Question about RC Toys
I have an ACOMS AP-435 4 channel Tx/Rx. It is set up to take 8 AA dry cells, but appears to have a charging socket. Can you help me work out what charger I need? Basically I need to knwo the charging voltage and whether the centre pin is +ve or -ve. Can I obtain an instruction leaflet or manual from somewhere??? Many thanks
4 Suggested Answers
SOURCE: peg-perego quad 12v. Just bought it, no instructions, need to charge battery can't find where to plug charger in.
It's in the front. the bumpber pulls down and the plug is behind it.
Posted on Dec 17, 2008
  • 7 Answers
SOURCE: just need to get the
You can find user manuals for all lexibook toys at this link: User Manuals
Posted on Mar 03, 2011
I have the CXT88. It's been a while since I dont use them. Now I can't get them to work.
Assuming these are Cobra CXT88 radios.
Manual: https://www.manualslib.com/manual/29293/Cobra-Microtalk-Cxt88.html
Make certain they are fully charged. I suspect the batteries. If the radio was left in the "on" position, it is very likely the batteries will not take a charge. The batteries can die in the drawer as well. Lithium batteries for all their good points really do not store well. (Yes, expensive lithium batteries such as your power tools or laptops do store well.) So, plan on new batteries. Many radios have become less expensive this year, so price out a new pair. That way you would have fresh batteries and a new charger.
Nov 05, 2016 | Radio Communications
I need help programming my baofeng 997s
To programme a repeater. VFO mode & curson on top line of display. Enter freq eg 147.250. Go menu button change settings like offset, tone. In menu delete channel required eg 000. In menu below that, choose mem channel now 000 & it saves receive freq.
Exit. press *SCN button so R appears on display. Save as 000 again but this time it stores TX freq. In other words, you save RX first, then exit.Add * so R appears in display second time round and save again TX freq. Go to channel mode and see it is in 000.
I might do a video to help people. Its the same process with UV5r and other Baofeng. Simplex you just save in one operation because TX is RX.
Aug 08, 2014 | Radio Communications
When i try to calibrate my 148gtl mk 2 the needle is very erratic,why?
can you be more specific please ?
TX meter or RX s meter ? check power supply voltage is stable,
obviously on RX its essential to use a constant signal, of course,
if you're doing it without test gear & just doing a quick 'tweak' comparing with a good know s reading off a known set - a s9 signal is usually the standard point they calibrate to. although on a CB set its not a greatly important. on TX you may first want to check RF power out is constant first, so a dummy load (in case aerial swr is changing while on TX) needs to be used.
If actual RF power is changing, suspect drying electrolytic capacitors, these sets are 30 years old, so its not unlikely. dying driver or PA transistors or dry joints are also possible. or if everything checks out, possible voltage regulation probs, so check 2SA1012 AM reg isn't dying and the other ****** too.
If you're lucky, its just the variable resistors giving up.
Mar 07, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
New radio, TX/RX freq. off 7khz and clarifier non functionable
under warranty that would be cover no charge.! send it in.. The clarifier on a factory radio will only adjust the RX.. not the TX.. unless there's a "course and fine." the course would do both. the fine would be rx only
Feb 22, 2011 | Galaxy Radios DX-2547 40-Channels Base CB...
Midland GXT 950 two way. TX problem
I am sure the OP isn't likely monitoring this, but just in case anyone else needs it... It's a power problem. Try charging the batteries, even though they look like they're fully charged -- or replace with 4@AA batteries.
This only seems to happen on the GMRS channels -- not the FRS ones. The radios come default to transmit at high power (the full 5 watts) on the GMRS channels, but only 0.5 watts on FRS. If you go to settings and change the power on that particular channel you're trying to medium or low, you'd likely find it works with the charge you had problems with.
Recharging or changing to 4@AA batts should get you back up to continuous TX on those high-powered channels.
Jul 04, 2010 | Midland Two Way Radio
How do I change the Baud rate on a canon f80 fax
To set the receive speed
Change RX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (RX or send) speed if this message appears frequently on the LCD.
