My b4ran7d n7ew Dyn7ex keyb4oard has automatic pop ups of n7umb4ers. How can7 I fix this ASAP. I am ab4le to b4ackspace to erase n7umb4ers. I can7n7ot type an7y copy.
  • 19,396 Answers
Re:"My b4ran7d n7ew Dyn7ex keyb4oard has automatic pop ups of n7umb4ers. How can7 I fix this ASAP. I am ab4le to b4ackspace to erase n7umb4ers. I can7n7ot type an7y copy."
I can see from typing that the problem is NOT the Num Lock. The numbers are not replacing the letter UIOJKLM, but are being inserted after letters like B and N.
That means that when you press certain letters the keyboard is sending two codes. That means that the keyboard is faulty.
Contact dynex and have the keyboard replaced.
Let me know if this satisfies your question. In case please do not forget to accept.
Regards.
Posted on Aug 19, 2010
Tip
How to Erase a Burned CD
CD-RW stands for CD re-writeable. This type of disc can be written on or "burned" multiple times. However, in order to burn music or data onto a CD-RW that already has something on it, you must first erase the current contents of the disc. No special software is needed to do this, as you can do it with the Windows Media Player program, which already comes installed on all computers with the Windows operating system. Regular CD-R discs cannot be erased or reused--the discs must be labeled as CD-RW.
Instructions
Step 1.
Click on the "Start" menu button in the lower left-hand corner of the screen. Select "Windows Media Player" from the pop-up menu.
Step 2.
Select the "Library" tab in the main Windows Media Player screen.
Step 3.
Insert the CD-RW that you want to erase in the CD-ROM drive. Close the "AutoPlay" window if it appears.
Step 4.
Right-click the CD-ROM drive in the "Navigation" pane on the left side of Windows Media Player. Select "Erase disc" from the drop-down menu. This will automatically erase the contents of the disc.
on Jul 17, 2010 | Computers & Internet
Ad popping up all over page
Your PC is infected. You should get it cleaned up asap!
Jan 16, 2014 | Computers & Internet
2005 Nissan Altima code P0420
code p0420 refers to the cat converter system-bank 1--efficiency below threshold===causes --wiring--cat converter -- HO2S 2. I would replace the heated oxygen sensor number 2. There is no real life on cat converters as they are extremely fragile and run at extreme temperatures which means that if you hit a icy puddle of water / snow and the cat is hot they are prone to cracking and disintergrating internally and blocking up the exhaust pipe.. In your case I would be looking at the sensor. Use the correct tool so that the wires are no damaged.
Jan 05, 2014 | 2012 Nissan Altima 2.5 Sedan 2.5L 4-cyl....
Email is down when is it going to be fixed please
Me too, It sucks I need to email something asap!
Jul 31, 2012 | Yahoo Mail
100,000 miles check list
Ok, this actual model will hold up quite well under moderate driving conditions but, you will need ot do a few things here. check the list below for further information.
CHECK LIST(100,000mi)
1 Spark Plugs-replace asap
2. Automatic Trans Fluid Filter-replace asap
3. Automatic Trans Fluid-change asap
4. Ignition Cable(s)- Inspect for damage and, change if damage is visible.
5. Inspect the engine oil and filter.
6. Finally, get a basic lube job.
Jun 25, 2009 | 2005 GMC Sierra
Things i dont know in using motorola v3i
for erasing messages you should click the button that is in the middle, at the top of all buttons of the phone.. then you will see the options you can select, between them, there is "erase", you can choose to erase them all, or just the message you were reading..
don't know is themes can be dowloaded.
for the pictures it is quite the same, if you go to options, using the same button, then you can choose something like "use different memory device" and if you choose that, you can choose between the intern memory of the phone and the memory card you are using..
I hope this was a bit helpful.. Can you rate this solution please??
Dec 02, 2008 | Motorola Mobility RAZR V3i Cellular Phone
HELP.asap.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Apr 16, 2008 | SanDisk Sansa e200 MP3 Player
How would I set up WD Passport as a permanent back up for my lap top? How do I erase the Passport from a previous transfer of info or does it automatically erase itself after a data transfer?
no it will never erase automatically ether erasing by data. some recovery software can recover it very easily. best way is to use 3 party software or replace your laptop hdd.
Mar 16, 2008 | Computers & Internet
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
