Ted harvested 50 3/8 of mangoes and his brother mario harvested 38 5/6 kilos.how much more did ted ted harvest than his brother?how much did they harvest together?
  • 12,061 Answers
11 11/25 11 55/100 or roughly 11 3/6
or (50 3/8) - (38 5/6) = 11.5416667
Posted on Aug 19, 2010
What methods can be helpful in rain water harvesting?
Rainwater harvesting is the best process for saving water. Some of the methods are summarized below:
1.Water butts.
2.Domestic rainwater harvesting.
3.Pump feed harvesting.
4 Commercial harvesting.
There are many more easy and cheap methods for which you may look on regenwassertonne.
Mar 17, 2017 | Refrigerators
What are the benefits of using rain water harvesting?
There are many benefits of rainwater harvesting, and some of them are listed below:
1. The rainwater can be used for irrigation.
2.Reduces water bills.
3. After filtering can be used for drinking.
4. Increases ground water level.
5. Easy maintenance.
There are lot more advantages for which you can refer Regenwassertonne.
Mar 17, 2017 | The Kitchen Appliances - Others
Scotsman cm3 does not harvest
your sump level control sensor is not reading the water level drop to go in harvest.you can do a self check test or replace the sensor(little blk box) could be wire harness. check to makeure your water value is leaking through
Feb 11, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Sce170a-1a wont harvest
This machine has a cube size control. Which tells the machine when to go into a harvest. there is a harvest switch did you try to force it into a harvest and if you did, did it harvest. depending on ambient temperature from start of freeze cycle to harvest it should be making ice every 15 to 18 minuets and then go into a harvest. so start the ice machine and time it , run it for 18 minuets and force into a harvest. after ice drops check the ice bridge thickness. Bridge thickness should be about 3/16'' the ice dimple must not be DEEPER than 1/16". If this is good then we need to look at what is not working to harvest ice. The cube size control is a reverse - acting thermostat that controls the start of the timed freeze cycle. It must be set properly to prove the correct size cube bridge. When it is closed, an indicator light on the control board will be on. If you force it into a harvest and it harvest the ice with no problems and the ice is at the right thickness then replace the cube size control, but if dose not harvest the ice and you see the ice is at a good thickness and not to thick because if it is to thick it will freeze to every thing and will not drop. SYMPTOM. Unit freezes, but will not try to harvest. POSSIBLE CAUSE: Cube size control will not close; to check: Unplug water pump, switch unit OFF and then ON, in about 2 minutes the timed freeze light on the control board should be ON. PROBABLE FIX: If timed freeze light does not go ON, replace cube size control. SYMPTOM #2: Timed freeze light glows, but after 4 minutes unit dose not power hot gas nor purge valves Then replace control board.
Dec 15, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scottman cu3030 max harvest-retrying, flashing code #2
The machine will try to harvest 3 times before it shuts the machine down. Is the ice thick enough to open the curtain door? if the curtain dose not open the magnet switch then the machine dose not know it has harvested the ice and will keep trying to harvest. Is the ice coming off the evaporator plate during harvest or is it hung on the plate? if hanging on the plate then system needs to be cleaned. is the harvest assist plunger working?
Oct 30, 2013 | Scotsman Refrigerators
Scotsman ice maker cme 506 makes ice and turns off and blinks refrigeration
First check to make sure condenser fan is running during freeze cycle. Now check to make sure condenser coil is clean. Her is all the specks on the machine.
1. Ice production ( 500 at 70/50
2. BTUs per hour ( 7000)
3. Maximum times in Minutes. ( 50 freeze, 14 harvest.
4. Refrigerant charge ( R-404A ) ( A-D series: AC 32oz, WC 20 oz. E series AC 23 oz, WC 14 oz, F series AC 23 oz, WC 13 oz
5. Suction pressure ( PSIG ) 35-37 - end of freeze, 120-125-Peak in harvest.
6. Discharge pressure ( PSIG ) 240-260- 5 min in freeze.
165-175- minimum in harvest.
7. Metering device.( TXV plus distributor, E series and higher have two TXVs. superheat 3 to 15 deg F.
8. Average comp.amps. 10-11 during freeze, 11-12 during harvest.
9. Batch Weight. 6.5-7 lb
10. cycle time, 23 minutes @ 90/70. 19 minutes @ 70/50
Feb 24, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman cme 506ae-1a harvest to soon. Where is the adjustment timer the harvest is also too long?
The water float rod in front of the unit serves as the fill stop as well as the harvest initiate. Difficult to remove to clean really well but not impossible. Harvest time is handled by the controller. First two or three harvests are long as the controller times out the harvests based on the blinking light of the bin full indication. After that is should get shorter.
Jul 04, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Whirlpool ice maker ,no harvest?
Hi, The optics almost never go in those unit's, the problem is in the icemaker module itself. If you can jump it thru a fill and then no advancing thru to harvest afterward ( provided your freezer is below freezing ) it's the module. You can either replace just the head/module or the entire icemaker. For the difference of only about $50 I always replace the complete assembly. The most common one being about $150 complete, # 2198597 and this should be the one for your fridge since you mentioned the optic component's. Hope that help's. Thanks for choosing "fixya" for your fridge inquiry. Please take a moment and rate this solution if indeed it solves your problem. Thanks again and good luck. Macmarkus :)
Mar 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
