FixYa.com
Tags:
Standard Televisions
Generic problem for all Standard Televisions
RCA television suddenly has problems with cable...
posted by SQPiggy on May 02, 2008
I have cable connected to my RCA 19" television (no converter box or VCR attached). Picture was great until I moved the set across the room. As a result, channels 2-10 get lousy reception with snow and ghosting. I checked all the connections and still no luck. These channels aren't even recognized while doing a channel search. All the other channels to 100 come in fine. Any ideas?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 02, 2008
Thanks for Trying (70)
Abrsvcs
Rank:Guru Guru
Rating: 85%, 515 votes
You have a bad ground connection somewhere. Either the cable has a break in the ground side or there is a connection problem elsewhere. Try with another cable if possible.
Dan
Rating Locked! (?) SQPiggy has rated this solution as Thanks for Trying
This Problem Also Relates To: GE 31GT660 TV GE 27GT271 TV GE 27GT722 27" TV Memorex MT2206 TV Sony FD Trinitron WEGA KV-27FS100 27" TV Sony FD Trinitron WEGA KV-27HS420 27" TV Sony FD Trinitron WEGA KV-32HS510 32" TV
Can you Help with these Standard Televisions problems?
GE 32GT740 32" TV
No soounding in my GE 32GT740...
Whenever I turn on my TV,... Answer This...
Zenith C27A24T 27" TV
codes not working
i have a zenith c27a24t tv and... Answer This...
Sony FD Trinitron WEGA KV-24FS120 24" TV
fixed channel
I have a sony trinitron tv and... Answer This...
JVC AV27F577 27" TV
jvc AV27F577
The green light in front of the... Answer This...
TV has picture but no sound
This just started a few days... Answer This...
Repair Service
Find Standard TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
