Question about Refrigerators
Hi I had a leak in my water line to the ice maker. I replaced the line, now it will not make ice. Water is not going into it.
  • 909 Answers
The fact that it was running fine before you replaced the pipe indicates the problem is with either the connections on either side or possibly the pipe is kinked or the wires from the solonoid pipe have been accidently moved. Firstly Dissconnect each end and see if pipe is clear and round on both sides. if good, blow into one end and see if blowing is possible. Then replace one side of pipe onto solonid side. With the opposite end open activate the valve. Water should come out in about 3 seconds. no water = vave not activating.If you are not farmiliar with mains power i suggest you dont test solonoid by yourself. Get help. Put a lead onto the solonoid and plug into mains. Switch on briefly and see if sol. activates with water exiting on the open side. If so switch off and reconnect pipe onto connecter that old one came off from.Once connected, have someone check inside at the icemaker while you put power on to the valve again.If water comes out, switch off- pull plug out then reinsert solonoid wires back onto the sol. Must work. Very seldom will the valve be a problem. Another thing you could do is to activate the test button function.
Posted on Aug 19, 2010
icansurf
  • 72 Answers
SOURCE: ice maker leaking water after replacing the solenoid valve two times
maybe the solenoid stays on too long during the fill cycle.. broken gear maybe or out of adjustment
Posted on Jul 11, 2007
SolutionGuy
  • 331 Answers
SOURCE: water leaking
Tarena, it's been my experience with Amana that tells me you have a failed water inlet valve.
Here's how it works; Water comes from the wall into the fridge to the valve I'm talking about. Now this valve works like this... When you put a cup in the dispenser area to get cold water a switch sends 120 volts to the valve and it opens up allowing water to flow through it. When you remove the cup, power is shut off at the valve... the valve is supposed to close all the way, if it didn't there would be water dripping from the dispenser area, right? (Like a leaky faucet) If the valve is bad, it won't open at all. (Like a blown out light bulb)
The ice maker is similar. When it "harvests" ice and it drops into the ice bin, the IM will send 120 volts to the valve (for 5 seconds or so) to re-fill the ice mold so it can make another batch. Now when the power is removed from the valve, it's supposed to shut off all the way. If it didn't, there would be water dripping into the ice maker fill tube (in the freezer behind the ice maker). drip, drip drip... one after the other.
Let's assume that the ice maker valve didn't close all the way. What would happen then? As these drops of water enter the freezer compartment and are heading down the ice maker fill tube toward the ice maker, they don't make it all the way 'cause they FREEZE in the tube! One drop at a time, week after week. ('course you never notice it, 'cause it's in the freezer) Now... the ice maker is still trying to make ice, so every 45 minutes or so it sends 120 volts to the valve to get more water. But the water fill tube has ice in it because of the water drops that have accumulated there. This goes on over time and eventually the water fill tube becomes completely BLOCKED with ice due to those water drops.
Now what happens? The ice maker is still trying to make ice, but the fill tube is blocked... it can't get water through it. But when the water valve opens up to allow water to the ice maker, where does it go? Since the fill tube is blocked, all that water pressure builds up in the water line (tube) that feeds the ice maker and eventually it blows out! (you can verify this... pull the refrigerator out from the wall, look at the water line going to the ice maker. There's a connector back there for the tube to fit into. This is what's blown out.) Now the tube is just dangling there and not hooked up to the ice maker any longer. Since the ice maker is still running, every time it asks for water it sprays out and onto the wall and floor back there through this dangling tube.
The repair? Replace the valve. It's easy. The part number is 67005154 and it lists for about $21.00. You can find one at any appliance parts retailer. (you'll see where the valve is located... it's where the water line hooks up behind the fridge.) UNPLUG YOUR FRIDGE WHILE YOU WORK ON IT!!!
Just replacing the valve is only half the job. You'll still need to remove the ice build up in the ice maker fill tube. Do this by pulling it straight out the back of the refrigerator and putting it under warm running water. Then re-install it and hook the water tube back up to it.
On some models, you can not remove the fill tube. If you can't get it out the back, you'll have to do it from the freezer compartment behind the ice maker (a little more work, but still do-able). It's easiest by removing the ice maker.... pull the ice bin out and set it aside. Then remove the 3 screws holding the ice maker. You don't have to disconnect the wires, just try to get it out of your way the best you can. Now take a hair dryer and thaw out the fill tube until the ice slides out of there. Then rebuild it.
There ya go! Job time? about an hour. Part cost? about $21.00. Knowing that you fixed it yourself? Priceless.
Posted on Oct 15, 2007
  • 1314 Answers
SOURCE: leaking water line
should have a small metel clamp there if not you can get a small clamp about any where and the fill tube being partialy frozen can be an issue the easiest way ive found to deal with this is to get a eureka 301 hand held enviro steamer its a little investment but there are about 1000 outher uses for it around the house and it wont hurt the fridge just let it heat stick the tip in the in the ice maker fill tube where the water line goes and pull the trigger till steam comes out the other end bingo does windows sinks stoves etc.thaws evaprators clears frozen drains seal door gaskets without melting them getting this master tech http://www.overstock.com/Home-Garden/Eureka-350-Hot-Shot-Enviro-Steamer/371207/product.html?fp=F&kid=4087&cid=52417
Posted on Feb 16, 2008
  • 17 Answers
SOURCE: No water to the ice maker
Yeah, the valve is definitely not turned on. Just turn the valve and you should be good to go...
