Question about Sanyo PLV-Z3 Multimedia Projector
I see constant vertical lines in the picture, and before some times I had blue color without sensing the video input , so I had to remove the video and re connect , then it worked out , but now picture includes th vertical lines.
  • 4 more comments
  • nissim_lamba Aug 19, 2010
    I have tried to change the cables and the source ,it isn't the problem ,
    why constant vertical lines appear on the picture ??????
    My projector is sanyo plvz3 not nec.??
    if it is electronic board ,which one it is ? can I purchase it by my self and replace it ( i am an electronic man) .Thanks
    Thanks jayantjha355 , is that driver boards , I can purchase by my self , any idea where ? I am an electronic man can i replace it by my self or it needs an adjustment :my projector is Sanyo PLVZ3.
    Thanks
  • nissim_lamba Aug 22, 2010
    Acctually I didn't understant if the vertical blue lines within the picture could be lamp which is nean that replacing the lamp will solved the problem problem or it is bad contacts or lcd ,no cases like my case in your history ??
  • nissim_lamba Sep 08, 2010
    Hi , I was in vacation ,
    I think the problem is not on the video , it is only in the background ,
    so when no video , on the blue background there are hard blue vertical lines , may I send you a snap shoot of that ?
    President:
  • 1,566 Answers
Hello there,
Are you trying to connect this from a computer source? Does it happen on all types of sources like the Audio/Video output etc? If the behavior is from the computer source or the VGA cable, and you have replaced the cable already, it could be an issue with the VGA port on your computer already. If that is the case, it would be best if you consult a technician and have him personally look into the problem. This is to avoid causing more problems to your computer or the projector.
If it happens on all sources, I would highly recommend you to have a technician check the projector.
Posted on Aug 22, 2010
  • 857 Answers
Try cleaning the filter on the bottom of the unit, might be overheating issue BUT The problem U R facing is a combination of both the lcds and driver boards in which case neither need to be truely replaced.. They use a specific voltage to transmit data to the lcds.. Each lcd is different and the driver board is programmed by the factory for the EE v.com setting. Unfortunatly with nec, they do not offer a service mode to go in and adjust the ee settings to correct the electrical convergance. So the only way to fix the problem is to replace the lcd with a newer one who wasnt worn out from long term heat
Posted on Aug 19, 2010
  • 10,594 Answers
It sounds problem with main board or light engine that has 3 lcds, filters, lenses inside and defective lcds can cause distorted image.
Remove lcds connecting flexibe ribbon wires from main board carefully, clean their contacts and insert them in connectors and check.
Do you have service manual of PLV-Z3 ? It has all necessary schematics, disassemble procedure, light engine details, part list info etc
Following image shows boards location in projector
Let me know if you have additional question.
  • Shahid Electronics
    Shahid Electronics Aug 22, 2010
    I didn't get answer of my questions, how can I help you then?
  • Sanyo Master
  • 19,396 Answers
Hi Nissim.
Please check the connection cable. Test using a different cable.
Turn off both projector and source. Disconnect projector power cable for five minutes.
Turn back on the source first, with cable already attached, and the projector with source connected.
If that does not work, try the opposite, turn off everything and turn back on projector first with cable attached.
If no luck, test a different kind of connection, use the input/source button on projector to switch between connection settings.
If source is a laptop, ensure that you do not need to press Fn+F button combination to switch to external source.
    is this the solution to the constant vertical lines showing on the picture ?? ?
  • Ginko
    Ginko Aug 19, 2010
    Re:"
    is this the solution to the constant vertical lines showing on the picture ?? ?"
    Troubleshooting starts from signal. Signal problem can cause vertical lines, I cannot see your display.
    Unfortunately it looks like you did not even try starting to troubleshoot the problem. If you are sure there is a failure just make your point and ask for more help (vertical lines as failure is main board or input board)
    I expected a deccent answer back, instead I got a refusal accompained by useless maybe sarchastic comment in about 5 seconds.
    I regret wasting my free time in answering similar staff. Ensure that it is not signal problem, then proceed with other posters help.
    After refusal the question will be passed to a different expert.
    Goodbye and good luck.
    Ginko.
