Question about Toshiba Satellite P205-S6347 Notebook
Monitor won't go on. blue screen. but exteral monitor works
  • 69 Answers
Sounds like it could be a possible problem with your driver. Find out what type of graphics chip is on the laptop and go to their site to get the most recent driver for your operation system. Hopefully that will help you out
Posted on Aug 19, 2010
Laptop monitor bad color and flickers continuely, but when attached to external monitor, works fine
I'm going to take an educated guess here, because it sounds like the monitor's interface controller is bad. I forgot the name of the thing, but it's a small circuit board that's normally located at the bottom of the panel frame, between the flat ribbon cables and the round hinge cables.
"Inverter Board"
Mar 19, 2013 | Dell LATITUDE Computers & Internet
Gateway monitor 2100 won't turn screen on, blue lite is on as if monitor is. but screen is not on. can it be fuse or what ? is not v-card
It sounds like the lamp for your monitor is no longer receiving power. While you can attempt to fix this issue yourself I wouldn't recommend doing so as it doesn't mean it will work after you attempt it.
If the monitor is under warranty still then you should contact the manufacturer about a RMA. If the monitor isn't under warranty then you should purchase a new monitor.
Nov 26, 2011 | Gateway Computers & Internet
Well I have a Gateway Laptop Model MS2274 and it won't turn on. The light of On/Off is blue so it's on, but the screen remains pitch black. I connected it to recharge it and the light turns on too....
Try connecting an external monitor and see if your see anything. If you can then most likely your LCD monitor on the laptop is dead. Also try FN+ the monitor toggle key to see if you can get video.
Jun 20, 2011 | Computers & Internet
I am trying to connect an acer netbook to an LG tv. All I get is a no signal response. What do I do?
ensure you switch on the exteral outlet of your laptop.
for acer i am told the following
right click the desktop and choose graphics options/external monitor. ensure this is set to external monitor.
if not look for a button on your keyboard that has a monitor square shape on it. then use the fn or function key together with this key to toggle thorough, notebook screen - notebook+monitor- monitor only.
2. ensure the source is set to on TV for the input for pc monitor connection. ensure and correct monitor cable is between the input connector on your tv and the monitor output of your laptop.
hope this helps
Dec 11, 2010 | Acer Aspire One Netbook 8.9" Notebook
Bad colors on an exteral screen ev700
this problem generally occurs with old monitorsyour picture tube has probably been damaged.
Feb 09, 2010 | Gateway EV 700 17" CRT Monitor
I have a dell e1505 laptop you turn it on it flickers to dell for about a 1/2 second then goes virtually black but if you look real close the screen is there.you can still hear it, i hook it to a exteral...
hi there !
-if you switch the computer on and it boots up and you hear the windows sound, this could be a possible video problem or motherboard problem
-run the diags on the LCD, while the computer is off, press and hold "D" then press power button at the same time, if you see the colors red blue green without any problems then it is a motherboard or video card problem
-another method to run the test is while the computer is off; preess and hold Fn then press power button, let the test run; when you see the question were colour bars displayed, press N, if you see the colors red blue and green without any problem then it is a motherboard problem or video card; otherwise it is an LCD problem
-to toggle display on the external monitor press Fn then F8
cheers !
Oct 20, 2009 | Dell Inspiron E1505 Notebook
I've tried to on my laptop (acer aspire 3680), but the lcd screen is blank even it already turned on..
check the display on exter monitor through the vga port, if its there then its the fault of the screen, if its not then its the fault of the motherboard of laptop take it to the service centre
Sep 26, 2009 | Acer Aspire 3680 Laptop
Will not power up
If there are lights and fan action to start with, but no screen to see, try changing or just reseating the RAM. If that fails, attach an exteral monitor to the laptop, and press the keys to switch the display to that (if required). Usually the 'Fn' (function) key plus one of the top-row buttons (it's 'f4' on this laptop). This alternates between laptop display; both displays or external display. This will check if your display is faulty - if so, would usually be backlighting failure. Replace the laptop LCD screen if so.
Sep 09, 2009 | Computers & Internet
Display problem
It can be inverter boad, so try to find someone who have got the same type of model so try to change the inveter the see what will happen.Or try to check the cable if its well connected on the motherboad of the computer.
Mr CPU.
Apr 10, 2008 | Compaq Evo N1020V Notebook
Toshiba Satellite P205-S6347 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
