Question about Nokia 6300 Cellular Phone
The charger is not working - Nokia 6300 Cellular Phone
What volt charger do i need to charg mower 12volt battery?
Doug, Any 12 volt automotive charger will work for your lawn tractor, the cheaper no frills chargers will work fine.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Battery Chargers Canadian Tire
Amazon com Battery Chargers Jump Starters Battery Chargers Portable Power...
Car Battery Chargers
Feb 27, 2016 | Cub Cadet Garden
Napa charger #85-435 will not charge
He said his battery charger is not working, this has nothing to do with the car not starting or charging? So if anyone can recomend what he needs to do to get his battery charger working would be helpful to him.
Mar 01, 2013 | Cars & Trucks
Scooter charger not working
Check the charger voltage. It should be 29 volts when not connected to the scooter. Anything less is a component gone bad on the circuit board.
Jul 28, 2012 | Pride Revo 3 Wheel Scooter
Charger problem how to identify
Hi, to identify charger. You will need to test another charger on the cell phone and test that same charger on another phone to confirm if the charger is working.
Also after testing for the charger and and if the charger works, that means the charging port of the phone where the charger is been inserted is damaged.
It will need to be fixed.contact you local repair person for help.
Take care.
May 22, 2011 | Cell Phones
When I plug it in to charge it does nothing. No lights the gauge doesn't move . Any ideals ? She have had problems like this for years off and on . They send out a repair man and it will work for a short...
Could be the charger or the charger port. Do you have the offboard charger that plugs into the joystick or an onboard charger? I would suggest trying to find an offboard charger from a friend or your provider that you can borrow and plug it into the charger port under the front of the joystick to see if it will charge the batteries. the meter will not work if you use an offboard charger the lights on the charger will turn green when it is fully charged. when the charger is plugged into the joystick and you turn on the chair the lights should scroll indicating you have the charger inhibit function working and hopefully the chair is charging. If you can charge the chair with the offboard charger then look into buying one and using it instead of trying to get the onboard charger working Hope this helps
Mar 04, 2011 | Jet 3 Ultra Power Chair
Hi i have a dell 6400 notebook when the charger conected to notebook cpu usage is 100% and do not work corectly but when disconect the charger work normal and good, (whith battry) this problem happen when...
hi
when plug adoptor any trebal in mouse working if mouse aero do some problem buy orignal charger
becuse local charger is not work properly dell some model spaishaly 6400 ok if u have orignal charger change bettary
if fix your problem click yes for vote
Jan 06, 2011 | Dell Inspiron 6400 Notebook
Charger not working. Not charging at all. moved to an outlet i know works but no charging
toad Try to locate a friend or someone who also has a off-board charger you could borrow. Then contact your provider to see if they can order you a charger It doesn't have to be a Pride charger any good 4 amp charger will work.. Also try e-bay for any good used charger Hope this helps
Oct 18, 2010 | Jet 3 Ultra Power Chair
My casio boulder will not charge how do I fix it
Hi, you can check with another charger first to know exactly what the problem really is before you can take the next step .Also check the phone on another charger.
After checking with another charger, if charger work,that means the charging sport where you plug in the charger is not working and need to be replaced.
If when you check the charger with another phone and and the charger doesn't work, replace charger.
Take care.
Jun 15, 2010 | Casio G'zOne Boulder Cell Phone
Charging problems
umm dat mite be a prob becuz the car usually pumps more voltage in the fone...........and if too much is pumped it damage the circuit board and mite even fry the system...... be care ful and keep trying the wall charger..........hope it works
Feb 21, 2007 | Motorola Mobility RAZR V3
Nokia 6300 Cellular Phone Logo
51 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
