Question about Life Fitness 9500HR Next Generation Remanufactured Treadmill
Immobilized - Life Fitness 9500HR Next Generation Remanufactured Treadmill
  • fitwrks Aug 20, 2010
    whats it doing and not doing
  • 79 Answers
Immobilized feature is activated.
Press and hold the SPEED Down
Arrow Key and press the Pause Key to
toggle ON/OFF.
Posted on Sep 15, 2010
    New Friend:
After I resetted it but the treadmill is not moving?? even though the display is working and spped stop at 6.2km/hr! what should I do next?
Posted on Jun 03, 2013
How I can pair ecu with immobiliger of safire
Immobilizer III ECU Swapping - Ross-Tech Wiki
wiki.ross-tech.com/wiki/index.php/Immobilizer_III_ECU_Swapping
1.1 Engine Control Unit (ECU); 1.2 Immobilizer (integrated in Instrument Cluster); 1.3Immobilizer (integrated in separate Immo Box); 1.4 Immobilizer (integrated ...
How to program honda ecu immobilizer key after ecu swap ...
? 1:47
https://www.youtube.com/watch?v=u0NB_zT_oMU
May 11, 2014 - Uploaded by vehix411
This video will show you how to program honda civic ecu keyimmobilizer after ecu swap it's common to ...
Immobilizer bypass HACK!! Real not fake - YouTube
Jan 08, 2016 | Cars & Trucks
Immobiliser bypass
The motor can be replaced without touching the immobilizer system. There may be no problem with the immobilizer system as it only turns off power to the fuel pump or ignition spark.
better yet just re-seed the immobilizer ECM with the dealer
Apr 17, 2014 | 2006 Toyota Hilux 2.0
I have problems with my dodge grand caravan 2005 won,t start an show this code p0513
P0513 - Incorrect Immobilizer Code
Possible causes- Open or short immobilizer circuit
- Poor electrical connection for immobilizer circuit components
- Faulty immobilizer control unit
- Faulty immobilizer key
- Faulty immobilizer key antenna
Read more: http://engine-codes.com/p0513.html#ixzz24sUqroQI
Aug 28, 2012 | 2005 Dodge Caravan
Anti theft immobilizer
For immobilizer reset procedure go through the link mentioned below.
Click the link:---
Immobilizer override and bypass? http://whatisbyme.blogspot.in/2012/05/2012-toyota-hilux-sr5-immobilizer.html
How to bypass immobiliser? http://technoanswers.blogspot.com/2012/01/how-to-bypass-immobiliser-on-rover-200.html
This will help.
Thanks.
Jun 05, 2012 | 2001 Toyota Sienna
2005 subaru outback immobilizer reset? Alarm was set with door being unlocked with key, immobilizer shut off all power. How can this be reset?
This could be a few things. If the security system was enabled and you just unlocked the door with a key and not using the remote, then all you have to do is put the key in the ignition and turn on/off three times. That's it!
Some cars have immobilizer keys. The immobilizer prevents unauthorized keys from starting the car (yours may or may not have it, depending on the exact Outback model).
Look here for the different styles of immobilizer keys:
http://www.cars101.com/subaru/keyless.html#immobilizer keys
Nov 09, 2011 | 2005 Subaru Outback
Vw beetle does not start. seems like its some kind of anti theft protection. the car/key icon lights up, it turns over for a second , then off. this is the first time this has happened, but we bought it...
First of all you need to programm all ignition keys using suitable diagnostic equipment (VAS, VAG-Com) connected to the data link connector of the car.
You have an electronic immobilizer key recognition problem. Now your key chip is not recognized by the transponder antenna fitted on the ignition switch barrel.
  • Everytime when you had a new key you must programm all available ignition car keys before trying to start the engine with this new key !!!
  • $(".author").find("img").brokenImage({ replacement: "http://c.fixya.net/fixya20/images/icons/expert-not-found.jpg" }); function ToggleComments(obj,id) { $("#solutionComments_" + id).find(".thComment").show(); $(obj).hide(); }
    This warning lamp indicates that the engine is locked by the immobilizer system, and the engine start sequence must be repeat again.
    From year 1995 in Audi-VW (VAG) cars is used engine immobilizer. The VAG group immobilizer system consists of an immobilizer ECU which controls the recognition of keys and the Engine Management ECU system. Immobilizer is activated when the ignition key is removed and, together with the engine control unit, largely prevents unauthorized starting of the engine. The system uses a transmitter and receiver unit in the ignition key (transponder). Whenever an attempt is made to start the engine, it transmits a new code to the car's electronics. The immobilizing is only cancelled and car motor electronic receives permission to start engine if the key sends a right authorization code.
    Oct 15, 2011 | 1999 Volkswagen Beetle
    Immobilizer active reset on 2006 volkswagon passat
    Oct 12, 2011 | 2006 Volkswagen Passat
    Immobilizer
    If there is a blinking car icon with an "X" over it. This icon means the Immobilizer has been activated and hence won't allow the car to start. It could be due to a bad SCU, Start Control Unit. The SCU is actually the ignition switch on these cars.
    Most of the time it's triggered by the anti-theft system..You can try this trick i learned that the dealers won't tell you...try locking and unlocking of the doors five times with the remote to reset the immobilizer and see if this helps.
    Good luck..i hope this helps...please take a minute to rate me a fixya.
    May 11, 2009 | 2000 Volvo S40
    I dont know where to hook up immobileizer bypass wire
    An immobilizer bypass is an electrical circuit which allows current to flow to whatever component is starved of current to keep the engine from running (usually the coil). The immobilizer opens the circuit to the coil, the immobilizer bypass closes the circuit to the coil.
    If you didn't install an immobilizer circuit, then you don't need the bypass. There are probably instructions you missed in the manual explaining the immobilizer circuit.
    Apr 30, 2009 | Honda Civic Cars & Trucks
    Life Fitness 9500HR Next Generation Remanufactured Treadmill Logo
    539 people viewed this question
    Top Life Fitness Exercise & Fitness Experts
    Howard
    Howard
    Glenn Mayer
    Glenn Mayer
    Craig Butler
    Craig Butler
    Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
