corresponding ink tank is
empty. Replace if necessary.
? Print the nozzle check pattern to ensure that ink is ejected correctly.
If the nozzle check pattern does not print correctly, clean the printhead.
? Printing the Nozzle Check Pattern
? Printhead Cleaning
If the problem is not resolved after cleaning the printhead several times, the printhead
may be worn out. Contact the Customer Care Center.
Note ? Always ensure that you dispose of the protective cap and protective tape
from a printhead.
? Ensure that you are printing on the correct side of the media.
You can only print on one side of certain media.
Nov 16, 2009 | Canon S900 InkJet Printer
Canon smartbase MP360 "put in cartridge" does this means buy a new in this case printerhead. The printer was printing fine before this error message came up and printing stopped. Amazing another clean...
Print heads cans wear out. Put in cartridge sound more like a low ink level. Check ink levels and reseat the ink cartridges. Still no? I'd suggest having the print nozzles checked by a repair center or Canon.
Oct 05, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Canon MP730 not printing. Printhead cleaning doesn't help.
You may need new print heads. They are around $50. Or, you could do this: Take the print head out of the printer, and run warm water from the tap (not high pressure), over the ports for about 5 minutes. Ink will drop out of the jets. Dont touch the electrical contact end of this head. This may clean the head enough so it works again. If not you need a new print head.
Apr 25, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Canon iPF 8000: Hardware Error 03800500-2F2F and 03800500-2F30
it's a multiple problem....there is no enough ink for the head managment sensor to understand the good function of the print head.
Print a nozzle check to see what is going on
Then come back for more information
Feb 10, 2009 | Canon Office Equipment & Supplies
Printer doesn't pring
Try cleaning the printheads
Performing the printhead cleaning procedure
  1. Power on your printer, press and hold the "RESUME" button until the printer light flashes once.Note: You can also clean the printhead by clicking the Cleaning button in the Maintenance tab of the printer properties dialog box in Windows; or clicking Cleaning pull-down menu in the Printer Utilities dialog box on a Macintosh computer. Choosing this option will allow you to select all nozzles, black or just the colour nozzles.
  2. Pressing Resume on the printer will clean all nozzles. When the printhead cleaning begins, the POWER light starts flashing. This will continue for about 30 seconds. Wait for the light to stop flashing before you resume normal operation.3. Perform the Nozzle Check Pattern test again
  3. If the results are satisfactory, resume normal printing
  4. If the results are not satisfactory, you may need to execute a printhead deep cleaning.
Deep printhead cleaning from the operation panel
  1. To deep clean the printhead from the operation panel
  2. Press the Maintenance button.
  3. Press the Right Arrow button three times.
  4. Press the Print button. Printhead deep cleaning starts.
  5. When deep head cleaning ends, press the Maintenance button to exit.
Deep printhead cleaning in Windows
  1. Make sure the printer is turned on.
  2. Click Start, then Settings, then Printers.
    Note:Windows XP users: Click Start, select Control Panel, then Printers and Other Hardware, then Printers and Faxes.
  3. Right-click the Canon S820D Bubble Jet printer icon, then select Properties.
  4. Click the Maintenance tab, then click the Cleaning or Deep Cleaning button. The Maintenance tab and procedures may vary for Windows 2000 and Windows XP. Follow the instructions when prompted for those operating systems.
  5. For each message displayed, click OK. The BJ Status Monitor opens automatically and closes when the printhead cleaning is done. The POWER lamp on the printer flashes green during the cleaning process.
May 18, 2008 | Canon BubbleJet i560 InkJet Printer
361 people viewed this question
jasbo
jasbo
