Question about HP Officejet 5610 All-In-One InkJet Printer
Printer cartridge won't release - HP Officejet 5610 All-In-One InkJet Printer
  • HP Master
  • 6,826 Answers
Just pull it out with about 5 to 10 lbs. of force.
Posted on Aug 19, 2010
Prnter won't recognize red ink cartridge. When I push down on the cartridge the recognition light comes on, but goes off when I release to close printer cover.
My printer just died. The first indication of a problem was ink cartridges not being recognized. I replaced 3 in one night. The next time I went to print the entire unit just lost power and will no longer power on. From what I've been reading a bad print head can fry the logic board. At that point the only solution is to replace the board. For a 5+ year old machine and a logic board that will cost ~$100, it doesn't seem worth repairing.
Dec 14, 2012 | Canon PIXMA MP830 All-In-One InkJet...
My HP 940C printer won't move the ink cartridge
Symptom look like carriage jammed in service station,open cover gently try to pull carriage out if its jammed, open top & side covers, release service station capping through manually rotate gears, once its released, push carriage left side, remove service station & verify why its jammed, if found any breakage replace it, or clean it..but little bit technical skill required..see the similar diagram below:
Dec 22, 2011 | HP DeskJet 940c InkJet Printer
HP Photosmart C4140 error message won't go away Remove and check color cartridge. I have done this and unplugged, checked both color and black cartridges...won't go away.
hey, sometimes there are faulty cartridges. i use to got some brand new and original from the shop and not working.. so try it with some old cartridge if you have.. you can also try to remove the cartridge and clean/wipe the contacts on the cartridge side and on the printer side (turn of the printer for safety)
Sep 18, 2011 | HP Officejet 5510 All-In-One Thermal...
My canon mp160 printer has the color light blinking (I checked to make sure it has ink and the cartridge is in correctly) and won't print color. Thanks for any help.
Usually the cartridge is out of ink in which case get it refilled or it may be electrically failed in which case you will need to buy another cartridge.
If putting a refilled cartridge in the machine you will normally get some kind of error code, to clear this, press and hold the resume button (Black with red circle with an arrow head pointing towards you) for about 10 seconds then release it and usually you can print. The orange light will however stay illuminated or flashing.
Sep 11, 2011 | Canon PIXMA MP150 All-In-One InkJet...
When opening my printer to get to the cartridges, they are stuck inside the printer and won't move. The on/off button is flashing.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 26, 2011 | Lexmark Z2320 InkJet Printer
Will 27 black and 28 tri-colour cartridge work on a D1560 hp deskjet
HP 21 black and HP 22 tricolor cartridges are the cartridges compatible with HP DESKJET D1560.HP 27 and 28 won't work with your printer because they won't get recognized by the machine.It will only give you an error message like incompatible cartridges.
Jul 21, 2011 | HP D1560 Deskjet Printer InkJet
Error 5100. the ink cradle moves on start up, the ink cartridges are brand new. Won't print a thing... "Check Printer, Error 5100" Canon MX300. Used once.
You need to reset your printer to remove this error. But first, may I suggest that you remove first your ink cartridge. Clean the contact surface using a cotton bud moistened with alcohol. After cleaning return back the cartridge.
Follow these steps:
1. Turn off the printer
2. Press and hold down the Stop/Reset button and Power button for 5 seconds.
3. While holding the Power button, release the Stop/Reset button.
4. While still holding the Power button, press the Stop/Reset button twice
5. Release Power button (wait till you get the lights)
6. Press the Stop/Reset button 3 times each having a 3 seconds gap. (check whether you are getting the orange light or not)
7. Press the Power button and enter data.
8. Remove the cartridge. Leave it for 20 seconds
9. Press the Power button and shutdown printer.
10. Return cartridge and start the printer.
11. Set the language and country.
After the first reset procedure and there is still an error, do this 2nd reset.
When the error is displayed on the display panel of the printer, 1. Press and Hold the STOP/RESET button and wait until it self restart.
2. Release the STOP/RESET button so printer will completely restart. After this, your printer will print again.
Please give this solution a 4 thumbs up rating.
Thank you for using Fixya
May 24, 2011 | Canon PIXMA MX300 All-in-One Printer
Ink cartridge full but won´t print
This might need to be reset.
Here' how...just follow the instructions..
moz-screenshot.pngThere's two ways to reset it
First: Soft Reset
1. Open front cover.
2. Hold down button located under LED's until all LED's are lit.
3. Release button and make sure drum LED is off, then
4. Close cover
Second: Factory Reset
1. Turn the printer off.
2. Hold in the circular button on the front panel of the printer.
3. Turn the printer back on.
4. When the DRUM light is lit by itself let go of the button.
5. Hold in the circular button on the front panel again.
6. Once the Alarm light comes on, let go of the button.
This will perform a factory reset on the printer.
I hope that's everything you want.
Please accept this answer if this will help you.
Thank you for using Fixya.
Oct 02, 2009 | Brother HL 1440 Laser Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
