Question about Kenmore Elite 45986 Front Load Washer
I continue to get an F code during a wash cycle. What is wrong?
    President:
  • 1,382 Answers
The reason for "F" flash is that if your machine doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely if it's frozen or stiff replace it. If the pump belt is broken or looks quite worn, replace it but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Thank you !!
Posted on Aug 19, 2010
Can you tell me what e6 on the display means as the machine wont work when this shows
Not sure of the make/model, but with Samsung washing machines that usually means 2 things. If you get it when entering the spin mode and the system stops and displays the code, the water heater is heating too quickly. Press the power button once to clear the code and finish the cycle before repair.
If you get the E6 during the spin cycle that can mean a problem with the main controller board.
You can keep resetting to get past that code but if you continue to get it during a spin cycle or part of the laundry where hot water isn't used, then usually that controller board is bad.
Good luck.
Apr 08, 2015 | Washing Machines
During washing cycle E2 alert alarm
What is the make and model number of your unit?
Feb 18, 2013 | Washing Machines
My LG comes up with the error code PF
PF - Power Failure - PF error code indicates a power failure during the washer's cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks
Oct 23, 2011 | LG WM-2277HW Front Load Washer
Fill Fault appears during wash cycle.
Is the filter in the hose where it screws onto the tap clean?, if this is okay then most likely the valve.
Apr 19, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Washer does not finish cycle..it stops at spin and it displays a 'dc' code...what is this
The Service Manual for reference. Sears Parts Direct for reference.
dC code from the Service Manual = Distribute Clothes: The load is unbalanced, preventing high speed spin. Redistribute clothes.
Your wash tub is banging around during the spin cycle correct?
You can redistribute the wash basket load until the cows come home the issue will only continue to get worse. Maybe start throwing uC error codes to the console display for continuous unbalance error code.
Your FAV6800A or FAV9800A has a Clutch malfunction. It can be corrected if you are handy see this DIY fix Clutch Fix. post.
If you decide to dive in I will help you through the fix………Rich
Feb 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Code pf came up and the washer does nothing
PF Power failure "PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost.
OR
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Apr 01, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer stops washing and gives a p5 trouble code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 12, 2009 | Kenmore Elite 45986 Front Load Washer
Washer stops with an F1 Code during rinse cycles.
Well I have the same problem the only way I have found that my washer works is that on the soiler level make sure you put that on the heavy. And that should work I know its a pain but thats what I do and my washer washs with out stopping
Dec 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore oasis he beeping during cycle
"HC" indicates hot and cold hoses switched.
Aug 23, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
