About dxg battery
What is the amp of the battery this camera is using
Manual
It doesn't. The DXG-301V uses standard AA batteries, either disposable or rechargeable. If you choose to use rechargeable batteries, you must charge them outside the camera using a separate charger.
Jun 23, 2013 | DXG Technology DXG DXG-301V Digital...
The LCD turned Upside down
Try resetting the camera bt removing the battery for 20 mins, then replace the battery and go into the menu and set the Date & time.
Jun 08, 2012 | DXG Technology DXG-305V Digital Camera
Lost the charger and usb cable where can I buy them
Apex Battery offers two DXG-308 chargers
http://tinyurl.com/2fstzxp
laptoptraveler.com has a charger they say is compatible with the DXG-308
http://www.laptoptraveller.com/battery-dxg-dxg-308-digital-camera-accessories.html
You can bypass the need for a USB cable with a card reader. That also saves wear on your camera.
Search Amazon.com for "card reader" and choose one compatible with your memory card
Nov 07, 2010 | DXG Technology DXG-308 Digital Camera
When DXG model 503 powers up, I switch it to camera mode & the unit shuts self down leaving lens out & open? Camera has a lexar SD 256 mb card in it, is this eoungh memory?
Your problem is likely due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Sep 27, 2009 | DXG Technology DXG-503 Digital Camera
Used dxg-503 digital camera won't power on even w/new batteries
If this camera has a memory card, remove it and then try turning it on. Sometimes the memory cards make the cameras act different.
If there is no memory card or card is out and you have same problem, you can send it in to DXG company and they will repair it for $50
May 06, 2009 | DXG Technology DXG-503 Digital Camera
DXG-301V Power won't stay on
laistrop,
The fact that your camera was not used for a year and assuming the batteries remained in the camera (uncharged?) after that long a period of time, it would be very likely the batteries have deteriorated and may need to be replaced. The first thing to try is charging the batteries if you have not already done so. Plug in the charger and allow at least 12 hours for the batteries to charge. If the camera still will not work, the original batteries have very likey lost their ability to hold a charge and will have to be replaced. To test this, without spending too much money, try inserting 4 Alkaline AA batteries in the camera (observe the battery polarity marked on the flip-top battery cover). If the camera works, you should replace the batteries with fresh NiMh rechargeable batteries and charge them before you attempt to use the camera. Allow at least 12 hours for the initial charge unless the battery manufacturer suggests otherwise. I would not recommend using any form of "rapid" or "quick" charge rechargeable battery. If you do, you will be paying extra for a convenience you will not use, unless you plan to use an external quick charger, since the camera is not equipped to support rapid battery charging.
Rega
Feb 17, 2009 | DXG Technology DXG DXG-301V Digital...
Battery
If you would like us to order a new battery, (I recommend TWO) please do the following:
1. Fax a request with the model and specifications of your camera to (626) 839-3674. The request should include a contact address, phone number and email address.
2. You should be contacted shortly with pricing and shipping information for the item that you need.
If you have any further questions, please contact the company at (626) 839-6528 extension 192. Their office hours are Monday-Friday 7:00am-5:30pm PST.
Mar 08, 2008 | DXG Technology DXG-608 Digital Camera
The power will not turn on-DXG -305V
used a usb cord come with DXG-305, you dont need batteries to connect it to computer, because usb deliver the power to the cam
Nov 19, 2007 | DXG Technology DXG-305V Digital Camera
Battery installation for the dxg 552 digital camera
on the bottom of your camera on the right hand side there is a tab that you would'nt really notice unless you know it is there. It slides and pops open
Nov 10, 2007 | DXG Technology DXG-552 Digital Camera
Computers & Internet Logo
David Payne
David Payne
