Question about NEC ND-2500A DVD±RW Burner
: "WRITER ERROR [ILLEGAL REQUEST (LOGICAL BLOCK ADDRESS OUT OF RANGE)]" Burn4free worked before I rewrote the computer(win XP) .what do I need to install?
    President:
  • 2,571 Answers
You could try and uninstall the drive in device manager, then let the pc reinstall the drive.
Try some other software, i use IMGBURN and CDBurnerXP.
Get back if this does not fix your problem
Posted on Aug 19, 2010
Testimonial: "thank you . I uninstalled the device manager burn4free didn't work but the imgburn did!!! Now I can stop wasting dvds."
Seagate expansion 2tb
Cause:
This problem is caused by an issue with the Windows 7 Backup and Restore utility when using drives with 4K Logical sector sizes, which are found on WD 2.5 TB and larger external drives. This is different from an "Advanced Format" (AFD) drive which use 4K physical sector sizes. AFD drives should not cause this problem.
Solution:
It is still possible to use a 2.5 TB drive or larger with Windows 7 Backup and Restore, as long as you don't need to use the drive with Windows XP. Using the WD Quick Formatter tool, select the Factory Default configuration to reformat the drive.
Warning: This tool will erase all data on your drive, so take the necessary precautions.
After formatting the drive to Factory Default mode, the drive will be usable in Windows Vista and Windows 7. However, the drive will not be recognized in Windows XP. This is the only way to get Windows 7 Backup and Restore to work correctly.
Jan 30, 2014 | Computers & Internet
Aspire One netbook BSoD
Those error codes don't really mean very much to the general consumer, but blue screens of deaths are caused by bad RAM memory in your computer, not viruses. I'm going to take a guess that your computer is either several years old and/or it constantly get quite warm? Heat can shorten the life of computer components by quite a bit. You may need to get one of your RAM cards replaced to solve this issue.
There's a free program called Memtest86 that you can run to determine if this is the case. It will scan all your memory and look for bad sectors. You can download it here: http://www.memtest86.com/ and burn it to a CD. What it does is create a bootable CD that will execute the program as the computer turns on to scan all the memory. There are full instructions on their website. The process can take an hour or two depending on how much memory your computer has, and if it turns up any bad sectors then you know what your problem is.
A computer can run with bad sectors in the memory, but it makes it unstable that it will keep bluescreening, so if you have bad sectors in your memory it might be better just to replace the RAM. Luckily, this isn't too expensive. For instance, if your computer has 4GB of memory, it probably has 2 2GB RAM cards installed. You can get a 2GB replacement notebook memory for, I'd say $30 or $40. Installing RAM is very simple, and if you're willing to install it yourself, it won't cost you more than that.
Dec 06, 2012 | Acer Aspire One Netbook 8.9" Notebook
Whenever i try to install win 7 with xp in dual boot configuration,i receive a error at xp logon page saying "a problem is preventing windows from accurately checking the license of this...
To fix that problem,
Open your computer in safe mode,
open a command promt
Register the following DLL s
it should be in the %system root% \ system32 folder
just type the following statements one by one and see you got success information popup
regsvr32 licwmi.dll
regsvr32 regwizc.dll
regsvr32 licdll.dll
regsvr32 jscript.dll
regsvr32 vbscript.dll
regsvr32 msxml.dll
regsvr32 shdocvw.dll
regsvr32 softpub.dll
regsvr32 wintrust.dll
regsvr32 initpki.dll
regsvr32 dssenh.dll
regsvr32 rsaenh.dll
regsvr32 gpkcsp.dll
regsvr32 sccbase.dll
regsvr32 slbcsp.dll
regsvr32 cryptdlg.dll
then try to restart,
Aug 11, 2011 | Computers & Internet
I have a desktop which is connect to my router and works perfectly fine. I am running win xp pro. I also have a laptop which i connect wirelessly via the router. The problem is when directly connect to...
The ip address conflict is likely caused by a manual IP address that is entered into the printer that is overlapping with an automatic address that your router is giving out. Either switch your printer to DHCP so it gets an automatic address, or reserve the address in the router's DHCP list or pick a manual address to assign that is outside of the range of the DHCP server. Most router will start at address XXX.XXX.XXX.100 so if you pick an address between 20 and 40 then you should not have any more issues with conflicts.
May 11, 2011 | Xerox Phaser 7750DN Laser Printer
DVD Writer Problem, DVDs burn but do not burn
i would unistall every burning program you have and install burn4free from burn4free.com its free and it burns everything. I think maybe you have your software set to make an image file rather than burn a disk
Mar 14, 2010 | Acer Aspire 4530-5889 Notebook PC
Have a Netgear FS108. Have 4 xerox printers with ethernet access. How do I install them on one pc with this switch? When I connected one of them the add printer wizard couldn't find the printer and I...
A router between your ISP and the switch will assign addresses to your PC, the printers, whatever you connect.
Or, if just the one computer needs access to the Internet and the printers, you can install/configure a second Ethernet port in the PC, connect it and the printers to the switch, and give them all static IPs in a private address space (e.g., 192.168.1.0/24)
Oct 31, 2009 | NetGear FS608 Networking Switch
DVD Writer Troublesome.
i would begin by making sure that you have updated drivers installed for that drive. Even though it's new out of the box, there could be issues with the factory drivers that have been corrected. Please follow the instructions here for XP or Vista
You can check for new Sony drivers here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 01, 2009 | Computers & Internet
RTHDCPL.EXE err
Error Message after Installing Security Updates 925902 and 928843 This afternoon (April 3rd, 2007) my Automatic Updates alerted me about a couple updates I needed to install, so I did. Upon rebooting the computer though I was confronted with the following error message
"RTHDCPL.EXE - Illegal System DLL Relocation"
"The system DLL user32.dll was relocated in memory. The Application will not run properly. The relocation occurred because the DLL C:\WINDOWS\SYSTEM32\HHCTRL.OCX occupied an address range reserved for Windows system DLLs. The vendor supplying the DLL should be contacted for a new DLL."
Cause of Error Message
Turns out this error occurs when the Realtek HD Audio Control Panel by Realtek Semiconductor Corporation is installed. This is my built-in sound card on my computer.
The HHCTRL.OCX file that is included in the Security update 928843 and the User32.dll files that is included in Security Update 925902 have conflicting base addresses. When Windows loaded the HHCTRL.OCX file before it loads the User32.DLL file, the problem occurs.
The error occurs when the following third party programs or applications are installed on a computer with Windows XP Service Pack 2 installed.
ElsterFormular 2006/2007
TUGZip
CD-Tag
Microsoft now has released a patch to correct the problems, you can go to the following link to download and install the patch for the patch :-)
http://support.microsoft.com/kb/935448
Oct 18, 2008 | Computers & Internet
Old DOS program in WIN XP
hello sir
i have f500 compaq laptop i have no winxp driver in sound driver plz help me
thanks
Aug 31, 2008 | Microsoft Windows XP Professional With...
Adding additional computer problem
Yes, the xp machine connects to the net. DHCP is not enabled. The ipconfig/all command brings up the correct static ip address, subnet mask, and default gateway. But it does also say under the ip configuration that ip routing is not enabled. I did have the 2000 machine connected when I first set up the router yesterday, but I booted up my laptop to try to set up a wireless connection, and then I had to reinstall the entire router set-up.
Jan 12, 2008 | Linksys Wireless-G WRT54G Router
NEC ND-2500A DVD±RW Burner Logo
602 people viewed this question
Top NEC Computers & Internet Experts
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
