How do I change the speedstream 5200 modem to work off ethernet cable instead of usb??
    Guru:
  • 1,342 Answers
Can't connect using usb cable
Try using Ethernet. That is always the recommended way to connect to the modem, and it works almost 100% of the time without having to install additional software or perform any additional configuration. If you must use USB for some reason then you will need to make sure you have the drivers installed properly before connecting the modem to your computer.
Mar 31, 2014 | Siemens Speedstream 6520 Modem Router With...
Computer does not recognise speedstream 6300
you try form USB or LAN interface \\Ethernet connection (recommended)
  1. Plug one end of the RJ-11 telephone cable into an unfiltered telephone wall jack (enabled for Sympatico High Speed Internet service).
  2. Plug the other end of the RJ-11 telephone cable into the DSL port on the back of the modem.
  3. Plug one end of the RJ-45 Ethernet cable into your computer's Ethernet port.
  4. Plug the other end of the RJ-45 Ethernet cable into the Ethernet Port 1 on the back of the modem.
  5. Insert the rounded end of the power adapter into the Power port and the dual-pronged plug end into your power outlet.
  6. Press the power button to turn on the modem.
USB connection
  3. Plug the small, square end of the USB cable into your computer's USB port.
  4. Plug the wide, flat end of the USB cable into the USB port on the back of the modem.
May 28, 2012 | Efficient Networks Speedstream 6300...
How do I discover or reset the password
Your modem if it is a Speedstream 5200 does not have any wireless capability and as such, there is no need for a password. You can only use one computer connected with an ethernet cable to your computer. What you can do is purchase a wireless router, preferably a N series wireless router because it is stronger than a normal G series router. Normally your modem connects to your computer via the ethernet cable. With a wireless router, instead of plugging the modem to your computer you should plug it in router. From the router you can connect another ethernet cable and plug it in on your desktop. You can connect at least 4 wired computer to your router. For the wireless part, all they have to do is look for the strongest wireless signal then hit connect. If it ask for a password then it should be in the sticker at the side of the wireless router.
Dec 14, 2011 | Efficient Networks SpeedStream 5200 Modem
I have a Speedstreams 5200 E242 modem. Installation stuck after modem connection. Is the 4.2.2.122 driver Windows 7 compatible? Where can I download the good driver for Win 7?
If your router is connected via the Ethernet port no drivers are necessary.
If you don't have a good reason to use the USB port, please use the Ethernet since it's much faster.
Please let me know.
regards
Jan 25, 2011 | Efficient Networks SpeedStream 5200 Modem
Does the speedstream 5200 offer wireless capability?
No it do not ahev wireless feature. details fo this devices are:-
Manufacturer: Efficient Networks Product MPN MPN 33A-5200-701 Key Features Router Functionalities dtrquestion.gif Firewall • DHCP Server Connectivity Wired Interfaces LAN Interfaces 10/100 Base-T WAN Interfaces dtrquestion.gif ATM Additional Interfaces 1 x USB Standards and Protocols LAN Standards IEEE 802.3 CSMA/CD or Ethernet • IEEE 802.3u 100 Mbps (Fast Ethernet) Protocols dtrquestion.gif ATM • DHCP • IP • PPPoA • PPPoE • TCP Routing Protocols RIP Version 1 • RIP Version 2 • Static Routing Remote Management Protocol dtrquestion.gif HTTP • Telnet • SNMP 1 Firewall / VPN Firewall Features Stateful Packet Inspection (SPI) • DoS Prevention • NAT Authentication PAP (UPAP) • CHAP Modem DSL Standards ADSL Lite (G.Lite ITU G.992.2) • ADSL Full Rate (G.DMT ITU G.992.1) Other Features LED Indicators Power • WAN • Activity • DSL Additional Features Auto Crossover (MDI/MDI-X) Warranty Warranty 1 Year Miscellaneous Release Date 2003
May 01, 2010 | Efficient Networks SpeedStream 5200 Modem
I have a siemens speedstream 4200 and windowsXP.
Are you connecting the modem using a USB cable or a ethernet cable.
If its the USB cable you would need the disk supplied with it and if its an ethernet cable, no installation is required.
regards
Sandeep
Oct 19, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Modem
Technical Specifications AAL and ATM Support
VCI 0-65535 address range
VPI 0-255 address range
AAL5 support
Bridging
IEEE 802.1.d Transparent Learning Bridge (dynamic learning of up to 255 addresses)
Spanning Tree support
Certifications
FCC Part 15, Class B
CE certification
Connectors
DSL interface: RJ-11 or RJ-45 (Europe)
Ethernet interface: RJ-45
USB Type B interface (5200, 5500 series)
Diagnostic LEDs
Power, DSL, Activity, Ethernet status; USB status (5200, 5500 series)
Management
Intuitive, Web-based GUI management access
SNMP support
Comprehensive hardware diagnostics
Media Interface
RJ-11 or RJ-45 (European) DSL WAN connection
10/100Base-T RJ-45 Ethernet LAN connection
USB Type B LAN connection (5200, 5500 series)
Power
12V power supply included, 700ma max. 5400/5500 - 12 VDC, 1000ma max.
Routing
DHCP server/DHCP client
Network Address Port Translation (NAPT)
Network Address Translation (NAT)
Packet filtering
RFC 2364 Point-to-Point Protocol over ATM PVCs (PPPoA)
RFC 2516 Point-to-Point Protocol over Ethernet (PPPoE)
RFC 2684 (formerly 1483) Bridged Ethernet and routed encapsulation Routing
Standards Compliance
IEEE 802.3
USB 1.1 T1.413 issue 2 G.992.1 (G.DMT) G.992.2 (G.Lite)
Oct 15, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Speedstream 5200 modem
Open the following link --
speedstream 5200
Download the manual from the link and review page 7 for ethernet connection.
Notice particularly the back of the device. There are four connection points to plug things in the one on the left with DSL is where cable with the phone connectors connects the phone jack to the speedstream 5200. On the right the round connector with the pin is where the power goes. Next to the power connector to the left is a USB connector. In between usb connector and the DSL port is an ethernet connector. One way to avoid the need for the USB software os to use the ethernet connector bu connecting an ethenet cable (wider connector that fits snugly in both ports one on the Speadstream 5200 and the other probably present on your computer.
USB driver including VISTA (if you prefer)
USB driver link
Dec 11, 2007 | Efficient Networks SpeedStream 5200 Modem
Speedstream 5200 nat
you should be able to access your modem in your web browser using 10.1.1.1 as the address . if u haven't changed the password and user name they should both be admin. once in the settings change from static IP to dynamic ip this should solve your connection problems
Nov 15, 2007 | Efficient Networks SpeedStream 5200 Modem
Printer and Modem
are you using a USB cable to connect your modem ? Are you using a USB cable to connect your printer ? If you are using a USB cable to connect your modem, try using an ethernet cable and your LAN card instead. It will work better and you won't need modem drivers to make it work. You do however have to have a LAN card or built-in LAN adapter. As long as you have one of those 2, the best way to hook up your modem would be by using the ethernet jack on the modem straight into your LAN card/adapter. If you are not using USB to connect your modem then please send me your printer model and how it's hooked up and I will help you figure it out. Hope this helps.
Sep 10, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Computers & Internet Logo
David Payne
David Payne