  1. On the operator panel, press <Menu>.
  2. Press the left '<' or right '>' arrow repeatedly until [USER DATA] appears.
  3. Press [Set].
  4. Press the right arrow repeatedly until [FAX SETTINGS] appears.
  5. Press [Set].
  6. Press the right arrow repeatedly until [RX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [RX START SPEED] appears.
  9. Press [Set].
    1. The factory default RX (send) Speed is 33600 bps.
    2. You can select from the following RX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable RX Speed.
  11. Press <Set>.
  12. Press <Stop> to return to standby mode.
To Set the Send Speed
Change TX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (TX or send) speed if this message appears frequently on the LCD.
  3. Press [Set].
  5. Press [Set].
  6. Press the right arrow repeatedly until [TX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [TX START SPEED] appears.
  9. Press [Set].
    1. The factory default TX (send) Speed is 33600 bps.
    2. You can select from the following TX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable TX Speed.
You can download a copy of the user manual for the F80 at
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=7175
Please make sure to rate this solution. Thanks.
  1. Press <Set>.
Apr 29, 2010 | Canon MultiPASS F80 All-In-One InkJet...
Speaker to soft on samsung U700 Cellphone.Already on max.
found it from this link
First start with *#0002*28346#
1. You will see menu showing "Under construction".
Press #.
2. New screen apears.:
[1] Load Params
[2] Call Config
3. Press Call Config
4. New screen (in here are all the settings for call volume):
[1] RCV Rx Call Vol (that`s what we focus on)
[2] RCV Rx Drmf Vol[]
[3] RCV Codec Gain[]
[4] RCV NS-EC[]
[5] RCV Tx AGC[]
[6] RCV Rx AGC[]
[7] RCV Tx Filter[]
[8] RCV Rx Filter[]
5. Press 1 to get into RCV Rx Call Vol Settings.
6. Now starts the editting.
You should see something like this (values below are not default cause i already changed them):
0.[2] rx:0.0dB
1.[4] rx:10.0dB
2.[6] rx:25.0dB
3.[8] rx:50.0dB
4.[10] rx:100.0dB
5.[12] rx:200.0dB
6.[14] rx:255.0dB
Input Ex: 123-> 12.3dB
Last line explains almost everything.
Each line represents different volume levels. Let`s say you want to edit first line. Then you press 0. Screen on your phone should blink. Now you enter value for the level. Let`s say you want it to be 21.3dB. Type in 213 and press ok. Display should blink and you will see:
0.[2] rx:21.3dB
1.[4] rx:10.0dB
2.[6] rx:25.0dB
3.[8] rx:50.0dB
4.[10] rx:100.0dB
5.[12] rx:200.0dB
6.[14] rx:255.0dB
That`s it. You just changed first line which means the lowest volume setting to 21.3dB. Keep playing with other settings. When you want to change second line just press 1. Then screen blinks again. Let`s say you want it to be 255dB. Type in 2550 and press OK. Screen blinks and you should see:
0.[2] rx:21.3dB
1.[4] rx:255.0dB
2.[6] rx:25.0dB
3.[8] rx:50.0dB
4.[10] rx:100.0dB
5.[12] rx:200.0dB
6.[14] rx:255.0dB
7. Now let`s go to speakerphone.
Press # 4 times.
You should get to menu like this:
[1] Debug Screen
[2] Version/DMS Information
[3] RF Test
[4] UMTS rf nv
[5] Read gsm rf nv
[6] Write gsm rv nv
[7] Base Band
[8] Audio (that`s where we are going now)
[9] Common
8. Press 8.
You should see:
posted by Gjigji Shabani - Ulqin - MOntenegro
Jun 10, 2009 | Samsung SGH-U700 Cellular Phone
Forgot codes of SHG-D500 cell phone - sound settings
I was suprised to see quite a few people are tweaking their sound settings and various other things -
thanks very much for the insightful help offered for my queries.
It might be an abuse of space, but If anyone else happens to needs/wants the defaults values SHG D500 Samsung Test Mode they are:.