Posted on May 07, 2008
VtToolMan
  • 704 Answers
SOURCE: leaking water from the ice maker
It is very unlikely that you have a leaking water line inside the fridge/freezer, as they are protected from damage. If you have water dripping from the ice maker inside the freezer and/or the dispenser in the door, the most likely problem is the valve that supplies water to the ice maker.
You'll need to replace the water inlet valve that supplies water to the ice maker. This is not the same valve that supplies water to the fridge (I believe the yellow colored valve) but rather, it is the blue valve, mounted just above the main water inlet valve.
At the bottom back right side of the fridge, you can remove the covering and see both the yellow and blue valves. The yellow one (on the bottom) is the incoming water control valve, while the blue (upper one) supplies water to the ice maker.
The part runs about $45-50 if you get it yourself, or around $185.00 for a repair person to come out and do the job for you. It should only take about 20-30 minutes to do it yourself with a small 1/4" nutdriver. Part available from Searspartsdirect.com or several other online and local stores. Just call around and give them your fridge model number and serial number, located on the inside of the fresh food section of the fridge - on the "ceiling" just inside the door.
Hope that helps.
Posted on May 07, 2009
Water flow tube on ice maker leaking by causing ice blockage
When the ice maker calls for water, the valve sends water to the ice maker in the appropriate amount and then shuts off, sending no more water until the ice maker calls for it again. If the water fill line is freezing up, this will cause a leak the next time the ice maker calls for water. The water has to go somewhere. The problem is more than likely the the water valve. It is not shutting off completely and it is allowing a small trickle of water to be constantly sent to the ice maker. This causes the fill line to freeze up and clog. Replace the water valve and defrost the water fill line and solve the problem.
Apr 06, 2014 | GE Refrigerators
Ice maker
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
Water plug to the ice maker keeps popping out
Hi and welcome to FixYa. I am Kelly This is usually caused by water leaking past the ice maker water valve. That water freezes up in the through the chassis water tube and then causes either the line to pop off or the tube to pop out. The remedy is to replace the ice maker water valve in the bottom rear of the unit. I just had to do the same thing for my own ice maker. The water line kept popping off and the ice maker had been making odd sized ice cubes. After replacing the water valve everything is normal.
If you need assistance locating a replacement water valve just respond with a make and model number of your unit and I will help you find a parts source.
Thanks for choosing FixYa.
Kelly
Sep 17, 2010 | Refrigerators
Water line from house supply sprung a leak just before going into the ice maker control unit in the lower right cornor of the frig. After replacint the water line the water did not flow into the control...
What once was a leak is now no flow and no response when trying to turn on ice maker? Is the valve where the ice maker line taps into turned back on? If it's back on, first turn it off, take loose water line as close to ice maker as possible, then have someone else turn valve at tap slightly on while you watch for water flow. If no flow, start back-tracing your connections until you find the blockage. Most water connections of this type have a in-line filter. Is it clogged? If you have water pressure as close to the ice maker as you can test, next you may need to troubleshoot the ice maker it's self. Let me know?
Jan 02, 2010 | KitchenAid Superba Architect KSCS25INSS...
Getting water
I have Kenmore Coldspot refreidgerator and am having a problem with water pooling inside the fridge at the bottom underneath the drawers (mostly the left side). Where is the water coming from and it formed a thin ice.
Thanks
Nov 25, 2009 | Kenmore Refrigerators
Water wont go all the way into the ice maker
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Or
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Oct 08, 2009 | Kenmore Refrigerators
Ice maker water leak in freezer. 8 yr old Amana std freezer on top, water actively leaking from ice maker into bin. Is it worth repairing?
Probably the solenoid (electric valve that opens and let the water from the supply line go into ice maker when It calls for it) is leaking and needs to be replaced ,it's not an expensive job. To make sure this is the problem ,shut of the ice maker by putting up the lever and wait a few hours and look inside the ice maker , if is water inside ,that's the problem ,if not the ice maker is the problem and has to be fix or replaced ; but is better to replace it ,won't be a big diference in cost.
Sep 27, 2009 | Freezers
Water leak from ice dispenser line
hi..
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
For the ice maker problem, Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.If it does, the problem is the ice maker and not the valve and line...
thank u
rate me!!
Jul 26, 2009 | GE Refrigerators
Water dispenser leaks, ice maker won't make ice. Hve disconnected line at bottom front, and tried blowing out the lines, no help. Model EDQ22DQFNX00
Jul 02, 2009 | Whirlpool ED2FHEXN Side by Side...
THE REFRIGERATOR IS NOT MAKING ANY ICE, ON THE ICE MAKER
Here is what I would do:I would put some water into the ice maker and wait. If it kicks a batch out, I would replace the watervalve. I would locate the water line going under the rear of the ice box and shut down the water. I would gently remove and replace the valve and snug up the connections, check for leaks and wait and see if the ice starts back in production. if no ice I would then replace the ice maker which is easier still than replacing the water valve but a bit more exspensive. Since you want to got the cheapest route the water valve would be the start.
Jan 15, 2009 | Frigidaire FRS26W2A Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
