This may be too late in posting. There are some great air fresheners that are a quick, inexpensive fix. The brand you want to look for is called Auto Expressions, Ventfresh airfresheners. Pep boys in my area, colorado springs, has a better choice than
autozone. They run about 3-4$ for a package of four. AE vent clips look better
in the vents than Refresh and other brands which have big round white head that
clash with the black.
Auto Expressions Vent Sticks: Wildberries Auto Air Freshener - 4 pk. ' Product Details ' Pep Boys
This is a link for what they look like.
SOURCE: 2006 acura mdx. battery completely dead now I
You need to get the serial number off the sticker attached to the radio. It will require pulling apart your dash. Call an Acura dealership with that serial number and they should be able to provide you the code. Or you can take it directly to the dealer but you will be charged labor.
SOURCE: acura mdx 2005
30000 miles.the owners manual will tell you exactly.most honda are 48000 km,exception is the cvt type transmission which there is no service done.
SOURCE: 2006 Acura MDX bluetooth stopped
Bluetooths have batteries, Rechargeable. If it won't hold a charge replace the batt.
SOURCE: Need to reset the code my Acura MDX navigation
check the side of the glove box. my TL has it on the outside side panel as you look from the driver side. my honda prelude had the code there as well. hope this helps
SOURCE: Pontiac vibe flap motor replacement
Replacing the flap motor can be relatively difficult to replace because it requires removing the dash in most cases. It is not overly expensive and may not be worth the effort to do it yourself.
