Question about Neff U1721 Double circotherm Electric Oven
Hi, I have a Neff U1722N0GB double oven. Bottom oven fan had been making a labouring sound for a couple of weeks and then stopped working. Immediately, this seemed to cause the bottom oven to stop heating up, rendering it unusable. The top oven still works fine and the clock is still operating. We would like to try to fix the problem, but don't know whether to replace the fan motor or heating element (don't want to purchase both if only one of them needs replacing). Can you help please?
SOURCE: Fan oven element - HEEELLLLPPPPP !
one element, but you will need to open the rear of the oven to access and remove the 3 screws holding the fan and with a little bit of push and shoving you will be able to remove the screw behind the fan be careful the screw does not get stuck behind the fan. Putting the new element in will require bending the securing bracket slightly but don't worry it will straighten when you replace the screw behind the fan; which is easier to replace than when you remove it
Posted on May 15, 2008
  • 26 Answers
SOURCE: Neff U1721 Double Oven - No Heat
If the fan is running then it is unlikely to be the clock/timer. Yopu need to check if there is voltage to the element but you MUST be careful to avoid an electric shock. There is sometimes a thermal cut out in line with the supply from the thermostat and that would need to be checked. If all OK the thermostat is the likely offender
Posted on Oct 21, 2008
barkencoa
  • 3463 Answers
SOURCE: Changing an element on the main oven - Neff U1721 Double oven
You should not need to remove fan to access the element fixing scew(s).
You may need what is called a torx screwdriver, if the screws are conventional screws, but some times a small screwdriver will undo them if they are not too tight.
let me know if you require any more assistance.
Plz rate my solution.
Thanks.
Posted on Jan 10, 2009
barkencoa
  • 3463 Answers
SOURCE: Neff U1421 double oven fan has packed up ?
Yes it is the fan that needs replacing.
It is a fairly straight forward repair, just remember that the nut that holds the fan blade on is a left hand thread, so to undo it, turn
it clockwise, as though you were you were tightening it.
Please leave a fixya rating for my solution.
Thankyou.
Posted on Feb 04, 2009
SOURCE: i need to set clock on my neff u1322 double oven
Try depressing the two middle bottoms and turning the knob.
Posted on Mar 29, 2009
My Neff U1721 bottom oven has just stopped working - the fan still works, although is a bit noisy - what could be the problem/
Sound like the element has burnt out but if your fan is also noisy it is probley running slow which may have caused the element to overheat and burn out so it would be a good idea to replace the element and the fan motor
Regards
Ian
Apr 20, 2011 | Neff U1721 Double circotherm Electric Oven
NEFF U1271 Oven overheating
Hi it could well be the thermosat has stopped working
Jan 24, 2010 | Neff U1721 Double circotherm Electric Oven
Neff u1421 bottom oven: Either fan works but no
You need to replace the oven fan element, as there is probably a seperate element in use when used on convection heat.
Please rate my solution.
Thanks.
Oct 24, 2009 | Neff U1421 Double circotherm Electric Oven
The fan and oven light in bottom oven works but not heat.
The heating element is the likely culprit as they burn out and go open
circuit..(ie ...disconnected and will not heat up )
If you can use a multi-meter , then the element can be tested using the resistance range (with the oven SWITCHED OFF )
Aug 30, 2009 | Neff U1721 Double circotherm Electric Oven
Neff u1421 bottom oven fan is working t/stat
Can only be either element or thermostat. I suggest you check element and connections
Aug 26, 2009 | Neff U1421 Double circotherm Electric Oven
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Neff U1452 tripping electrics
Hi
sounds like you have a faulty new element. sometimes depending how long you supplier has had the element they get damp and when they get hot they go down to earth. if i was you i would take it back and get another one and try that. hope this helps you .
regards dan
Mar 19, 2009 | Neff U1452 Double circotherm plus Electric...
Neff faulty Fan
Hi.
I would not think that both fan and element are faulty, although it is possible.
if it has a timer make sure that it is on manual and not on auto, as this would stop the oven working.
Other possible fault is faulty main oven selector switch.
Hope this helps. Please do not for get feedback .
Thanks.
Nov 23, 2008 | Neff U1661 Double circotherm super...
Neff single oven
fan heating heating element gone replace it ;Ire close bye
Sep 04, 2007 | Neff U1721 Double circotherm Electric Oven
Neff U1721 Double circotherm Electric Oven Logo
100 people viewed this question
Top Neff Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
