Question about Garden
Hi I have a HP Laser Jet Printer 3005 and i get some times this error 49.4c02 power then on
  • 1,218 Answers
Printer error 49.4c02 may occur due to corrupted print queue. Just clear the queue and restart the printer and the error may be fixed. This would seem to work for most cases. If none of them are corrupted, check to see if any of them are in an uncommon size. Larger printings tend to result in this error as well. Check if it's the cause by clearing the queue then printing normal-sized documents instead. The error may also be caused due to complicated fonts as they are harder to read, especially if they're in color or written in a pdf format. If this is the cause of the error you can either stop printing such documents and update the drivers or firmware. The drivers may contain bugs which cause the printers to act this way, so updating them will solve the problem. http://www.fixya.com/support/t6031482-hp_laser
Posted on Sep 18, 2010
Hp laser jet 3005 printer clearing paper path error
I would pull out the paper tray, and clean the underside roller. First try to clean it without moving the clips. Use a cotton cloth or lint free cloth and alcohol. Get as much paper dust off as you can. This might help you out.
Jul 30, 2012 | HP LaserJet 4350 Printer
Scaner error 52 in my laser jet printer printer model :-hp laser jet 3052 all in one printer
52 Scanner Error
The all-in-one has experienced an internal hardware error.
1. Turn off the power by using the power switch, and then wait at least 30 seconds.
2. If a surge protector is being used, remove it. Plug the all-in-one directly into the wall socket.
3. Check the FFC connection between the formatter and the scanner.
NOTE Do not bend or fold the FFCs during the removal or reinstallation process.
4. Try connecting the product to a different power source or surge protector.
5. Turn on the power and wait for the all-in one to initialize.
6. If the error persists, replace the laser scanner assembly.
Jul 12, 2011 | HP LaserJet 3052 All-In-One Printer
Printer hp laserjet 3005 make noise when printing
If it is growling and or grinding, check my tip (click on tip to go to it)
You may qualify for a free repair from HP.
Apr 27, 2011 | HP Laser Jet Printer P3005dn
Hp 3005 kod 52.00
Laser/scanner error. A scanner motor error occurred. It probably isn't spinning.
A printer tech is needed to replace the laser/scanner assembly.
Apr 21, 2011 | HP LaserJet P3005 Printer
13.05.00 jam inside in 3005 laser jet printer
Seems like there's a jam in the paper dispenser. Check the back openings, and the paper tray to see that no paper is stuck there. Also, there is a chance that the paper tray is overloaded. Try loading it with less papers.
Feb 16, 2011 | HP LaserJet P3005 Printer
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
MY HP LASERJET 3005 DISPLAY ERROR 49.2F9D
Its already discussed in one of the forums for Hp.
check :-
https://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=1158526
Thanks
Jun 04, 2009 | HP LaserJet P3005 Printer
49.FF95 SERVICE ERROR
Please look on: http://www.fixyourownprinter.com/
There are much solutions of this problem listed ...
For example this (it see good):
http://www.fixyourownprinter.com/forums/printer/46157#1
HP Laser Jet 4250n by TLYNN (3/20/07 12:22 PM) reply + / -
Anybody know the error code "49. FF95 Service Error"
We can't get around this...
Firmware Error 49 by Stephen (edited 3/20/07 12:29 PM) reply + / -
It could be a bad job.
First disconnect it from your network and any PC it might be attached to.
Power cycle it, then if it goes to ready status try the built in test pages, do they work?
If the printer will go to ready status and you have a parallel cable with the proper connector, then you can try upgrading the firmware from a PC, you can also try to upgrade the firmware over the network.
More reading:
http://www.fixyourownprinter.com/search/forums?f=&q=49+4250
Re: HP Laser Jet 4250n by TLYNN (3/20/07 12:59 PM) reply + / -
Still won't go back to ready status. Turns on to the same error code....
Cold Reset HP Laser Jet 4250n by Stephen (3/20/07 1:03 PM) reply + / -
Try a cold reset, it will reset the JetDirect settings, but it's the next step.
Cold Reset:
Power off printer, wait about 5 seconds, then power it on, when asterisks start appearing on the display press and hold the check mark until all 3 lights come on solid, then use arrow keys to find cold reset and push check mark to perform the reset.
Re: HP Laser Jet 4250n by TLYNN (3/20/07 1:06 PM) reply + / -
Thank You so much for your help... but that didn't work either. Same error code showed up.
Re: HP Laser Jet 4250n by Stephen (edited 3/20/07 2:27 PM) reply + / -
Then you probably need to replace the formatter.
Do you have another printer you can swap parts with?
There is a slim chance the memory DIMM is bad, you can try it with the DIMM removed, if there is more than one DIMM you can try installing just one and then the other.
A 49 error indicates that the formatter could not understand or execute an instruction within a file or cannot interface with an accessory, DIMM, or EIO device. Troubleshooting 49 errors is done through process of elimination. First determine if the printer functions in a stand-alone mode then test communications to the printer.
These errors can be divided up into two categories; the associated troubleshooting depends on the circumstance the 49 errors are occurring.
A 49 error is always followed by Hexadecimal numbers, for instance, 49.00FF. The Hex code is a memory address. Most Hex codes are not documented.
Re: HP Laser Jet 4250n by dmzcompute (3/20/07 2:26 PM) reply + / -
I do not see anywhere where the printer has been disconected from everything. If you have not done so already disconnect every cable from the printer with the exception of the power cable and turn the printer back on and see if you get the error and if not report back here for further instructions.
Re: HP Laser Jet 4250n by Stephen (3/20/07 3:28 PM) reply + / -
You might also try disabling the embedded JetDirect.
To disable the embedded LAN port
Turn the printer power off.
Power on the printer and watch for the memory count to begin.
Hold down the SELECT (Checkmark) button, when you see the memory count begin.
Continue holding down the SELECT (Checkmark) button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds.
After the message SELECT LANGUAGE appears on the display, press the UP ARROW button or the DOWN ARROW button until EMBEDDED LAN DISABLED appears on the display
Press the SELECT (Checkmark) button. The printer then continues its power-on sequence with the embedded LAN disabled.
If this works the JetDirect built into the formatter is bad, you can either replace the formatter, or buy an JetDirect to install in an EIO slot.
Re: HP Laser Jet 4250n by Trev Pearson (3/20/07 10:08 PM) reply + / -
The only other thing to try, before spending money, is to get the network administrator to clear the print queue for that particular printer and then turn it on.
The theory being that a 'corrupt' print job is still in the system and as soon as the printer is turned on, that 'corruption' floods the network card with garbage which promptly goes 49.
If the printer comes 'ready', great. Then do a firmware upgrade. If not, then you will have to spend money on a new formatter.
Regards
Trev
Re: HP Laser Jet 4250n by roadrunner178 (6/21/07 2:09 AM) reply + / -
hi.
With a cold reset ,my problem solved.
try this as a first solution.
thank you
Re: HP Laser Jet 4250n by Anonymous (7/31/07 1:20 AM) reply + / -
THANK YOU WERY MUCH
FROM TURKEY
ZAFER
Jan 02, 2009 | HP LaserJet 2420dn Printer
Garden Logo
75 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