Code: *#8999*8378# ( * means press star)
Normal
MIC gain - 0
Tx PGA - 70
Side PGA - 0
Ear gain - 3
HFR gain - 9
Rx PGA - 128
Rx vol - Lv 1 - 10
Rx vol - Lv 2 - 28
Rx vol - Lv 3 - 40
Rx vol - Lv 4 - 50
Rx vol - Lv 5 - 96
Rx comp - Lv 1 - 11
Rx comp - Lv 2 - 11
Rx comp - Lv3 - 11
Rx comp - Lv 4 - 29
Rx comp - Lv 5 - 30
Key vol - Lv1 - 64
Key vol - Lv2 - 64
Key vol - Lv3 - 64
Key vol - Lv4 - 64
Key vol - Lv5 - 64
Headset
MIC gain - 0
Tx PGA - 64
Side PGA - 0
Ear gain - 13
HFR gain - 3
Rx PGA - 128
Rx vol - Lv 1 - 10
Rx vol - Lv 2 - 20
Rx vol - Lv 3 - 42
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 146
Rx comp - Lv 1 - 11
Rx comp - Lv 2 - 11
Rx comp - Lv 3 - 11
Rx comp - Lv 4 - 30
Rx comp - Lv 5 - 28
Key vol - Lv1 - 10
Key vol - Lv2 - 20
Key vol - Lv3 - 42
Key vol - Lv4 - 76
Key vol - Lv5 146
Loud SPK SUP
MIC gain - 0
Tx PGA - 160
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 120
Rx vol - Lv 1 - 16
Rx vol - Lv 2 - 27
Rx vol - Lv 3 - 45
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 128
Key vol - Lv1 - 1
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Loud SPK SDN
MIC gain - 0
Tx PGA - 160
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 120
Rx vol - Lv 1 - 16
Rx vol - Lv 2 - 27
Rx vol - Lv 3 - 45
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 128
Key vol - Lv1 - 1
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Loud SPK EXT
MIC gain - 1
Tx PGA - 226
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 92
Rx vol - Lv 1 - 16
Rx vol - Lv 2 - 27
Rx vol - Lv 3 - 45
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 128
Key vol - Lv1 - 5
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Loud SPK Out Only
Tx PGA - 160
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 120
Rx vol - Lv 1 - 10
Rx vol - Lv 2 - 28
Rx vol - Lv 3 - 40
Rx vol - Lv 4 - 50
Rx vol - Lv 5 - 96
Key vol - Lv1 - 1
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Yamaha AMP vol.
31
Yamaha MEL vol.
Normal
Lv 1 - 6
Lv 2 - 12
Lv 3 - 18
Lv 4 - 24
Lv 5 - 31
Melody key
Lv 1 - 2
Lv 2 - 4
Lv 3 - 11
Lv 4 - 18
Lv 5 - 25
Power on/off
Lv 1 - 1
Lv 2 - 10
Lv 3 - 14
Lv 4 - 18
Lv 5 - 22
ISS Normal
Ear gain - 12
HFR gain - 3
Rx vol - Lv 1 - 121
Rx vol - Lv 2 - 186
Rx vol - Lv 3 - 268
Rx vol - Lv 4 - 376
Rx vol - Lv 5 - 564
Rx vol - Lv 6 - 802
Rx vol - Lv 7 - 980
Rx vol - Lv 8 - 1560
Rx vol - Lv 9 - 2167
Rx vol - Lv 10 - 2863
ISS Headset
Ear gain - 10
HFR gain - 3
Rx vol - Lv 1 - 164
Rx vol - Lv 2 - 328
Rx vol - Lv 3 - 492
Rx vol - Lv 4 - 656
Rx vol - Lv 5 - 820
Rx vol - Lv 6 - 984
Rx vol - Lv 7 - 1148
Rx vol - Lv 8 - 1312
Rx vol - Lv 9 - 1476
Rx vol - Lv 10 - 1640
Bluetooth
Tx PGA - 255
Rx PGA - 12
Side PGA - 0
Mar 19, 2009 | Samsung Cell Phones
Cobra 25 uk ltd soundtracker locks up on channels
probably is the tuner chip or main board that gave troubles...assistance from expert only!
