Question about Gateway M-1625 Notebook
I've been having a lot of problems running games with my current video card. I want to know is it upgradeable? Also which video card could I buy to upgrade it?
  • 6,826 Answers
Video cards of laptops or notebooks are not generally upgradeable. Just desktops and towers are.
Posted on Aug 19, 2010
Upgrading graphics quality on my pc.
There is a large range of graphics card on the market in both performance and prices to match.
The graphic card that suits your requirements depands upon what you want in terms of performance and the application that requires a particular level of graphic capability.
Check the software documentation or games program for the graphic card that is required to run with their program. Generally games programs that require photo realistic rendering require high end graphics cards.
You may select a graphic card that is a bit above your current requirements to cover for future requirements.
I suggest you Google search the Internet or go to your computer shop to see what is available that meets your requirements. You can spend a lot of money on a very high end graphics card when a lessor graphics card would still suit your requirements and not burn a hole in your pocket.
Jun 15, 2012 | Gigabyte Computers & Internet
WHEN I TRY TO PLAY SIMS 3 GAME I GET A EROR MESSAGE YOUR VIDEO CARD DOES NOT SUPPORT SHADER MODEL 2 PLEASE UPGRADE YOUR CARD
a Video card (aka a Graphics card) is a physical component in your computer that renders images and graphics, the higher quality graphics card you have the higher quality of games and images you can play/render.
so what this error means is the graphics card that your computer currently has installed doesn't support a model of shader (think shadows) which is needed to run Sims 3 properly
you can upgrade these cards, but it all depends on other components of your computer as to which would be most suitable for you
if you know anyone with knowledge of computers consult them as it would be free, or otherwise you'll have to have a consultation with a computer technician at your local computer store
hope this helps.
Apr 14, 2011 | HP Pavilion F1703 17" LCD Monitor
Dimension 5150 (DIM515MIN) PC Desktop: I want to know what kind of case a dell has. I'm p...
The Dimension 5150 has a BTX case, which is nearly impossible to upgrade. The motherboard is NOT interchangeable (with a few exceptions, but none of which are true upgrades).
If you have a PCI Express slot, you can upgrade the video card but do not get a card that requires an additional power cable directly from the power supply. This is because the stock power supply is very weak and doesn't have outputs for additional cards. If the card requires no additional power, you should be fine.
You can upgrade your processor with the P4 [Prescott] 5xx or 6xx Series Processors with HT. The 5150 does not support core 2 duo processors. Depending on what you currently have, this may or may not be worthwhile. Also note that higher power processors run at higher temps, which sometimes causes a noticeable increase in fan noise.
The hard drive is easily upgradeable. Just buy any standard sized SATA hard drive. Your computer case supports two drives, so you could keep your current drive and just add a second drive. Remember to buy a SATA cable with the new drive because new drives usually don't come with them.
Overall, if you're looking to get outstanding performance, get a new computer. BTX computers are not gaming computers. You'll end up dumping money into this thing just to get a lousy increase in performance.
May 18, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I play online games (mmorpgs) and when I run these games I lag a lot. Now what is the problem? Should i buy a new graphics card? If so then which one would you recommend?
Find out what kind of interface your current one has, like PCI Express Or just PCI ect. Then go to best buy and buy the most expensive one you can afford with the same interface. If you have a built in graphics card then you may be stuck unless it has slot for an upgrade. Just see what slot your motherboard has for a graphics card before you buy one. If its an onboard but has a slot for a upgrade after installation turn off the onboard graphics card in your bios .
Sep 22, 2009 | Video Game Consoles & Games
Laggy display after a few minutes play
lot of the game now a days require a pretty big video card. A 5200 is outdated and i know u cant upgrade your laptop. The best solution to this is increase the amount of RAM in your laptop to the max. When you run games lower the video settings to low or medium. Another thing that can help is running msconfig in the RUN box and turning off lot of apps that run in background
May 19, 2009 | Nvidia Geforce FX 5200 Graphic Card
Upgrade video card on a gateway 5200 xl pc
You can get this card right now on e-bay for $53 including shipping. Not htr fastest but much,much better,I believe.
New EVGA GeForce 8600 GT 256MB GDDR3 Video Card PCIE 16
Dec 23, 2008 | Gateway 5200XL PC Desktop
I don't what the problem is.
Firstly have you considered it is the game? try restalling
If that doesnt work, it is most likely your video card. dxdiag into run and click all the run test buttons you can see.
Update video drivers and try installing to a different pci slot.
It may be the video cards ram instead of your pcs ram.
but check the pcs ram is compatible.
Oct 08, 2008 | XFX GeForce FX 5500 Graphic Card
Video cards
You Can,t really shuffle Graphics cards Around where Laptops Are Concerned.
the individual manufacturers, want you to buy thier Products Only. hence so many different Socet/Board types.
you,ve gotta grin And Bear What you,ve Got unfortunately, check in the Bios settings, how much of your system memory, is designated to running graphics, Can sometimes be allocated More. That you have the latest video drivers installed for your Graphics Card/Chip.
And that you have Sufficient Memory/RAM installed on the laptop.
Alternative, is to sell And Buy upgraded Machine, Alienware recommended.
Mike @ compurepair.
Posted @ 22.01 PM ( G.M.T )
Mar 02, 2008 | Computers & Internet
Laptop videocard
I would NOT recomment upgrading anything other than RAM and Hard drives on a laptop. It's very expensive, and can't always be done. If you want a gaming computer I'd recommend a desktop computer, as you will get a lot more "umph" for a lot less buck.
Same goes for upgrades. It's easy and fairly cheap (unless you want to have the absolute top knotch parts all the time) with a desktop because so many can use the same parts. Lots of laptops have "their own kind" of parts, which makes them expensive.
Keep the laptop for portability whenever you need your computer with you.
Nov 07, 2007 | IBM ThinkPad R50e Notebook
Open Questions:
Gateway M-1625 Notebook Logo
66 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
