Question about Kenmore Elite 45986 Front Load Washer
Error codes 'H' and 'F', alternately. - Kenmore Elite 45986 Front Load Washer
  • Kenmore Master
  • 12,061 Answers
Http://www.thathomesite.com/forums/load/laundry/msg021832083258.html?22
Please go to this website above, it directly addresses your issue, it appears that that error FH, has to do with a pressure valve that needs cleaning or replacing, you can DIY.
Posted on Aug 19, 2010
I have a 2005 freestyle with new alternator and battery replaced but code u1900 pops up with engine light and battery light on says check charging system
code u 1900 is a CAN COMMUNICATION BUS FAULT--receive error and is set when the PCM ( power train module) detects a communication error between itself, ABS, trailer brake and cluster when the ignition is in the -run - position
it is normally attributed to bad connections , wiring, abnormal voltages ,, resistances ,
Having fitted a new alternator and battery, the first thing you should do is use a scanner to reset the ECM
Next is to have the charging system professionally checked as the original problem may not have been the alternator but a faulty voltage regulator which would have set off the code
May 05, 2018 | Cars & Trucks
Error code 1500
The error code P1500 means there was a problem "Alternator FR teminal circuit"
Was the battery jump started recently or battery gone dead? This code condition tends to be intermittent especially when a jump start was given
Jun 12, 2015 | Chrysler Sebring Cars & Trucks
Error code:101-0502 for wii u any one know what it is ?
Error Code: 101-0502
Situation:
  • A communication error occurred when using the friend list service.
  • What to do:
    • Check our network status information.
    • Review our Network Status page and ensure there are no service notifications related to the Wii U friend list service.
    • Ensure your Wii U is connected online and try again.
    • Test your Wii U console's Internet connection by performing a connection test. If the connection test fails, use the error code provided to troubleshoot your Wii U console's Internet connection. [How to]
    • Enter an alternate DNS into your Wii U connection settings.
    • If there was an issue with the DNS you are using, entering alternate DNS may resolve your issue. [How to]
Oct 12, 2013 | Video Game Consoles & Games
Error code E 7
proceed according you have two alternative: see the diagrams . God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jan 22, 2013 | LifeSpan Fitness Lifespan PRO3 -Treadmill-...
I have a tunturi t40 treadmill an error code e7 appears And it cuts out after 5 seconds have tried to calibrate the elevation motor but it won't stay at 9 mm gap when it powers up the gap closes
please test the 2 alternatives for error 7. God bless you
see the diagram attached.
ERROR CODE # 7
2)Alternative:
Jan 08, 2013 | Tunturi T40 Folding Treadmill
Meaning H 4 appear alternative Sharp Al-1641 CS
H4 is nothing but an error code that appears due to power fluctation(in absence of a stabilizer). You please enter # interrupt-C interrupt -14-start to clear to clear the error
Jan 12, 2011 | Sharp AL-1641CS Laser Digital Copier
My Sub-Zero is flashing error code 36. What is this?
Diarmait --
Technical Service Manual for the SubZero 600 series can be downloaded at:
[https://docstore.fedex.com/subzero]
Username=subzero
Password=subzero
Write back if you still need help.
-- SWT
Aug 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
My pixma IP1980 ahs an error and the green at orange lights blink alternately. error code is 6000.. pleasehelpme...
Error code 6000 mean line feed error. Possible problems in:
- Timing sensor unit
- Timing **** disk film
- Feed roller assembly
- Platen unit
- Logic board assembly
- PAPER FEED MOTOR
Oct 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Kenmore Elite 45986 Front Load Washer Logo
90 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
