Water collection tray - Heating & Cooling
    Problem Solver:
  • 7 Answers
What is your question???
Posted on Aug 19, 2010
Trane xr90 leaking water from behind inducer
You have a condensing furnace, clean out the condensate drain line.
Nov 30, 2013 | Aprilaire Heating & Cooling
SMELL COMING FROM LARDER FRIDGE,FOUND THE PROBLEM AT BACK WHITE TRAY ON TOP OF MOTOR A BUILD UP OF SLIME , FINDING A PROBLEM TO CLEAN TRAY,
This is the defrost water that collects on the collection tray - white tray on top of motor. Normally over a period of time the water evaporates off but if there is collection of dirt it can smell. So you need to PULL out the tray - use a screw driver to release the lock and the tray will come out which can be cleaned using a water jet and detergent.
Apr 06, 2011 | Refrigerators
Delonghi DH400p dehumidifier running but not collecting any water ? Humidity is 68 set to 50???
Hey, I had the same thing with mine.
First, try cleaning out your filter if you haven't already. It gets angry if it can't get any air.
If not, I don't know how brave you are, but I ripped mine apart to fix the problem. I took off the panel with the filter (5 screws) and you can see a collection tray with another little collection gutter under that. Both of mine were filled with junk, mostly dust that had gotten wet to make this awesome disgusting sludge. If you can get at it from there, try to clean the sludge out of the collection tray and the little gutter. I ended up taking my whole unit apart so I can get the collection tray out (dumb design, you have to take apart the whole dang casing to get at two screws that hold the collection tray in).
May 14, 2010 | DeLonghi Dehumidifiers
How much water to put in the water entering tray
dehumidifier's remove moisture from the air,so you really don't want water anywhere close, the tray in a dehumidifier is to collect water removed from the air. a humidifier is easy, you put a pan of water close to a heat source or moving air
Jan 31, 2010 | Dehumidifiers
It collects some water but it also spits water out
The dehumidifier has a non-removable tray under the coils (they look like radiators) that collects and drains the water away. If the tray or drain gets clogged with dirt or slime the water doesn't drain away well. Some water is picked up by the fan and is blown out the vent. Take the covers off the machine and give everything a good cleaning. If you get water on any electrical parts, let the machine dry thoroughly before plugging in.
Nov 12, 2009 | Frigidaire FDL50R1 Dehumidifier
Dehumidifier leaks
Either there is a hole/leak in the tray, or the drain line is clogged. You are giong to have to access the tray to determine this: standing water is plugged line and no water is busted pan. This will determine your avenue of approach.....
Aug 31, 2009 | Ebac Neptune Dehumidifier
Water leaking into fridge
Unless you have a lot of confidence in your ability as a handy person and plumber, it may be better to leave this to a pro. Here's the story.
When the freezer automatically defrosts, water from the melted ice collects into a tray behind the back panel of the freezer. There is a drain in this tray, and the drain empties into a pvc tube that carries the water down into an evaporation tray that extends from front to back on the bottom right side of the refrigerator. A fan blows air over the evaporation tray to dry the water in the tray before the next defrost cycle.
Over time, the drain tube gets partly clogged with gunk, the water in the upper collection tray doesn't drain completely into the lower tray, and when the defrost cycle ends, the water still in that upper tray freezes. After a few defrost cycles, enough ice forms in the collection tray so it blocks the drain completely, and this plug won't melt during the defrost cycle. Now every time there is a defrost cycle, water collects, overflows, and drips down through the air channel at the back of the fridge into the refrigerator section.
The fix is to clear the drain tube leading from the upper collection tray to the lower evaporation tray. Here's how (if you have the know-how to tackle the job):
First, move the fridge away from the wall, unplug it, and remove the fiberboard panel that runs across the the bottom back. From the front of the fridge pull out the trim grill that runs across the bottom. Locate the evaporator tray on the right, but don't remove it yet.
Empty the freezer, and be sure to safely store the removed items in another freezer, or an insulated cooler, if you can complete the job in an hour or two. Be careful with ice cream and such, which cannolt be allowd to defrost, even partially.
Remove the ice maker if you have one, remove the screws holding down the bottom panel of the freezer, remove it, and remove the screws holding the back panel, and remove it.
Leave the refrigerator door closed, to keep the food in it from spoiling. If this job is going to take you more than an hour or two, move the food in the fridge to another fridge.
Now you need to let the freezer defrost (a hair dryer will make it go faster, but don't let it get wet), and sponge out all the water, There will remain an ice plug in the drain at the bottom of the collection tray at the back. Use hot water to dissolve the ice plug, use a drinking straw inserted into the drain (don't let it drop!) to be sure the ice plug is melted.
You still have to clear the plastic drain tube of collected gunk. This is like snaking out a drain pipe. I found that 8 feet of 1/8 pvc tubing works well. Before you clear the drain tube, remove the lower evporation tray. There is a finger hole at the front. Use it to lift the tray up and forward (be carelful, it may contain water).
Put the pvc "snake" down into the drain in the upper collection tray, and gently work it down through the drain tube. You are done when the snake emerges from the bottom of the drain tube, at the back bottom of the fridge, above where the evaporator tray sits. . Snake up from the bottom, and then back down again from the top, to be sure the drain tube really is clear. Replace the evaporator tray, and slowly pour 2 cups of water into the collection tray at the top, and confirm that it drains quickly and completely into the lower tray.
Empty the lower tray, replace it, and reverse all the disassembly steps.
This is not a permanent fix, because the drain tube could clog again, but should be good for a few years before you have to repeat this operation. At least now you know the cause and the fix, and can deal more effectively with a repair tech, even if you don't tackle the job yourself.
Jun 20, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Water collecting in the bottom tray and, at time, pouring out
The condensate drain is probably plugged w/dirt. You have to blow out the drain w/ some pressure to clear the drain.
Apr 15, 2009 | Heating & Cooling
Water leaks under veg bins.. Cannot tell where it is coming from. Accumulates slowly
This refrigerator look like mine (Picture).
Mine did the same thing. If it is the same then this is what I did.
Look under the there is a collection tray.
This tray collect the water.
At the bottom of the refrigerator (Inside where the water collect) is a cap.
The cap has cap would have holes or a slot that allow the little water to fall to the collection tray.
Mine has slots and was block up.
clean it out and that should do it.
The water should be able to fall to the tray at the bottom.
I do hope this help you.
Mar 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water in the Unit
Most of the AC Unit lately are not made to drain. So when you have water collecting inside the unit, the condenser and the evaporator is suppose to help dissolve the water.
When water is collecting inside the appliance like that, it is either because the ac unit is not installed correctly or you live in a high humid area.
Aug 06, 2008 | Frigidaire FAC124 wall/Window Air...
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
