Question about Blaupunkt Woodstock DAB 52 CD Player
Unit gets stack and does not allow you to change channels or tracks or from cd to radio. It takes a very long time to come back to normal sometimes days. Any help would appreciated, thank you
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Blaupunkt Master
  • 2,226 Answers
You may have a bad switch.
Posted on Aug 19, 2010
The radio won't work. It is currently on cd mode. When I put the radio on it starts playing the same cd that has been in for a week now. All the buttons dont work. I can't change the mode.
Sound as if there is an internal problem with the system. Will the CD eject when commanded? If not, try to remove it manually with a pair of tweezers or something of the sort to see if it will come back on line. You can also disconnect the battery for a few minutes to erase the units memory ( you may require a code if it has a theft feature ) to see if it will start working again. If nothing gets better, suspect an internal unit issue
Nov 29, 2015 | 2006 Ford Focus
How do I get the picture?
The TV is usually set to Channel 3 or Channel 4. You may have a switch on the back of the VHS recorder near which is marked Ch3 Ch4.
Once you correct this, try the following procedure.
Some VHS have a tracking button that allows the user to tune to the best signal. The tracking can also be done from the remote controller.
Usually that tracking function is used as follows.
While movie is playing on the VHS unit and signal gets fuzzy, press the channel key repeatedly (for example >> to increase the channel number). f after awhile pressing the same channel change button does not find a better picture, you should press the other channel change button (to decrease the channel number <<) to see if the picture improves.
If that does not work, IT DOES NOT MEAN that you tv/vcr combo unit is defective. It could just be the movie. The tape is magnetic and it might have been accidentally demagnetized.
If picture is better with another movie/tape, your unit is definitely OK.
May 20, 2010 | Memorex MVT2135 13 in. TV/VCR Combo
PRESET STATION CHANGER WILL NOT ALLOW CHANGING ON 2001 ASTRA
Seems to have cleared up, just cleaned the pins on the back of the removable unit
Nov 24, 2009 | Car Audio & Video
How do you set the time and alarm on the RP5600A
Setting Clock
1. Press SET repeatedly until a clock icon
shows on the display.
2. Press REV or FWD to set the clock
time. The time decrements or
increments will follow by a faster rate
when you press and hold the buttons.
AM or PM icon will also show beside
the time.
3. Press SET when finished.
Setting Wake Time
This unit allows two wake times to be set.
1. Press SET repeatedly on the top of the
unit until you see WAKE 1 or WAKE 2
flashes on the display.
2. Press REV or FWD to set the respective
wake time. The time decrements or
3. Press SET repeatedly until you see no
WAKE 1, WAKE 2 or icon the
display.
Selecting Wake Source
You may be woken up by radio, CD or alarm.
1. If your desired wake source is radio or
CD:
• Wake by radio - select an AM or FM
station (see directions on “Radio”).
• Wake by CD - insert a CD in the CD
compartment. If you want to be
woken up by a specific track on the
CD, press and hold wake up - cd
track
on the top of the unit and at the
same time press REV or FWD to select
a desired track.
2. Set a wake time (see above direction).
3. Press WK-1 or WK-2 repeatedly at the
front of the unit to select a waking
mode. Corresponding icon lights on
the front of the unit.
- Wake 1 by alarm
- Wake 1 by radio
- Wake 1 by CD
In case of Wake 2, “2” shows at the
centre of the icons.
Sep 30, 2009 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
No radio text display on vauxhall corsa
model cdr 2005 radio/cd player works fine except there is no display above where the radio station2_bing.gif/cd track number is supposed to be displayed. I have time and temperature as normal
May 07, 2009 | Car Audio & Video
My Dodge RAM Car CD will play OK, but won't eject.
If this a CD with a paper label, sometimes they will peel up on the edge and not allow the CD to eject or in same cases the CD is slightly warped.
One thing you might try is this..... Get a flash light and try and look into the CD slot when the radio is trying to eject. There is a black felt type material that you can lift up slightly and if you can see the disc edge trying to come out it may look like it is very slightly too high and getting caught. You can take a business card and try and slide it above the CD edge from the side and this will get the edge of the CD to come down and eject. This has worked many times for me anyway.
Mar 23, 2009 | 2005 Dodge Ram 1500
Car Radio, Casette Player and CD Player not working
Hello Lei,
It sounds like the antenna has came loose from the back of the radio and the wiring harness is loose.
Make sure you have a good ground going to the radio, or this will cause a short and make the radio do strange things, the fact you sometimes get a signal tells me the radio is in working condition.
Sep 22, 2008 | 1997 Ford Expedition
No display
Did you install the unit with the correct wiring harness, or cut-and-splice the wires from the factory line to the stereo lines? This could be a problem.
Aug 27, 2008 | Car Audio & Video
Steering mounted CD/Radio controls acting up
good chance radio has a fault' try a freinds one.if you still have the same problem change the steering wheel control pannel
Jul 18, 2008 | 2002 Honda Accord
Kenwood RXD25 CD player intermitent??
Hi jenoss
Sounds like the unit has either a failing load belt to the cd drawer mechanism,not allowing the transport to fully load the cd. Give the unit a gentle tap just after the drawer closes and see if it resolves the problem.
OR a faulty spindle motor, you will have to take the lid off and after pressing play, give the disc a gentle "kickstart". If it then begins to run, then the motor is the problem.
If you find it is neither of these, get back to me here and I we shall go further
regards
Graeme
Mar 16, 2008 | Audio Players & Recorders
Blaupunkt Woodstock DAB 52 CD Player Logo
67 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
