Question about Plantronics DSP-400 Headset
I have problem in plantronics dsp 400..regarding mike..i cab hear the incoming calls but i cant hav any conversation in mike..the end user cannot hear..so kindly rectify this problem..as it would be of great help. Let me know if any software is required to install.
  • 3 Answers
<span style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: navy; FONT-SIZE: 10pt; mso-fareast-font-family: Calibri; mso-fareast-theme-font: minor-latin; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">The first thing you need to check is your audio settings and make sure that both sound recording and playback are set to the same device. If you
Posted on Aug 19, 2010
  • scashiola Aug 19, 2010
    The first thing you need to check is your audio settings and make sure that both sound recording and playback are set to the same device. If you're using the headset with the USB connection then both recording and playback should be set to the headset. If you're using the device through your sound card with the audio jacks then it's possible you have a bad sound card. Do any other headsets or microphones work on your computer? Is this the first time you've used this headset on your computer? An no, there are no drivers.
User has a iCom Bluetooth Hearing Aid adapter paired with her Plantronics Voyager 500A base station on a Cisco 7940. When on an active call and she receives another incomming call, her current call is...
Make sure that the Plantronics 500A base inteli-sensor switch is set to the number one setting (should be set on the one line, not the two line setting, on the right side of the 500A base unit). Also if you are using an EHS (Electronic Hook Switch) instead of an HL10 Handset Lifter, that could be the issue as well. The only other thing is to check the user guide for the hearing aid and make sure that there is not an "auto answer" setting that may need to be turned off. Here is a link below for the 500A / 510S user guide.
Plantronics 500A/510S User's Guide
Good luck from Headsets Direct!
Apr 04, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Mike is not working but there is some problem with my mike i can not hear the voice of incoming call. i have given the mobilr for service he is saying that your both mike is ok . for that you have to...
hi :) i u cant hear people talking,that not mike problem. mike problem is people cant hear u talking. i think your speaker was spoil already,that why u cant hear the voice incoming or ringing.u better send for check again :)
if my solution useful,please voted me.thanks..
Jul 30, 2010 | LG Shine KE970 Cellular Phone
How do I replace the ear cushions for a Plantronics DSP 400? Does the ear piece detach? Can't find a manual either.
There are some small silver inserts on the side of each earpiece. You can pry them off (gently) starting under the cushion and working your way around.
You can then remove the old cushions and put in the replacements and snap these silver retainer inserts back on.
You can get replacement cushions online for about $16.
Oct 14, 2009 | Plantronics DSP-400 Headset
Do I need a driver for plantronics USB DSP v4 audio interface
Yes you would need a driver for your Platronics headset if you intend to connect it to your PC
Could you please describe the model of your plantronic headset so that i can get the required drivers for you.
Thanks.
May 21, 2009 | Plantronics DSP-400 Headset
Bluetooth is paired and on but instead of answering calls, send call straight to voicemail.
Is there a visble window setting You may have to change it to be visible to your phone for more than a few minutes. Check your setting on answering or sending all incoming to the answer machine. Press the large face button to answer a call.
http://safemanuals.com/user-guide-instructions-owner-manual/PLANTRONICS/EXPLORER%20220-_E link to playtronics for user manual.
Apr 15, 2009 | Plantronics - Bluetooth Headset Plus Base...
Incoming calls don't connect easily when I hit the button on plan
Try deleting the headset from your phone, turn phone off for about 45 seconds and them turn it back on. Now try repairing headset to your phone. See if this will help with the problem.
Below is a link to the 300 Series User's Guide for more information:
Plantronics Explorer 300 Series User's Guide
Apr 04, 2009 | Plantronics Explorer 330 Headset
CS70N Wireless headset
The earpiece will make 3 short beeps when a call is incoming. Also the phone will still ring if you are within distince to hear the ringer. Hope this helps! SM
Sep 10, 2008 | Plantronics CS70 Wireless Headset
PLANTRONICS 330
Link to user guide:
http://plantronics.custhelp.com/cgi-bin/plantronics.cfg/php/enduser/std_adp.php?p_faqid=8769&p_created=1157668516&p_sid=Sv_asGUi&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MiZwX3Byb2RzPSZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1leHBsb3JlcjMzMA**&p_li=&p_topview=1
Oct 17, 2007 | Plantronics Explorer 330 Headset
Can't Hear Anything
Did it come with software if so did you install that?
If you have it may just be a loose wire in the headset, i would take it back and ask for a replacement.
Hope this helps,
and good luck.
Ben
Oct 15, 2007 | Plantronics DSP-400 Headset
Plantronics DSP-400 Headset Logo
588 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
Ed Nelson
Ed Nelson
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