rgds, stefano
Jul 07, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Audio settings
default values of the secret E370 audio menu by inputing *#8999*8378*
Normal
MIC gain - 0
Tx PGA - 70
Side PGA - 0
Ear gain - 3
HFR gain - 9
Rx PGA - 128
Rx vol - Lv 1 - 10
Rx vol - Lv 2 - 28
Rx vol - Lv 3 - 40
Rx vol - Lv 4 - 50
Rx vol - Lv 5 - 96
Rx comp - Lv 1 - 11
Rx comp - Lv 2 - 11
Rx comp - Lv3 - 11
Rx comp - Lv 4 - 29
Rx comp - Lv 5 - 30
Key vol - Lv1 - 64
Key vol - Lv2 - 64
Key vol - Lv3 - 64
Key vol - Lv4 - 64
Key vol - Lv5 - 64
Headset
MIC gain - 0
Tx PGA - 64
Side PGA - 0
Ear gain - 13
HFR gain - 3
Rx PGA - 128
Rx vol - Lv 1 - 10
Rx vol - Lv 2 - 20
Rx vol - Lv 3 - 42
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 146
Rx comp - Lv 1 - 11
Rx comp - Lv 2 - 11
Rx comp - Lv 3 - 11
Rx comp - Lv 4 - 30
Rx comp - Lv 5 - 28
Key vol - Lv1 - 10
Key vol - Lv2 - 20
Key vol - Lv3 - 42
Key vol - Lv4 - 76
Key vol - Lv5 146
Loud SPK SUP
MIC gain - 0
Tx PGA - 160
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 120
Rx vol - Lv 1 - 16
Rx vol - Lv 2 - 27
Rx vol - Lv 3 - 45
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 128
Key vol - Lv1 - 1
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Loud SPK SDN
MIC gain - 0
Tx PGA - 160
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 120
Rx vol - Lv 1 - 16
Rx vol - Lv 2 - 27
Rx vol - Lv 3 - 45
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 128
Key vol - Lv1 - 1
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Loud SPK EXT
MIC gain - 1
Tx PGA - 226
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 92
Rx vol - Lv 1 - 16
Rx vol - Lv 2 - 27
Rx vol - Lv 3 - 45
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 128
Key vol - Lv1 - 5
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Loud SPK Out Only
Tx PGA - 160
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 120
Rx vol - Lv 1 - 10
Rx vol - Lv 2 - 28
Rx vol - Lv 3 - 40
Rx vol - Lv 4 - 50
Rx vol - Lv 5 - 96
Key vol - Lv1 - 1
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Yamaha AMP vol.
31
Yamaha MEL vol.
Normal
Lv 1 - 6
Lv 2 - 12
Lv 3 - 18
Lv 4 - 24
Lv 5 - 31
Melody key
Lv 1 - 2
Lv 2 - 4
Lv 3 - 11
Lv 4 - 18
Lv 5 - 25
Power on/off
Lv 1 - 1
Lv 2 - 10
Lv 3 - 14
Lv 4 - 18
Lv 5 - 22
ISS Normal
Ear gain - 12
HFR gain - 3
Rx vol - Lv 1 - 121
Rx vol - Lv 2 - 186
Rx vol - Lv 3 - 268
Rx vol - Lv 4 - 376
Rx vol - Lv 5 - 564
Rx vol - Lv 6 - 802
Rx vol - Lv 7 - 980
ISS Headset
Ear gain - 10
HFR gain - 3
Rx vol - Lv 1 - 164
Rx vol - Lv 2 - 328
Rx vol - Lv 3 - 492
Rx vol - Lv 4 - 656
Rx vol - Lv 5 - 820
Rx vol - Lv 6 - 984
Bluetooth
Tx PGA - 255
Rx PGA - 12
Side PGA - 0
Oct 04, 2007 | Samsung SGH-E370 Cellular Phone
Toys Logo
117 people viewed this question
Top RC Toys Experts
Tom Chichester
Kevin K.
Brett Duxbury
Brett Duxbury
Are you a RC Toy Expert? Answer questions, earn points and help others
