Question about HP Office Equipment & Supplies
Officejet j3680 scanner failure error - HP Office Equipment & Supplies
SOURCE: Scanner Failure
I had the same problem along with the problem of "remove and check color cartridge." Nothing worked until I completely disconnected the power to the K80, both from the wall and from the K80, and left it disconnected overnight. In the morning all worked great. The problem was gone.
John
Posted on May 23, 2008
SOURCE: Scanner Failure: HP Officejet 6210
Option one: Scan using Windows Fax and Scan
Click the Windows icon ( ), click Programs , and then click Windows Fax and Scan .
NOTE: The Windows Fax and Scan option is available in the Business, Ultimate, and Enterprise editions of Windows Vista. If you have the Home Basic or Home Premium edition of Windows Vista, skip to Option two:
Scan using Paint .
Click New scan .
Click File , and then click Scan .
Option two: Scan using Paint
Click the Windows icon ( ), click Programs , and then click Accessories .
Click Paint .
Click File , and then click From Scanner or Camera .
Click Scan .
Cause
The drivers in the Windows Vista operating system do not support button press functionality on the product.
THANKYOU BILL GATES AND HP!!!!!!!!!!!!!!!!!!!!
Using paint worked for me. I got this from HP.
Posted on Oct 16, 2008
SOURCE: HP Officejet 6310 scans once but then says scanner failure
hi,
that error message is nothing to do with the software part, it actaully hardware issue try the following,
1) unplug the machine and connect it to wall outlet directly,
2) unplug the power cord from the printer and press and hold ON for 1 min and release the ON button and plug it back..
3) Disconnect the power cord from the product.Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons and if printer turns off, turn it back ON and wait until it cmopletes its instialization and if still persists, it a hardware failure...............
regards,  raj_p5983
Posted on Jan 22, 2009
SOURCE: officejet J6480 shows scanner failure
officejet k60xi
Posted on Feb 07, 2009
RPFinney
  • 385 Answers
SOURCE: scanning with an Officejet J3680
Click Start , and then click Run .
In the Open text box, type msconfig , and then click OK .
In the System Configuration Utility window, click the Startup tab.
Search the list for HP Digital Imaging Monitor . tick the box.
If HP Digital Imaging Monitor is not on the list,
the driver was not correctly installed and You need to reinstall the software.
Open HP Solution Center with one of the following methods.
On the Windows desktop, double-click the HP Solution Center icon
On the taskbar, click Start , click All Programs , click HP , and then click HP Solution Center .
If more than one HP device is installed, click the tab for the All-in-One product.
Click Settings .
Click Scan Settings and Preferences .
Click Scan to... Setup .
Click the Destination List tab.
NOTE: Depending on the computer performance, it can take several minutes for the
Front Panel Destination List to populate after you turn on the printer or computer.
If the Front Panel Destination List contains valid scan destinations,
you need to reinstall the software.
If the Front Panel Destination List is empty, continue with this procedure.
Click each program to include on the Scan To list.
Click the Add arrow.
Click OK .
Scan a document using the Scan To button on the front panel.
If the scan fails, try to scan using the HP Solution Center Scan button.
If the scan still fails, re-install the software.
Hope this helps
Ric.
Posted on Apr 18, 2009
HOW DO I CONNECT THE PRINTER WITHOUT A CD HP OFFICEJET J3680
Go here: HP Officejet J3680 All in One Printer Drivers and download the driver for your operating system. Follow the instructions to install it on your laptop, and you should be up and running!
Sep 17, 2014 | HP J3680 Officejet All-in-One Printer
Windows 8 doesn't recognize HP scanners.The scanners in question are Officejet J3680 and scanjet 2400
It looks like there is no Win8 driver available at present. The joys of a new OS!
Nov 02, 2013 | HP Computers & Internet
My J3680 keeps dis[playing "Cartridge Error:" "
Remove both cartridges, switch off then on, printer detects cartridge missing, install cartridges one by one & observe which one showing faulty, replace faulty cartridge..end..
Oct 07, 2011 | HP J3680 Officejet All In One Printer
HP J3680 Officejet shows scanner error, will not copy or fax
typically this is a software problem. Please check to make sure you have the correct and most up to date driver installed
Jul 21, 2010 | HP J3680 Officejet All In One Printer
Need advice on how to resize images using the scanner on the hp officejet j3680, I want to take one image from scanned page and make it a certain sizem may last scanner was great and easy to use this one...
I believe you can only adjust it from within your destination scan program. In other words, scan first, open the scan in your editing program and adjust the size from there.
Sep 18, 2009 | HP J3680 Officejet All In One Printer
I can not scan. it said "No scan options" and referer to device documentation.
At first delete your scanner software, then restart ur machine, at that time the machine required the scanner driver. insert ur scanner driver cd and instal it
Sep 16, 2009 | HP J3680 Officejet All In One Printer
Un active the fax,scann,copy
This solution is for "older" R-series All-in-One's but it may be your solution as well. You may be experiencing a situation in AllN1's called "SCANNER SYSTEM FAILURE" where the scanner bulb may be weaker than it appears by naked sight and doesn't meet system power requirements to "pass" as good to go and thereby is passing to the printer a failure condition. In the R-Series AllN1's the ultimate solution was a bulb replacement. Which surprisingly is not as intimidating as it may sound if you might want to tackle the problem on a do it yourself basis. I can give you more details if you would like. I think you can respond to this Solution; I am new to this forum. If you can not respond directly my email address is DanDeeCo-Online@att.net.
Mar 02, 2009 | HP Officejet 5610 All-In-One InkJet...
363 people viewed this question
Seeker5211
Seeker5211
