Question about Sony Handycam CCD-TR87 Camcorder
Caution light flashing on TR5 - Tape is good.
Can this be fixed? Tape goes for a few seconds then the caution light flashs and everthing stops.
    Sergeant:
    Champion:
  • 319 Answers
There may be several reasons for this, - the unit may not be pulling the tape through the transport mechanism because of tape binding in the cassette. Or there could be excessive oxides built up on the captstan. If you can, remove old tape and try a new one. In either case, you should get unit cleaned and checked by a qualified tech.
Posted on Aug 01, 2008
I am trying to turn on the ps3 and shows the red light, when i push it changes to green for a couple seconds and goes back to red again any ideas?
Hi Ponchin,
Are you seeing any flashing red/yellow lights?
If so this is the red light error and you will find that is why the system will not turn on.
Why Does It Happen?
The GPU and the CPU are the 2 main chips in the system and they deal with all of the number crunching however they can get very hot and if they lose connection the system will either freeze up or turn off and give you the red flashing light.
How To Fix?
The key is stopping the heat build up and you can either send it in and they will fix it for you.
Bear in mind that for the PS3 red flashing light error you will be waiting for about 4 weeks and it will also cost you $150 for the repair bill!
Other Ways To Fix?
You can also use a good PS3 Repair Guide to fix it and this will show you how to stop the heat build up with a few household items.
Just make sure that you get a good guide there are some good ones out there!
Click Here For A Complete Review Of All Available PS3 Repair Guides.
Hope this helps and any questions let me know?
Sep 11, 2011 | Sony Playstation 3 (PS3) Console
When turn on geen light stays on fro few seconds then goes back to red light,so cannot turn ps3 on
Hi Denise,
Why Does It Happen?
How To Fix?
Other Ways To Fix?
Apr 21, 2011 | Sony Playstation 3 (PS3) Console
It beeps then just shut off. When I try to turn it back on it comes on for half a second then beeps and the light goes from green to yellow to a flashing red, and it shuts off and then just stays...
Hi Uniballer,
Why Does It Happen?
How To Fix?
Other Ways To Fix?
Apr 09, 2011 | Sony Playstation 3 (PS3) Console
My ps seems to have crashed!! it will only turn on momentarily,the light goes blue for a second, flashes orange?? then turns off!! the red light flashes till i touch the power on sensor,beeps then goes...
Hi tomtoremar,
Why Does It Happen?
How To Fix?
Other Ways To Fix?
Mar 27, 2011 | Sony Playstation 3 (PS3) Console
I was trying to backup my server while exchanging DLT tapes, the tape in use light stayed on and the serve would then alternate to four flashing lights and then back to flashing "Tape In Use...
Try the following action to resovle your issue:
1. Run the Drive Assessment Test in HP StorageWorks Library and Tape Tools.
CAUTION: Running the Drive Assessment Test overwrites the tape. If it is not possible to
overwrite the tape, run the logs-based Device Analysis Test instead.
2. Check the backup logs.
3. Verify that a supported configuration is being used.
4. Check for media damage:
o Incorrect label placement
o Broken, missing, or loose leader pin
o Damaged cartridge seam
o Usage in incorrect environment
5. Check for software issues:
a. Check the backup software.
b. Check that virus scanning software is not scheduled to run at the same time as the back-up.
6. Verify that a tape can be formatted.
Tape Error LED is flashing:
1. Reload the suspect tape. If the Tape Error LED stops flashing, the problem has cleared.
2. Load a new or known good tape. If the Tape Error LED stops flashing, the problem has cleared.
3. Reload the suspect tape. If the Tape Error LED flashes, discard the suspect media as faulty.
From my experience, most of the time it is a bad tape, using a new tape usually solves the problem. If after inserting a new tape and the problem exist, you may need to update your firmware/backup software.
Good Luck
C2Solutions
Jan 13, 2011 | HP Compaq ProLiant ML350 G3 Server
Flashing lights from everthing
Mine is doing the same thing, solution, buy a new printer. No resolution!
Aug 14, 2008 | HP Photosmart C3180 All-In-One InkJet...
Panasonic PV-DV203
the reel sensor is the problem of your camera...most of that problem is a poor connection of reel sensor to the main board socket or connector....it is need to be service now your camera...
May 28, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Fault code possibly
this is when the take up reel either stops or when the reel pulses arent been read properly,have you tried a different tape??.It can be caused by tight tape,if this doesnt work is a job for your local sony service center
May 12, 2007 | Sony GV-D800 Digital 8 TM VCR
Sony Handycam CCD-TR87  Camcorder Logo
243 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
