Question about IBM (4317-4162) Network Adapter
When I power on the IBM 4317 printer the machine goes thru a self test and some of the gears that move the paper appear to be partially stripped. The printer throws an 61 error. Is it worth fixing? Are these parts still orderable and is it something if I had the documentation I could change out myself? It appears the whole Paper transport is still available but the cost of that alone is just a little less then what a new printer would cost.
    Problem Solver:
  • 6 Answers
Resident ROM checksum error. Ensure the controller PWB is properly installed and restart the printer. If this action does not clear the code, install a new card. get more information from here http://www.fixyourownprinter.com/forums/printer/67694#2
Posted on Aug 19, 2010
Getting printer stall code on screen...
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test.
To self-test the printer, please follow the steps given below:
1. Press and hold the "Plus" (+) button. While holding it down, press the "Scan" button. Once the screen changes, release both buttons. The screen will display the firmware version until the buttons are released. Then it will display 0: Button test.
2. Press the "Plus" (+) button once. The screen will display "Single Test Page."
3. Press the "Menu" button.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed.  If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Oct 03, 2009 | Lexmark X5250 All-In-One InkJet Printer
Carrier stall
1. Press the "Menu" button 10 times. It should then read "Maintenance" on the printer's display screen.
2. Press the "Select" button once. You should then see "Cartridges" displayed on the printer screen.
3. Press the "Right Arrow" button 3 times, which then brings you to the "Self-Test" option.
4. Press the "Select" button once. It should print out a sheet of paper with horizontal color and black lines and smaller vertical lines.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues and we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
Oct 03, 2009 | Lexmark X85 All-In-One InkJet Printer
Indicating a carrage problem, carrage going to fast and slaming into one on start up
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test. If it slams to the left again, the strip is not yet set correctly.
If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
try this printer self-test by following the steps given below:
1. Please press the "Options" button 10 times. "Cartridges" should now appear in the display screen.
2. Press the "Left Arrow" button once, which then brings you to the "Self-Test" option.
3. Press the "Select" button once. You will hear a series of clicks.
4. It should print out a sheet of paper with horizontal color and black lines and smaller vertical lines.
You should see text followed by a thick 1-inch black bar. Under this bar, should be a process gray bar about ½-inch thick. Below this line should be a set of railroad like bars of cyan, magenta, and yellow.
Oct 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
Alignment problem hardware error 0502. Printer is an X6150.Can n
1. Press the "Options" button 9 times. "Maintenance/Align" should now appear in the display screen.
2. Press the "Right Arrow (+)" until "Test" appears.
3. Press "Select."
You should see text followed by a thick 1-inch black bar. Under this bar, should be a process gray bar about a 1/2-inch thick. Below this line should be a set of railroad like bars of cyan, magenta, and yellow.
Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If you cannot repair the strip, please contact Lexmark tech support for further assistance.
Oct 01, 2009 | Lexmark X6150 All-In-One InkJet Printer
HOW DO I FIX A SHORT CIRCUIT ON A LEXMARK X1185 PRINTER?
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If you cannot repair the strip, please contact Lexmark tech support.
Sep 30, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
LEXMARK 7350 IS NOT WORKING
HI,
Please follow the instructions given below to know exactly when the light is blinking:
1. Disconnect the USB cable and the printer power cable.
2. Please disconnect the power supply from the back of the printer.
3. Then remove the cartridges from the printer.
4. Please reconnect the power supply back and turn on the printer.
5. If lights are blinking then printer encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
6. The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
7. The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and let us know if the lights are still blinking.
8. If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer. We will replace the printer, only if it is under warranty.
9. However, if lights are not blinking then try inserting one cartridge at a time and check if you can see any lights blinking. If light blinks with one cartridge then that cartridge is defective.
Next, lets try to print the self test.
Begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." This is essential. Then plug the printer back in and follow these steps:
1. Press the "Copy" button.
2. Press the "Menu" button.
3. Press the down arrow button once or until the screen displays "Maintenance."
4. Press the check mark button to select the "Maintenance" menu.
5. Press the down arrow button three times until the screen displays "Print Test Page."
6. Press the check mark button to select this. The Self-Test will start printing.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously.) Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let me know.
your's tech expert
Jeeth
Dec 28, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Hardware error code 0502
HI try this its from the lexmark web site.
Hardware Error 0502 on LCD Display ID:ENUS16536
Check the encoder strip on the printer. (This is a clear strip running the length of the printer, above or behind the cartridge carrier.) Do the following:
1. Switch off the printer using the power button.
2. Disconnect the power cable from the back of the Lexmark X5100 / X6100 Series.
3. Leave the power cable disconnected for 30 seconds.
4. Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
5. Take out both cartridges.
6. Place an index finger on the encoder strip on either side of the cartridge carrier.
7. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
8. Lightly press the strip first to the rear and then forward, if necessary.
9. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
10. Reconnect the power cable and switch the printer on again.
11. Perform the hardware test without cartridges first and then with both cartridges.*
12. Make a standalone copy.
13. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
How to Perform the Hardware Test on the Lexmark X5150 ID:ENUS3744
Using the operator panel on the printer:
1. Press the Option button 10 times until Cartridges appears on the LED display.
2. Press the + button 4 times until Self test appears on the LED Display.
3. Press Select. The printer should print a sheet of paper with one black bar and one grey bar.
4. If the printer fails to print, remove both cartridges and try the test again. (It will feed the paper through and print a blank page.)
5. If the test works with no cartridges in the printer, run it again with one cartridge at a time installed.
Aug 21, 2008 | Lexmark Office Equipment & Supplies
Hardware error 0502 on lexmark 3in1 printer
Mar 31, 2008 | Lexmark X5150 All-In-One InkJet Printer
Erorr 0502
The encoder strip may have gone out of range of the sensor, or it might be dirty .
Resolution
You need to check the encoder strip on the printer. This is a clear strip running the length of the printer, above or behind the cartridge carrier.
Encoder strip is a transparent strip which is behind the cartridge carrier ,This strip is very delicate handle with care please do not apply to much stress as this may break the strip and make ur printer useless
Disconnect the power cable from the back of the X5100
The red arrow points to the encoder strip. Click here for an enlarged view.
Perform the hardware test first without cartridges and then with both cartridges.
Press the + button four times or until Self test appears on the LED Display.
If the printer fails to print, remove both cartridges and try the test again. It will feed the paper through and print a blank page.
Mar 07, 2008 | Lexmark X5150 All-In-One InkJet Printer
Computers & Internet Logo
50 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
