Question about Moen Plumbing
I have a brand new moen faucet 2 handled chrome model.. i was cleaning it and the pop down plug became detattched.. now i can't get the plug out or the water thats being held in the sink.. what do i do
    Scholar:
  • 67 Answers
Take a look under the sink. The mechanical pop up has likely become disconnected from the rod that goes into the drain to control the pop up plug. You should be able to just reconnect it and the drain should work fine. If this doesn't solve the problem please let me know. Please remember to rate this solution, your feedback is important. Have a great day.
Posted on Aug 21, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    How do I remove the chrome cap from the faucet
    depending on the model faucet you have some will just pop off with a sharp edged tool and there will be a screw underneath. others will screw off and you should be able to just lift the spout up and off always remember to grease the o-rings when sliding the spout bck down on the o-ring
    Oct 01, 2014 | Moen 7907 Chateau Two-Handle Kitchen...
    How to tighten swivel spout of moen kitchen faucet
    pop the cover off the top of the spout tighten the screw underneath and replace the cap.
    May 11, 2014 | Moen 7065 Vestige Single-Handle Kitchen...
    How do I get cover off moen 7840 kitchen faucet
    Use a small flat-head screwdriver. Insert behind the small cover and 'pop' it off.
    Dec 27, 2011 | Moen 7840 Camerist Single-Handle Kitchen...
    New moen kitchen single handle. Worked for one full day. Now no water pressure.
    Unthread end of faucet (aerator) where the water comes out into sink, under the aerator is a screen & a plastic valve.It has sediment & rust which will disrupt the flow & pressure.Careful not to flush it down the drain. Tip upside down, while holding it together with finger. Flush it under the faucet. It is not uncommon to get plugged up initialy because of the new installation.
    Nov 01, 2010 | Moen 7310 Legend Single-Handle Kitchen...
    Re: Moen single-lever kitchen faucet like the 7100. When I replace the lever, it only goes up. I can't get it to go down. I'm pretty sure the cartridge is in right, with the U-clip and the other screw-on...
    The water supply should have no bearing on the working motion of the faucet cartridge or handle. On both models of Moen faucet, the handle needs to be hooked under the cartridge's top cam bearing. It is a bit tricky sometimes. Here's the parts view for 7300 and 7310 Moen Kitchen faucet. Parts view for 7100 Moen.
    If you need further assistance please let us know.
    Sep 16, 2010 | Moen 7310 Legend Single-Handle Kitchen...
    Cannot remove handle. Allen wrench receiver is stripped. Are there any other options? Thanks!
    There is a home cleaning product called the The Works which will loosen the corrosion around the screw. Then use a screw extractor tool. You can find one at most hardware stores and home centers.
    Another solution would be to call Moen Customer Support and ask for a new handle and repair parts for free. The faucet should have a lifetime warranty. When you have the new faucet parts in hand, literally cut the handle off the faucet with a hacksaw or drill the screw out to remove the handle.
    Sep 07, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
    Replace cartridge in Moen kitchen faucet and now
    it probably has a plastic cartridge,remove it, and push the center piece out slowly and firmly. wipe this down,not completly this is what carries the wieght of the handle.give this a shot.
    Jan 12, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    I have a moen faucet that has a side handle. It has progressively got to the point that it has less and less water pressure. When I take the main hot/cold water lines loose at the shutoff valve I have...
    pop the cap at the top w/ screw driver,remove screw. lift handle up and off,take note how it attache's.remove retainer nut,now firmly pull up on spout near base move left and right,to remove.back to center of faucet there is horse shoe shaped clip,w/ a little hole pull it out,take good note of how it goe's in in regard's to the cartridge. now pull up on cartridge,theycan be a ***** some time's get a good grip and nice steady pull.if your's has a spray there will be collar there as well check all this and good luck
    Dec 08, 2009 | Moen 7310 Legend Single-Handle Kitchen...
    My moen single lever faucet is loose, how do I tighten it?
    On the back side of the lever you should see a button cover. It pops out exposing a allen key. this will tighten the lever
    Nov 02, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    Plumbing Logo
    106 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
