Question about HP LaserJet P3005n Printer
Hp laser jet3005n error mem test failure replace dimm 0
  • 1,110 Answers
This means your formatter board has failed. This is quite common on the P3005. You need to call HP support and give them your serial number. They will tell you if it is under their extended warranty. They have a program to cover these defective boards. Just don't know wether your machine will still be under that repair program. In any case be assured it is the formatter board which is under the right side cover. The one that your network/USB cable plugs into. I repair HP printers and have personally seen this exact situation 4 or 5 times.
If your still unsure just Google search P3005 formatter or P3005 replace dimm 0. You will see lots of people with the same issue.
Good Luck and Thank You for using Fixya.
Posted on Aug 19, 2010
What does printer code "mem test failure 1/6
Hello carmen_alley,
This means the memory test process failed due to a bad module. DIMM ( Dual In-line Memory Module ) is the memory of your printer. It is really similar to computer RAM (memory).
If the printer is under warranty I would contact the manufacturer for a repair/replacement. If it is not, I would still contact them and get further information on what DIMM you would need to purchase to replace the bad one.
Hope this helps!
Jun 29, 2011 | HP LaserJet P3005dn Printer
Mem test failure replace Dimm 0
There is only one DIMM slot in the printer.
Unplug the printer, disconnect the interface cable.
Remove the right side cover by sliding it to the rear.
Open the metal access door by pulling on the metal tab located at the left side of the door.
You will see the DIMM, reseat it, plug in the power cord and power up. It will power on with these covers open. If the error comes back, you will have to buy a replacement DIMM. Take the bad one with you to match. BestBuy, Radio Shack or any computer store even Walmart should carry them. They are "keyed", so they only can go in one way.
Apr 05, 2011 | HP Laser Jet Printer P3005dn
My printer shows memory error on its screen why?
Mem test failure replace Dimm 0 or Mem test failure replace Dimm 1
If either of the are the messages displayed, the problem lies with the mother board (formatter).
DIMM 0 = On Board Memory - cannot be changed. DIMM 1 = Add On Ram - Can be Changed
Make Sure the printer firmware is up to date FIRMWARE
Most Likely the formatter board would require replacing.
Feb 03, 2011 | HP LaserJet 2420dn Printer
Mem test fail replace DIMM1
This error indicates that either the formatter has failed, or if you have additional memory installed it is bad.
Dec 06, 2010 | HP Laser Jet Printer P3005dn
The printer states mem test failure replace dimm 0, what is this and how much does it cost?
Dimm 0 is the memory that is onboard the Format board, you can't just replace it like a memory upgrade where you would add another dimm. You would have to replace the whole format board, part number Q7848-61006. cost all depends on how much you shop around.
Sep 15, 2010 | HP LaserJet P3005dn Printer
Mem Test Failure Replace Dimm
The biggest problem with the P3005 is the main board. There has been a warranty extension on the P3005 if it is the main board.
it maybe a memory problem too, but unless you added memory, its usually part of the main board.
Jun 02, 2010 | HP LaserJet P3005n Printer
MEM TEST FAILURE REPLACE DIMM 0
DIMM 0 is the memory slot under the keyboard.
Apr 15, 2010 | HP Compaq Presario 3005US PC Notebook
Problem for HP LaserJet P3005n Printer MEM TEST FAILURE REPLACE DIMM 0
Apr 15, 2010 | HP LaserJet P3005n Printer
Printer hangs and gives a message"MEM FAILURE REPLACE DIMM 0"
You would need to replace dimm memory if you have spare one. Or try to remove it and install it again
Sep 24, 2009 | Office Equipment & Supplies
HP LaserJet P3005n Printer Logo
524 people viewed this question
Seeker5211
Seeker5211
