Question about Philips CDR775 2-Disc CD Recorder
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
    Problem Solver:
  • 17 Answers
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Posted on Aug 19, 2010
How do i record L.P.s to my P.C.
you will need to connect your amplifier to the pc through the line in port, This will most likely be a 3.5mm jack (like headphones) depending on your amplifier, you will need either a twin phono to 3.5mm jack (for aux output on the amp to the pc) or 3.5mm jack on both ends (for amp headphone socket to pc line in)
May 25, 2015 | Televison & Video
I can't record a DVD from VCR. I tried hooking straight to front av jacks,no luck. I have dish network it's set on channel 25,video 1 on the tv. No problem recording from dish,just can't get it to record...
You need to select front AV as you video source on the DVD recorder if using the front AV phono connectors. Make sure the lead you use from the VCR is working y connecting the AV leads directly to your TV if possible.
Mar 03, 2011 | Philips Magnavox MWR10D6 DVD Recorder
I have Radioshack wireless headphones with a 30 foot range. I cannot hook them up to my new Panasonic Viera 42 inch HD T.V. - The "audio outlet" is a square and the headphones only have red and...
hi there.
At present, the square connector is what is called an "Optical" connector.  It's purely digital and transmits digital data via what looks to us like a RED LIGHT.  Your headphones are incompatible. Your heaphones have an analog connection on RCA Phono type connections.  The type you usually get on the back of hifi equipment.
The pannasonics DO have a headphone socket, but it is the small 3.5mm type socket.  a small round hole that looks slightly larger than a pin head.  It normally has a small diagram of a pair of headphones above or below the socket to indicate what it is.
In order to connect your headphones to your set you will need a stereo,male 3.5mm jack to two RCA Phono jacks.
If your current lead on your headphones has "male" ends, the red and white ends should have silver or gold points sticking out.
If your current lead on your headphones has "female" ends, the red and white ends should have silver or gold surrounds with holes in.
With this in mind, if you have male ends you will require a stereo 3.5mm jack to stereo female Rca Phono vice versa so that they basically lock into eachother forming a "Constant chain".
I have tried to explain this as best I can, I hope you've managed to get the idea of what I'm saying.
You will either need this :
http://cgi.ebay.co.uk/1-2m-3-5mm-Stereo-Jack-2-X-RCA-Phono-Plugs-MP3-/270689011629?pt=UK_Computing_CablesConnectors_RL&hash=item3f065287ad
or this :
http://cgi.ebay.co.uk/3-5MM-STEREO-JACK-MALE-2X-RCA-PHONO-FEMALE-ADAPTER-/360300626060?pt=UK_Computing_CablesConnectors_RL&hash=item53e397408c
Sometimes the colours of connectors vary.  Just remember that Red to Red (for right hand side)  and White to White or Black To White  or Black To Black (for left)
Jan 07, 2011 | Audio Players & Recorders
How do i connect my laptop to my berringer mixer to record and play back through my mixer speakers
You'll have to use the headphones socket, so you'll nead a lead with a stereo micro (3.5mm) Jack for the Laptop end and probably RCA Phono's (L & R) at the other. You'll have to check your Mixer inputs.
Its a fairly standard lead, you should be able to get it at most electrical retailers.
Nov 09, 2010 | Computers & Internet
Can this unit be connected to my computer so I can make cd's?
It can if your computer has a 3.5mm jack audio imput.
What you need to have on your unit is and audio out socket. But if it doesn't have one you can use the headphone output. Then all you need is a lead. If you have the output sockets you just need a 3.5 jack to two RCA phono plugs one. If not you will need a 3.5 to 3.5 lead.
If using the headphone output, keep the volume low, use the computer recording device to adjust the signal level. NEVER turn the volume up high. Again if you are using the headphone output set tone controls to neutral, otherwise you will have either too much bass or treble on your recordings.
You can use the computer speakers to monitor the sound. Or you can get a headphone adapter plug that will allow to jacks to go into the headphone output of your unit, so you can connect a pair of headphones, but as I said don't mess with the volume control.
Feb 05, 2010 | Aiwa Z-R555 Shelf System
How do I record from a CD onto a tape?
Two ways. You can put the audio out leads of the CD into the line in of the recorder. However you will have to listen to the recording by connecting headphones to the Recorder's jack socket.
The most common way is to connect the recorder to an amp and the CD to the same and with the cd playing back press record.
In both cases you must set the record level control so that sound on the VU meters peaks at loudest parts at around 0db, rarely going over (into the red on LED type meter).
You will need a 4way RCA type phono cable, the better quality types will give you a better sound. Connect the playback jacks via the output sockets of the recorder to the tape inputs of the amp, vice-versa for the record jacks.
Dec 01, 2009 | Pioneer Audio Players & Recorders
How can I connect my CD-RW880 recorder to the
Make sure the phonograph is connected to the Phono Connectors. Hook up your CD recorder to the tape. The play connectors on the CD recorders can connect to the tape play connectors on your stereo. The record connectors on your CD recorder connect to the record outputs on the tape connectors on your stereo. You can also connect you CD recorder to the VCR connectors if you are using an audio tape as your source. All of the outputs and inputs are the same level except the phono.
Jun 12, 2009 | Teac CD-RW880 CD Player / Recorder
Recording
I always use either one of the Master Output's (you have two, ones a jack the other a phono so use the one you've not got pklugged into your amp), or the monitor output...assuming you're not already using these for instance in a club environment.
Personally I've been using a phono to headphones jack cable from the monitor putput into my laptop (using Soundforge to record), the advantage being you can change the level of the recording volume using the monitor vol, without affecting your Master Volume whilst you're having a mix!
Hope that helps...
Dec 22, 2008 | Pioneer DJm500 Professional DJ Mixer...
Can't get sound JBL Media 100 speakers/ subwoofer with mac
I am not sure what the extra lead is for. The instruction book should make it plain how it should be connected. If you have no instructions perhaps they can be downloaded from the manufacturer's website.
My 5:1 speaker system is prewired and has only one audio in lead and a socket for the power supply. The audio lead of such speaker systems is generally equipped with a 3.5mm stereo jack plug intended to be used in the headphone socket of computers, tv's, radios and anything with a headphone socket, even phones.
Once you are certain the speakers are properly connected they should work if there is audio present at the headphone socket of the Mac. A known pair of headphones can be used to test this and conversely the speakers could be tested by plugging them into any other known good audio source.
The presence of an RCA or phono plug/lead is confusing as these aren't usually associated with active speaker systems for computer and general use but rather for more serious audio such as connections between an amplifier and peripherals or cinema surround sound. Such a system probably wouldn't be suitable for use with a computer...
Apr 01, 2017 | JBL Media 100 Computer Speakers
Philips CDR775 2-Disc CD Recorder Logo
253 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
