Question about LG Heating & Cooling
My LG air-con model HS-C096QDA3 is acting up. Sometimes, it just beeps a note and doesn't work at all (it becomes irresponsive to my remote controller), even when i try switching on and off of the electricity source.
bobotfel
  • 236 Answers
SOURCE: AIR CON REMOTE CONTROL NOT WORKING
replace your receiver board it may be defective.
Posted on May 16, 2008
notsomot
  • 67 Answers
SOURCE: Remote Control Unit-Fujitsu Air Con. Model:AR-DL1 is broken.
If you contact Fujitsu in your country and you will be able to buy it straight from them, if they are still available. Now I have to warn you as a Fujitsu warrenty agent they are very very expensive.
I would prolly recommend getting a universal remote. ALOT cheaper
Posted on Jan 23, 2009
lenwest
  • 150 Answers
SOURCE: Remote's functions dont control the air con anymore.
Have you checked the battery's in your remote?
Posted on Jan 30, 2009
louislevel_2
  • 374 Answers
SOURCE: my LG air cond will only work when put on to manual ON
hi! there,
have you ever check the batteries,try to replace a new one.or if not function after replacing
try to clean the pads behind in any button of your remote.doing this open your remote there are quick lock in the side of your remote,use flat screw driver to loosen this be carefull to break the
lock,try to cleran the rubber pads by cotton buds
to remove oily debris and on circuit board if you have an eracer in pencil try to rub this gradually
until carbonize element disappear.then put back
pads and cover together and try.cheers and have a nice day don't forget to rate me thank's
Posted on Apr 04, 2009
crouchdash
  • 83 Answers
SOURCE: I HAVE MISLAID REMOTE CONTROL INSTRUCTIONS TO CHANGE FACILITY REQUIRED IE COOL, OR HEAT
You can download the owners manual; here is the link for it.
http://www.generalmanual.com/Air-Conditioners/LG-LA121CNP-Art-Cool-Air-Conditioner.htm
when you get to the page scroll down and you will see Download Now and under that "Owners Manual" just click on it.
I hope it helps.
Posted on May 27, 2009
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
HOW I CONNECte remote control to fujita air ASW-H18B4/HS
If it the correct remote control for the unit, point remote to unit and press power button this is normally followed by a beep to confirm unit has received command,
if this does not work please check battery's to ensure they are still fit for purpose
Dec 24, 2015 | Heating & Cooling
My REMOTE CONTROL IS NOT WORKING I HAVE TO SWITCH IT OFF FROM THE MAIN HOW CAN I GET A RELACEMENT IT IS AN LG SPLIT SYSTEM AIR CON?
First try to change the batteries before replacing the remote control. Buy replacement from SEARS or any LG suppliers. Sometimes the problem is in the control board circuit due to condensation.
Sep 02, 2011 | LG Heating & Cooling
I have an celestial air con unit model KFR-70GW/K it is blowing air refresh out but will not turn on to air con with the remote... help
Check temp setting minimum -3 degree than your room temp and also in cool mode. If while settings there any beep sound? If not transmission problem between remote and PCB. Replace batteries and check once again. If beep sound comes and no start, check compressor is working and also with proper gas pressure. Thanks.
Jan 22, 2011 | Heating & Cooling
Cant turn air con of with control
if the remote is lg it haven't code the eye of the plate has burned
Feb 21, 2009 | LG LS-L1210CL Mini Split Air Conditioner
LG AIR CONDITIONER NOISE
What kind of air conditioner is this? A window unit or a split?
Sep 19, 2008 | LG Heating & Cooling
May 12, 2008 | LG Art Cool LA121CNP wall/window Air...
Heating & Cooling Logo
154 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
