Question about Aiptek DV-3500 / DV5 Digital Camera
As soon as i switch on the camera,the lcd display comes and in a few seconds the camera gets turned off.i tried putting the new bateries still the it is getting shut.pls help me solve it or else pls provide me the aiptek service centre in mumbai.
  • 6,826 Answers
You'll have to search for the service center in mumbai.
Posted on Aug 19, 2010
PROBLEM WITH - Cannon PowerShot A85:- The
switch off the camera and take out the baterys for a muinnuit then put nthem back in then switch on the camera if you still have the same problem you may need to use the same type of batterys as wos with the camera
Mar 07, 2011 | Canon PowerShot A520 Digital Camera
Kodak Easyshare wont turn on with a full batery
Remove your battery and memory card for 15 min and put them again. (you can also try by putting new batteries. In some cases battery can be faulty.) Then restart your cam. If then also problem persist, Sorry you have to get it serviced. there is a mechanical problem.
Please rate the aswer
Jun 08, 2010 | Kodak EasyShare One Digital Camera
How do I change the LCD screen please?
Very easy.
Remove the batery. Remove the case screws and pull the case apart. Where the flat ribbon cables connect to the main board, carefully release the clamps on the board end plugs. The plugs don't come off, the ribbon just comes out of them. Carefully remove the screen. It has double stick foam in a few spots. Put the new screen in, reconnect the ribbon cables and put the case back together. 30 minutes max.
Sep 30, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
CAnon indicates low batery even it is full
Clean the battery holder with a pencil eraser, otherwise go for good brand rechargeable battery AA 2700 mAh try it.
Aug 25, 2009 | Canon PowerShot A590 IS Digital Camera
Samsung s700 camera lens won't retract
you must have dropped your camera where it caused damage in internal part. when cameras are dropped wires and screws inside loosen which will cause trouble. Have it checked by a pro. you might destroy it more if you try to fix it yourself. Thanks.
Nov 15, 2008 | Samsung Digimax S700 Digital Camera
No LCD display
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 21, 2008 | Pentax Optio S4 Digital Camera
Diplay turning white on mju 700...
Hi
Sounds like your camera was dropped and the LCD was damaged. The white screen you see is typical for a defective LCD screen. The only way to repair the camera is to replace the bad part with a known good one.
One solution would be to buy a defective camera online that has a good LCD screen and swap them out.
Good luck from Darntoothysam com
Thomas
May 01, 2008 | Olympus Stylus 700 / 700 Digital Camera
LCD won't turn off
http://esupport.sony.com/US/perl/news-item.pl?mdl=DCRTRV19&news_id=161
Dec 20, 2007 | Sony Handycam CCD-TRV87 Camcorder
LCD DISPLAY BLANK
The LCd connecting Flexible strip might be faulty. If you can view the picture in dark way,then the back light can be the faluty part. If they are all OK, then replace the LCD. The connecting strip is failing fast as per our experience and this costs US$ 21.00 and it is available with us.
Dec 28, 2006 | Sony Handycam DCR-HC42E Mini DV Digital...
Aiptek DV-3500 / DV5 Digital Camera Logo
55 people viewed this question
Top Aiptek Cameras Experts
mohamed salim shaikh
Are you an Aiptek Camera Expert? Answer questions, earn points and help others
