Question about Refrigerators
Fridge on top of freezer is not chilling - Refrigerators
    Scholar:
  • 58 Answers
If you have a french door (also known as bottom mount, freezer on bottom) and your fridge sections(cold air blows from freezer to refrig) is not cooling try this
1. ensure you hear the fan running, its it not, thats it(most likely fan motor
IF fan is running check these things
1. ensure refrig section light shuts off by holding down the switch
2. ensure door shuts
3. clean conderser coils (usually accessed from front through base grille)
4. check for icing in vents, freezer section contain them at top or back, and for a bottom mount the refrig sections vents are under your BIG drawer. if iced try a hair dryer from distance. or empty food into another fridge unplug open doors, and plug back in two days later this should defrost all ice build up
Posted on May 02, 2008
I have a haier model # htq18jabww-01 and the freezer seems to b working fine but the fridge does not seem to be cold at all...any soultions??
The "Cold-to-Coldest" adjuster in the freezer steals chilled air from the refrigerator to add more to the freezer. It's a mechanical damper. Set it fully CCW to cold (warmest position). I also put duck tape over half the chilled air outlets in the freezer to increase the chilled air pressure feeding the refrigerator section. Set the thermostat in the refrigerator to 8 or 9 and the freezer works fine and everything in the refrigerator is 38F.
Apr 18, 2012 | Haier HTQ21JABWW Top Freezer Refrigerator
I have a westinghouse 2 door fridge that is not getting cold enough, 7 degrees in the fridge, freezer seems ok. not sure where to set the controls as i have no manual. its a 2 door,freeze at the top and...
i think your ref working normal try to adjust thermostat setting on the fridge if you want to cool lower than 7 degrees but this temp. allready can chill the food. then you said that freezer ok.
Feb 12, 2011 | Westinghouse Refrigerators
Top freezer is getting cooled but bottom freezer is not getting chilled
Check freezer fan behind freezer is working. Check ice formation not abstracting the fan by working. This is the common problem- defrost failure. Check thermostat,timer and freezer heater are working.
Simple way of solution. Unplug fridge for some times and after defrost completely, restart the unit.Keep freezer temp @5 degree.
Jan 30, 2011 | Samsung Refrigerators
My Miele fridge freezer KFN8762SDED has a problem in the fridge section. The temperature varies between 4 and 13 degrees. If I put on the super chill the temp comes down to normal, 4 degrees only to rise...
Hi Jean, Sorry I have no solution - but have an identical issue with my Miele fridge freezer... - In case you have managed to find a solution, I would be grateful if you could let me know what it is, to save me from running around... ?? Best wishes in any case, Guy
Jan 12, 2011 | Miele KFN8762SDED Bottom Freezer...
I've had a Samsung fridge for 6-7 years, it's a small/medium fridge/freezer with the freezer at the top (sorry, don;t have the size handy). The freezer works fine, however the fridge no longer makes...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 27, 2010 | Samsung Refrigerators
I have a samsung side by side fridge, and the fridge side is not staying cool, but the chill drawers are keeping the right temp??? The Model# is RS267LABP
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The chill drawers are probably staying cold because there is a vent to the freezer in the wall for the cold air to seep through.
Nov 03, 2009 | Coffee Makers & Espresso Machines
Bot the fridge & freezer have quit chilling..
sounds like something pocked a hole in the refrigerant line ether inside or out side leak needs to be found and repaired with epoxy and coolant refilled
Oct 28, 2009 | Samsung Refrigerators
Hotpiont ffm90 fridge not chilling
hi if the freezer appears to work and the fridge if warm,the problem is that the freezer is over frozen and blocking the vents which send cold air into the fridge when required,and the noise is the fan hitting the the ice build up,defrost (switch off)your applinace for at least 36 hours then switch back on,you will then find after the freezer reaches -12 the fridge will then start to go cold.
Mar 09, 2009 | Hotpoint FFM90 Bottom Freezer Refrigerator
FREEZER ACCUMULATED WATER FROZEN NOW DRIPPING THRU TO FRIDGE
The drain in the freezer is blocked. Just below the cooling coils is a drain, when the defrost heater cycles on the water is suppose to go down the drain and into a pan under the ref.
Feb 13, 2009 | Whirlpool ER2MHKXPL 22.0 Cu. Ft. Freezer...
Fridge not cold enough and build up of ice at back of fridge
May be your damper switch not closing your damper when it reaches tempature setting.
Dec 13, 2007 | Smeg FA311X Top Freezer Refrigerator
Refrigerators Logo
176 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