Samsung LED TV, Model# UN55B6000VFXZA turns on to black screen then displays large blocks of colored vertical lines?
check every flat cable main boerd to t-con t-con to display if dont help display is a problem
Feb 24, 2017 | Samsung Televison & Video
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
My LTV-32w6 westinghouse powers on & has sound but displays black screen with very faint colored vertical lines. It shows like this for about 1min before it goes into standby mode & the blue power...
Depends on what is causing it...
Vertical bands of faint black are generally caused by filtering capacitors and can be found in the power supply or the 5 volt supply or even the Video processing circuit...it is not an easy task to identify the source of Video hum bars.....we also call them Jailbars.
Another problem seen is faint black lines caused by the TV set being in 4:3 mode all the time....right at the edge of where the picture ends and the black pillars begin, we see a faint black line that never goes away and is normally seen with a full screen....
That is actually image retention, but it's caused by the crystals that create the picture becoming polarized or ionized over a very long period of time....and it's not easy to DE-Polarize them !
But there are some theories out on how to do that....
Certain people suggest running the TV overnight with an ALL-WHITE picture and some suggest an ALL BLACK PICTURE...and some suggest alternating between both !!
Now, a black picture is easy to make, you just deactivate the Video Mute (blue screen) and set it to an unused Video INPUT overnight....
About the only way to make a white screen is to use the USB port for pictures and take a very bright outdoor shot of a piece of white paper that hopefully is out of focus too....That would create an all-white picture that you can plug into your TV set overnight....
Now if you decide to try this, deactivate any displays on your TV set...all you do is press the display button until the Video and/or USB input numbers disappear....
Next day , set it back to normal TV and see if it's gone or if it's REDUCED....try it again if needed, or try the exact opposite if you see NO RESULTS....
Sep 20, 2012 | Westinghouse Televison & Video
AOC PD4264 Screen fault
Extremely blue color temperature that cannot be adjusted; some false-contouring artifacts in dark scenes; no picture-in-picture; limited connectivity with just one DVI and no HDMI inputs.
If use as a TV monitor:
The number of colors you can display is controlled by the video card installed in your computer. In order to display more than 16 colors, the proper video card driver must be installed. Contact your computer or video card manufacturer to obtain the latest driver from them.
If you are watching standard-definition or Cable/RF signal on an HDTV, the picture may appear to be of poor quality. This is because the TV is designed for viewing HD or at least digital content. Your best bet would be to upgrade to a Dish Network HD receiver and connect it to the TV with an HDMI cable. Similarly inputting analog signal to TV from your DVD player will not appear to be of great quality. A newer DVD player would most likely have component video output which would look much better. To get even greater quality, an upconverting DVD player connected with an HDMI cable would look the best. You could also upgrade to a Blu-ray disc player, which is capable of playing HD Blu-ray discs as well as DVD's at higher resolution. A less expensive choice could also be a streaming media box. Hierarchy of inputs for good picture quality:
Apr 13, 2012 | AOC A42HD84 42 in. Plasma HDTV
Cannot reset vertical convergance
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Colored vertical lines
It is a tossup between a bad LCD panel and the logic board. The only way to tell for sure is to change out the logic board or have it tested on another unit. Checkout www.lcdrepair.us for instruction videos on that unit as well as parts.
http://www.lcdrepair.us/Installation.html
Jun 19, 2008 | Dell 2000FP 20.1" LCD Monitor
Blue horizontal and vertical lines
We have many problems with loose or poorly seated cables and connectors on these units. Pull the back and reseat all the internal cables, especially the LVDS cable to the LCD control bd. If this does not correct the problem the main cause is a bad LCD control bd. or possible a defective main bd.
Jan 12, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Mitsubishi WD-62825 vertical lines, blue snow, picture jumping
sounds like dm module
http://hdtvoice.com/voice/showthread.php?t=32186
Dec 28, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Vertical red/green lines
This set has a bad digital board.and or signal board
The company is in California and is a china inport.
Digital and signal board could cost $130+
Nov 03, 2007 | Soyo Dymond DYLT032A Television
A 12" high by 4" wide block of colored vertical lines in middle of screen
I have the exact same problem as sal1965. Does anyone know which circuit board may have a problem?
Aug 16, 2006 | Samsung PPM50H2 50 in. Plasma Television
Sanyo PLV-Z3 Multimedia Projector Logo
132 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
